failed to build tensorflow on offline machine for imx8mp Scarthgap
1,428件の閲覧回数
greeran
I’m building the fsl-image-qt6 image for i.MX8MP with Scarthgap. I built it on an online machine and copied the downloads directory to the offline machine. I’ve successfully used this workflow many times before with other BSP releases (Kirkstone, Zeus, and others), so this isn’t my first offline BSP build.
However, when I try to build the same image on the offline machine, the build fails at tensorflow-lite-tools-native. It seems to attempt cloning extended third-party dependencies (protobuf, etc.), and the downloaded tar.gz files are not sufficient to satisfy it.
Has anyone come across this issue before? If so, what’s the recommended way to resolve it?
Thanks in advance
6 返答(返信)
1,091件の閲覧回数
greeran
i delete all my build, download and sstate and rebuild from scratch. the build was long but successful. i then removed the build_xwayland directory (and kept the downloads and sstate path in the site.conf). i added this flags to the
BB_NO_NETWORK = "1"
BB_FETCH_PREMIRRORONLY = "1"
i removed the internet cable to simulate my offline computer. when running the bitbake fsl-image-qt6 it fails in the parsing
WARNING: /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb: Exception during build_dependencies for fetcher_hashes_dummyfunc | ETA: 0:00:04
WARNING: /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb: Error during finalise of /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb
ERROR: ExpansionError during parsing /workdir/var-fslc-yocto/sources/meta-nxp-connectivity/meta-nxp-matter-baseline/recipes-matter/matter/matter.bb
Traceback (most recent call last):
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 1248, in srcrev_internal_helper(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
d.setVar("__BBAUTOREV_ACTED_UPON", True)
> srcrev = ud.method.latest_revision(ud, d, name)
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 1670, in GitSM.latest_revision(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
except KeyError:
> revs[key] = rev = self._latest_revision(ud, d, name)
return rev
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/git.py", line 850, in GitSM._latest_revision(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, name='default'):
> output = self._lsremote(ud, d, "")
# Tags of the form ^{} may not work, need to fallback to other form
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/git.py", line 832, in GitSM._lsremote(ud=<bb.fetch2.FetchData object at 0x78232b81e3d0>, d=<bb.data_smart.DataSmart object at 0x78233207c820>, search=''):
if ud.proto.lower() != 'file':
> bb.fetch2.check_network_access(d, cmd, repourl)
output = runfetchcmd(cmd, d, True)
File "/workdir/var-fslc-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 970, in check_network_access(d=<bb.data_smart.DataSmart object at 0x78233207c820>, info='git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://github.com/NXP/matter.git ', url='https://github.com/NXP/matter.git'):
if bb.utils.to_boolean(d.getVar("BB_NO_NETWORK")):
> raise NetworkAccess(url, info)
elif not trusted_network(d, url):
bb.data_smart.ExpansionError: Failure expanding variable fetcher_hashes_dummyfunc[vardepvalue], expression was ${@bb.fetch.get_hashvalue(d)} which triggered exception NetworkAccess: Network access disabled through BB_NO_NETWORK (or set indirectly due to use of BB_FETCH_PREMIRRORONLY) but access requested with command git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all ls-remote https://github.com/NXP/matter.git (for url https://github.com/NXP/matter.git)
The variable dependency chain for the failure is: fetcher_hashes_dummyfunc[vardepvalue]
ERROR: Parsing halted due to errors, see error messages above
Summary: There were 2 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
to fix it i need to connect to the internet and then run bitbake fsl-image-qt6 --runall=fetch and then offline build works. the problem that in the offline machine i will not be able to do the runall=fetch.
