failed to execute child process xterm (no such file or directory)
4,557 次查看
sachusanal
Hai Sir ,
I have crosscompiled Qt application for IMX6qsabresd board.
while running executable in board i get an error like  failed to execute child process xterm (no such file or directory)
i am using core-imag-sato-sdk image in board. if it is the problem of the image
could you please help me solve this issue.
Sachu
2,722 次查看
CarlosCasillas
Hi Sachu,
I’m afraid that Freescale does not support QT code. However, you could refer to the following document from the Community:
Setting up Qt Creator to build for i.MX6
Hope this will be useful for you.
Please accept our apologies for any inconveniences this may cause.
Best regards!
/Carlos
