for imx6ull, powered on are stuck
michael_yang
Some boards are stuck when powered on, and restart normal, pls help to analyze log information as below attachment.
Sanket_Parekh
Hello @michael_yang ,
I hope you are doing well.
->Thanks for the logs, I checked.
I have a few queries to ask, Please find them below.
->Please share the dts file changes if you have made any.
->Did you check it with the prebuilt image or customized?
->If customized, Please share the changes related to the DNS server if you have made any.
->Did you check the same with the latest kernel?
Please share the observation.
Thanks & Regards,
Sanket Parekh