might you know what my error is and why i am not able to build offline
thanks
1,351件の閲覧回数
greeran
thanks for the response
i am sending the manifests from the repo and the error i get. i tried downloading the download twice and i still get the same error when running in offline (BB_NO_NETWORK = "1" and BB+GENERATE_MIRROR_TARBALLS  = "1" )
<manifest>
<include name="imx-6.6.52-2.2.0.xml" />
</manifest>
this is the manifests from the repo
<manifest>
<default revision="scarthgap" sync-j="4"/>
<remote name="yp" fetch="https://git.yoctoproject.org"/>
<remote name="yp-gh" fetch="https://github.com/yoctoproject"/>
<remote name="oe" fetch="https://github.com/openembedded"/>
<remote name="kraj" fetch="https://github.com/kraj"/>
<remote name="community" fetch="https://github.com/Freescale"/>
<remote name="ossystems" fetch="https://github.com/OSSystems"/>
<remote name="qt" fetch="https://github.com/YoeDistro"/>
<remote name="timesys" fetch="https://github.com/TimesysGit"/>
<remote name="imx" fetch="https://github.com/nxp-imx"/>
<remote name="imx-support" fetch="https://github.com/nxp-imx-support"/>
<remote name="sbabic" fetch="https://github.com/sbabic"/>
<remote name="variscite" fetch="https://github.com/varigit"/>
<project name="poky" remote="yp-gh" path="sources/poky" revision="200d12b6a58ad961d60a7774ca0f7a9d29498724" upstream="scarthgap"/>
<project name="meta-openembedded" remote="oe" path="sources/meta-openembedded" revision="72018ca1b1a471226917e8246e8bbf9a374ccf97" upstream="scarthgap"/>
<project name="meta-clang" remote="kraj" path="sources/meta-clang" revision="2b7433611d80f6d0ee1b04156fa91fc73d3c2665" upstream="scarthgap"/>
<project name="meta-freescale" remote="community" path="sources/meta-freescale" revision="0627128b341cfb2bef7a0832ce8cac0ce1127f13" upstream="scarthgap"/>
<project name="meta-freescale-3rdparty" remote="community" path="sources/meta-freescale-3rdparty" revision="6c063450d464eb2f380443c7d9af1b94ce9b9d75" upstream="scarthgap"/>
<project name="meta-freescale-distro" remote="community" path="sources/meta-freescale-distro" revision="b9d6a5d9931922558046d230c1f5f4ef6ee72345" upstream="scarthgap"/>
<project name="meta-arm" remote="yp" path="sources/meta-arm" revision="950a4afce46a359def2958bd9ae33fc08ff9bb0d" upstream="scarthgap"/>
<project name="meta-qt6" remote="qt" path="sources/meta-qt6" revision="586a6cb5aec755803a3be3cec359baafe89d6432" upstream="6.8"/>
<project name="meta-browser" remote="ossystems" path="sources/meta-browser" revision="dc31889c0899971def535dc1c040edf18bc16691"/>
<project name="meta-security" remote="yp" path="sources/meta-security" revision="459d837338ca230254baa2994f870bf6eb9d0139" upstream="scarthgap"/>
<project name="meta-timesys" remote="timesys" path="sources/meta-timesys" revision="4dc3f4bdfde4a86904b6e1a3d58df4696e7a63fa" upstream="scarthgap"/>
<project name="meta-virtualization" remote="yp" path="sources/meta-virtualization" revision="6f3c1d8f90947408a6587be222fec575a1ca5195" upstream="scarthgap"/>
<project name="meta-imx" remote="imx" path="sources/meta-imx" revision="219f6d04a4c339eb6f2dc626f944bbdf9a716ff5" upstream="scarthgap-6.6.52-2.2.0">
<linkfile src="tools/imx-setup-release.sh" dest="imx-setup-release.sh"/>
<linkfile src="README" dest="README-IMXBSP"/>
</project>
<project name="meta-nxp-connectivity" remote="imx" path="sources/meta-nxp-connectivity" revision="f58365ec75a5768ff3e8e8bcd64f237738c93160" upstream="imx_matter_2024_q3-post"/>
<project name="meta-nxp-demo-experience" remote="imx-support" path="sources/meta-nxp-demo-experience" revision="e8e646e22b1f926aac83bb7ad522efa9cd8ccc45" upstream="scarthgap-6.6.52-2.2.0"/>
<project name="meta-swupdate" remote="sbabic" path="sources/meta-swupdate" revision="d598d4e675b541301ea1dfc8f0c8931983b4dcd0" upstream="scarthgap"/>
<project name="meta-variscite-bsp-common" remote="variscite" path="sources/meta-variscite-bsp-common" revision="10fb8ca3956c6359a9f744da47197048cc28a483" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-bsp-imx" remote="variscite" path="sources/meta-variscite-bsp-imx" revision="19052e7e0b96814b84069fdfd0d03568271c7ec6" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-hab" remote="variscite" path="sources/meta-variscite-hab" revision="ec4e9f1b2f99ad03077af6b847c38f6e9c2378a7" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-sdk-common" remote="variscite" path="sources/meta-variscite-sdk-common" revision="ee4ade553e063e5daed4e083c62ebff647d9e7dd" upstream="scarthgap_6.6.52-2.2.0_var01"/>
<project name="meta-variscite-sdk-imx" remote="variscite" path="sources/meta-variscite-sdk-imx" revision="fbd0a9e4a7390f66e63af63ec7338bced09686f1" upstream="scarthgap_6.6.52-2.2.0_var01">
<linkfile src="scripts/var-setup-release.sh" dest="var-setup-release.sh"/>
</project>
<project name="variscite-bsp-base" remote="variscite" path="sources/base" revision="fa940410b6fa12155da5827c06351791147107d0" upstream="scarthgap_6.6.52-2.2.0_var01">
