fsl-mm-codecs source availability
2,798 次查看
bonzo
Is the source code for the fsl-mm-codecs available for the iMX53?
I have a customer that would to recompile the libraries with with the hard float option.
Is this source code Freescale's, or was it provided by the IP vendor?
标签 (2)
2,508 次查看
SergioSolis
No, the source code is not available, if your customer wants to recompile, he would need to check with each IP vendor of each codec.
Hope this helps!
2,508 次查看
bonzo
Is there anyway we could have this library recompiled with hard float?
2,509 次查看
SergioSolis
Hope this helps!
