i followed this post:
i.Mx6DQSDL DDR3 Script Aid
change the DRAM parameter on my custom board, 4 piece k4b4g1646d DRAM (total 2G bytes) run very well,
here is the calibration result:
DDR Stress Test (2.4.0)
Build: Dec 11 2015, 11:13:38
Freescale Semiconductor, Inc.
Chip ID
CHIP ID = i.MX6 Dual/Quad (0x63)
Internal Revision = TO1.5
Boot Configuration
SRC_SBMR1(0x020d8004) = 0x00000000
SRC_SBMR2(0x020d801c) = 0x22000001
ARM Clock set to 1GHz
DDR configuration
BOOT_CFG3[5-4]: 0x00, Single DDR channel.
DDR type is DDR3
Data width: 64, bank num: 8
Row size: 15, col size: 10
Chip select CSD0 is used
Density per chip select: 2048MB
Current Tempareture: 49
DDR Freq: 528 MHz
ddr_mr1=0x00000000
Start write leveling calibration...
running Write level HW calibration
Write leveling calibration completed, update the following registers in your initialization script
MMDC_MPWLDECTRL0 ch0 (0x021b080c) = 0x00260022
MMDC_MPWLDECTRL1 ch0 (0x021b0810) = 0x002B002B
MMDC_MPWLDECTRL0 ch1 (0x021b480c) = 0x001D0028
MMDC_MPWLDECTRL1 ch1 (0x021b4810) = 0x000D0028
Write DQS delay result:
Write DQS0 delay: 34/256 CK
Write DQS1 delay: 38/256 CK
Write DQS2 delay: 43/256 CK
Write DQS3 delay: 43/256 CK
Write DQS4 delay: 40/256 CK
Write DQS5 delay: 29/256 CK
Write DQS6 delay: 40/256 CK
Write DQS7 delay: 13/256 CK
Starting DQS gating calibration
BYTE 0:
Start: HC=0x01 ABS=0x70
End: HC=0x04 ABS=0x34
Mean: HC=0x03 ABS=0x12
End-0.5*tCK: HC=0x03 ABS=0x34
Final: HC=0x03 ABS=0x34
BYTE 1:
Start: HC=0x01 ABS=0x4C
End: HC=0x04 ABS=0x28
Mean: HC=0x02 ABS=0x79
End-0.5*tCK: HC=0x03 ABS=0x28
Final: HC=0x03 ABS=0x28
BYTE 2:
Start: HC=0x01 ABS=0x54
End: HC=0x04 ABS=0x14
Mean: HC=0x02 ABS=0x73
End-0.5*tCK: HC=0x03 ABS=0x14
Final: HC=0x03 ABS=0x14
BYTE 3:
Start: HC=0x00 ABS=0x4C
End: HC=0x04 ABS=0x1C
Mean: HC=0x02 ABS=0x34
End-0.5*tCK: HC=0x03 ABS=0x1C
Final: HC=0x03 ABS=0x1C
BYTE 4:
Start: HC=0x01 ABS=0x60
Mean: HC=0x03 ABS=0x0A
BYTE 5:
End: HC=0x04 ABS=0x24
Mean: HC=0x03 ABS=0x02
End-0.5*tCK: HC=0x03 ABS=0x24
Final: HC=0x03 ABS=0x24
BYTE 6:
Start: HC=0x01 ABS=0x38
End: HC=0x03 ABS=0x5C
Mean: HC=0x02 ABS=0x4A
End-0.5*tCK: HC=0x02 ABS=0x5C
Final: HC=0x02 ABS=0x5C
BYTE 7:
Start: HC=0x01 ABS=0x58
DQS calibration MMDC0 MPDGCTRL0 = 0x03280334, MPDGCTRL1 = 0x031C0314
DQS calibration MMDC1 MPDGCTRL0 = 0x03240334, MPDGCTRL1 = 0x031C025C
Note: Array result[] holds the DRAM test result of each byte.
0: test pass. 1: test fail
4 bits respresent the result of 1 byte.
result 00000001:byte 0 fail.
result 00000011:byte 0, 1 fail.
Starting Read calibration...
