getting started with i.mx 28 - SDK install
2,877 次查看
pizzatime
I have a virtual machine running Ubuntu 10.04
other then that no software is installed
I am having difficulty understanding what i need to compile and build images onto an sd card , support is slow I am hoping to get some help with this.
Thank you in advance for replying.
标签 (2)
2,433 次查看
VladanJovanovic
You'll need Linux BSP release (L2.6.35_MX28_SDK_10.12_SOURCE under Board Support Packages) from:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX287&nodeId=018rH3ZrDRA24A&fpsp=1&...
You'll also need Linux BSP documentation (IMX28_EVK10_12_LINUXDOCS_BUNDLE ) package from:
i.MX287 Product Summary Page
With that, unpack documentation bundle and look at Linux Board Support Package User's Guide (i.MX28_Linux_BSP_UG.pdf). Starting at Chapter 2 there's step-by-step instructions on how to build the Linux BSP.
5 回复数
2,433 次查看
pizzatime
I gave up and switched to the i.mx 53 VM bundle
2,434 次查看
VladanJovanovic
2,433 次查看
pizzatime
hey cool, thanks for the fast response, trying it out now
2,433 次查看
pizzatime
is there a GUI coding interface at the end of this 5+ hour install ?
2,433 次查看
VladanJovanovic
No, this deals with building and flashing Linux BSP.
LTIB will generate target root file system in <ltib_install_dir>/rootfs . Toolchain is in /opt/....
For GUI-based coding, there's manuals on the web on how to set up Eclipse to do cross-compiling.
