Are you logged into the community? If so, press the "Add Comment" button, then push the "Use advanced editor" link on the right upper corner of the message window, then, after the advanced editor script is loaded, push "Attach" on the right lower corner of the message window.
If you are not logged into the community, first, create your own account, then log in, and then follow the instructions above.
Artur
