Greetings,
I use gpio1_11 as PWM2 output.
After I set the PWM output, if the frequency is set to 8KHZ, period = 125000, duty_cycle = 62000, then the output is a square wave. If set to 8MHZ then the output is sine wave,period = 125, duty_cycle = 62.
Can you help me find out what the reason is? Thank you!
Hello, this problem is caused by the oscilloscope. After replacing the oscilloscope, the output is square wave.
Thanks!
Please refer https://bbs.21ic.com/icview-3304758-1-1.html
Best Regards
Zhiming
