fsl-mm-ms-codeclib-2.0.3.tar.gz compilation failure
2,587件の閲覧回数
GongXiPeng
Installation tips article, I use L2.6.35_11.09.01_ER_source_bundle.tar.gz, IMX_MMCODECS_11.09.tar.gz for ltib compile failure. Error message:
Try fsl-mm-ms-codeclib-2.0.3.tar.gz.md5 from the GPP http://bitshrine.org/gpp/fsl-mm-ms-codeclib-2.0.3.tar.gz.md5: 02:19:14 ERROR 404: Not Found. Try fsl-mm-ms-codeclib-2.0.3.tar.gz from the GPP http://bitshrine.org/gpp/fsl-mm-ms-codeclib-2.0.3.tar.gz: 02:19:14 ERROR 404: Not Found. Can't get: fsl-mm-ms-codeclib-2.0.3.tar.gz at. / Ltib line 790.
Please give me fsl-mm-ms-codeclib-2.0.3.tar.gz and fsl-mm-ms-codeclib-2.0.3.tar.gz.md5 these two documents
タグ(2)
4 返答(返信)
2,027件の閲覧回数
MorenoAddadHass
Have you solved this issue? Because this renders the Multimedia Codecs unable to be used on our own compiled kernel+modules, which kind of defeats the purpose of using the imx53 at all.
2,027件の閲覧回数
EricNelson
Senior Contributor II
Sorry Gong,
I thought you hit a problem that was present on an earlier release (that's what I get for posting late  at night).
2,027件の閲覧回数
GongXiPeng
* Freescale Multimedia Plugins/Codecs - fsl-mm-codec-libs & gstreamer-fsl-plugins
fsl-mm-codec-libs.  This is all necessary components, can not install.
2,027件の閲覧回数
EricNelson
Hello Gong,
Double-check the file name.
There's a typo in the spec file that you can fix by either renaming the package in /opt/freescale/pkgs or by changing the .spec file.
