getting started with i.mx 28 - SDK install
2,963件の閲覧回数
pizzatime
I have a virtual machine running Ubuntu 10.04
other then that no software is installed
I am having difficulty understanding what i need to compile and build images onto an sd card , support is slow I am hoping to get some help with this.
Thank you in advance for replying.
ラベル(2)
2,519件の閲覧回数
VladanJovanovic
You'll need Linux BSP release (L2.6.35_MX28_SDK_10.12_SOURCE under Board Support Packages) from:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX287&nodeId=018rH3ZrDRA24A&fpsp=1&...
You'll also need Linux BSP documentation (IMX28_EVK10_12_LINUXDOCS_BUNDLE ) package from:
i.MX287 Product Summary Page
With that, unpack documentation bundle and look at Linux Board Support Package User's Guide (i.MX28_Linux_BSP_UG.pdf). Starting at Chapter 2 there's step-by-step instructions on how to build the Linux BSP.
5 返答(返信)
2,519件の閲覧回数
pizzatime
I gave up and switched to the i.mx 53 VM bundle
2,520件の閲覧回数
VladanJovanovic
2,519件の閲覧回数
pizzatime
hey cool, thanks for the fast response, trying it out now
2,519件の閲覧回数
pizzatime
is there a GUI coding interface at the end of this 5+ hour install ?
2,519件の閲覧回数
VladanJovanovic
No, this deals with building and flashing Linux BSP.
LTIB will generate target root file system in <ltib_install_dir>/rootfs . Toolchain is in /opt/....
For GUI-based coding, there's manuals on the web on how to set up Eclipse to do cross-compiling.