ABS_OFFSET=0x00000000 result[00]=0x11111111
ABS_OFFSET=0x04040404 result[01]=0x11111111
ABS_OFFSET=0x08080808 result[02]=0x11111111
ABS_OFFSET=0x0C0C0C0C result[03]=0x11111111
ABS_OFFSET=0x10101010 result[04]=0x00011011
ABS_OFFSET=0x14141414 result[05]=0x00011011
ABS_OFFSET=0x18181818 result[06]=0x00011001
ABS_OFFSET=0x1C1C1C1C result[07]=0x00011000
ABS_OFFSET=0x20202020 result[08]=0x00000000
ABS_OFFSET=0x24242424 result[09]=0x00000000
ABS_OFFSET=0x28282828 result[0A]=0x00000000
ABS_OFFSET=0x2C2C2C2C result[0B]=0x00000000
ABS_OFFSET=0x30303030 result[0C]=0x00000000
ABS_OFFSET=0x34343434 result[0D]=0x00000000
ABS_OFFSET=0x38383838 result[0E]=0x00000000
ABS_OFFSET=0x3C3C3C3C result[0F]=0x00000000
ABS_OFFSET=0x40404040 result[10]=0x00000000
ABS_OFFSET=0x44444444 result[11]=0x00000000
ABS_OFFSET=0x48484848 result[12]=0x00000000
ABS_OFFSET=0x4C4C4C4C result[13]=0x00000000
ABS_OFFSET=0x50505050 result[14]=0x00000000
ABS_OFFSET=0x54545454 result[15]=0x00000000
ABS_OFFSET=0x58585858 result[16]=0x00000000
ABS_OFFSET=0x5C5C5C5C result[17]=0x00000000
ABS_OFFSET=0x60606060 result[18]=0x01100010
ABS_OFFSET=0x64646464 result[19]=0x01100111
ABS_OFFSET=0x68686868 result[1A]=0x01100111
ABS_OFFSET=0x6C6C6C6C result[1B]=0x11100111
ABS_OFFSET=0x70707070 result[1C]=0x11100111
ABS_OFFSET=0x74747474 result[1D]=0x11111111
ABS_OFFSET=0x78787878 result[1E]=0x11111111
ABS_OFFSET=0x7C7C7C7C result[1F]=0x11111111
Byte 0: (0x1c - 0x60), middle value:0x3e
Byte 1: (0x18 - 0x5c), middle value:0x3a
Byte 2: (0x10 - 0x60), middle value:0x38
Byte 3: (0x20 - 0x70), middle value:0x48
Byte 4: (0x20 - 0x70), middle value:0x48
Byte 5: (0x10 - 0x5c), middle value:0x36
Byte 6: (0x10 - 0x5c), middle value:0x36
Byte 7: (0x10 - 0x68), middle value:0x3c
MMDC0 MPRDDLCTL = 0x48383A3E, MMDC1 MPRDDLCTL = 0x3C363648
Starting Write calibration...
ABS_OFFSET=0x04040404 result[01]=0x10111111
ABS_OFFSET=0x08080808 result[02]=0x10111111
ABS_OFFSET=0x0C0C0C0C result[03]=0x10110111
ABS_OFFSET=0x10101010 result[04]=0x10100011
ABS_OFFSET=0x14141414 result[05]=0x10100010
ABS_OFFSET=0x18181818 result[06]=0x00100000
ABS_OFFSET=0x1C1C1C1C result[07]=0x00100000
ABS_OFFSET=0x60606060 result[18]=0x00000000
ABS_OFFSET=0x64646464 result[19]=0x00000000
ABS_OFFSET=0x68686868 result[1A]=0x00001000
ABS_OFFSET=0x6C6C6C6C result[1B]=0x01001000
ABS_OFFSET=0x70707070 result[1C]=0x01001110
ABS_OFFSET=0x74747474 result[1D]=0x01011111
ABS_OFFSET=0x78787878 result[1E]=0x01011111
Byte 0: (0x14 - 0x70), middle value:0x42
Byte 1: (0x18 - 0x6c), middle value:0x42
Byte 2: (0x10 - 0x6c), middle value:0x3e
Byte 3: (0x0c - 0x64), middle value:0x38
Byte 4: (0x10 - 0x70), middle value:0x40
Byte 5: (0x20 - 0x78), middle value:0x4c
Byte 6: (0x04 - 0x68), middle value:0x36
Byte 7: (0x18 - 0x78), middle value:0x48
MMDC0 MPWRDLCTL = 0x383E4242,MMDC1 MPWRDLCTL = 0x48364C40
MMDC registers updated from calibration
Read DQS Gating calibration
MPDGCTRL0 PHY0 (0x021b083c) = 0x03280334
MPDGCTRL1 PHY0 (0x021b0840) = 0x031C0314
MPDGCTRL0 PHY1 (0x021b483c) = 0x03240334
MPDGCTRL1 PHY1 (0x021b4840) = 0x031C025C
Read calibration
MPRDDLCTL PHY0 (0x021b0848) = 0x48383A3E
MPRDDLCTL PHY1 (0x021b4848) = 0x3C363648
Write calibration
MPWRDLCTL PHY0 (0x021b0850) = 0x383E4242
MPWRDLCTL PHY1 (0x021b4850) = 0x48364C40
Success: DDR calibration completed!!!
| Device Information |
| Manufacturer: | samsung |
| Memory part number: | k4b4g1646d |
| Memory type: | DDR3-1600 |
| DRAM density (Gb) | 4 |
| DRAM Bus Width | 16 |
| Number of Banks | 8 |
| Number of ROW Addresses | 15 |
| Number of COLUMN Addresses | 10 |
| Page Size (K) | 2 |
| Self-Refresh Temperature (SRT) | Normal |
| tRCD=tRP=CL (ns) | 13.75 |
| tRC Min (ns) | 48.75 |
| tRAS Min (ns) | 35 |
| System Information |
| i.Mx Part | i.Mx6Q |
| Bus Width | 64 |
| Density per chip select (Gb) | 16 |
| Number of Chip Selects used | 1 |
| Total DRAM Density (Gb) | 16 |
| DRAM Clock Freq (MHz) | 528 |
| DRAM Clock Cycle Time (ns) | 1.894 |
| Address Mirror (for CS1) | Disable |
| SI Configuration |
| DRAM DSE Setting - DQ/DQM (ohm) | 48 |
| DRAM DSE Setting - ADDR/CMD/CTL (ohm) | 48 |
| DRAM DSE Setting - CK (ohm) | 48 |
| DRAM DSE Setting - DQS (ohm) | 48 |
| System ODT Setting (ohm) | 60 |