<linkfile src="setup-environment" dest="setup-environment"/>
<linkfile src="README" dest="README"/>
<linkfile src="scripts/var-start-container.sh" dest="var-start-container.sh"/>
</project>
<project name="var-host-docker-containers" remote="variscite" path="sources/var-host-docker-containers" revision="dd7218bb6e1c76db77cf40552b4cad7dfaa795fc" upstream="master"/>
</manifest>
the error i get
Initialising tasks: 100% |##########################################################################################################################################################################| Time: 0:00:12
NOTE: Executing Tasks
ERROR: tensorflow-lite-host-tools-native-2.16.2-r0 do_configure: ExecutionError('/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/temp/run.do_configure.179032', 1, None, None)
ERROR: Logfile of failure stored in: /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/temp/log.do_configure.179032
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/workdir/sources/poky/meta/recipes-devtools/cmake/cmake-native_3.28.3.bb:do_populate_sysroot', '/workdir/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', 'virtual:native:/workdir/sources/poky/meta/recipes-devtools/ninja/ninja_1.11.1.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'cmake-native', 'libtool-native', 'quilt-native', 'texinfo-dummy-native', 'openssl-native', 'ncurses-native', 'zlib-native', 'make-native', 'ninja-native', 'perl-native', 'bzip2-native', 'xz-native', 'zstd-native', 'gdbm-native', 're2c-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_configure
| + export HTTP_PROXY=
| + export HTTPS_PROXY=
| + export http_proxy=
| + export https_proxy=
| + cmake_do_configure
| + [ /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git = /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build ]
| + [ -e /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/site-file.cmake ]
| + oecmake_sitefile=
| + cmake -G Ninja -DCMAKE_MAKE_PROGRAM=ninja /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/native_tools -DCMAKE_INSTALL_PREFIX:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr -DCMAKE_INSTALL_BINDIR:PATH=bin -DCMAKE_INSTALL_SBINDIR:PATH=sbin -DCMAKE_INSTALL_LIBEXECDIR:PATH=libexec -DCMAKE_INSTALL_SYSCONFDIR:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/etc -DCMAKE_INSTALL_SHAREDSTATEDIR:PATH=../com -DCMAKE_INSTALL_LOCALSTATEDIR:PATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/var -DCMAKE_INSTALL_LIBDIR:PATH=lib -DCMAKE_INSTALL_INCLUDEDIR:PATH=include -DCMAKE_INSTALL_DATAROOTDIR:PATH=share -DPYTHON_EXECUTABLE:PATH=/usr/bin/python3 -DPython_EXECUTABLE:PATH=/usr/bin/python3 -DPython3_EXECUTABLE:PATH=/usr/bin/python3 -DLIB_SUFFIX= -DCMAKE_INSTALL_SO_NO_EXE=0 -DCMAKE_TOOLCHAIN_FILE:FILEPATH=/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/toolchain.cmake -DCMAKE_NO_SYSTEM_FROM_IMPORTED=1 -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DFETCHCONTENT_FULLY_DISCONNECTED=ON -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=ON -DFETCHCONTENT_FULLY_DISCONNECTED=OFF -DCMAKE_SYSROOT= -Wno-dev
| -- The C compiler identification is GNU 9.4.0
| -- The CXX compiler identification is GNU 9.4.0
| -- Detecting C compiler ABI info
| -- Detecting C compiler ABI info - done
| -- Check for working C compiler: /workdir/build/tmp/hosttools/gcc - skipped
| -- Detecting C compile features
| -- Detecting C compile features - done
| -- Detecting CXX compiler ABI info
| -- Detecting CXX compiler ABI info - done
| -- Check for working CXX compiler: /workdir/build/tmp/hosttools/g++ - skipped
| -- Detecting CXX compile features
| -- Detecting CXX compile features - done
| -- Cloning flatbuffers repository from http://localhost:8080/7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz, found in /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/../third_party/flatbuffers/workspace.bzl
| -- Cloning flatbuffers repository revision 7d6d99c6befa635780a4e944d37ebfd58e68a108, found in /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/../third_party/flatbuffers/workspace.bzl
| -- Proceeding with version: 23.5.26.0
| -- Looking for strtof_l
| -- Looking for strtof_l - found
| -- Looking for strtoull_l
| -- Looking for strtoull_l - found
| -- Looking for realpath
| -- Looking for realpath - found
| -- CMAKE_CXX_FLAGS: -isystem/workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/include -O2 -pipe
| -- Cloning https://github.com/protocolbuffers/protobuf...
| [1/9] Creating directories for 'protobuf-populate'
| [1/9] Performing download step (git clone) for 'protobuf-populate'
| Cloning into 'protobuf'...
| fatal: unable to access 'https://github.com/protocolbuffers/protobuf/': Could not resolve host: github.com
| -- Had to git clone more than once: 3 times.
| CMake Error at _deps/protobuf-subbuild/protobuf-populate-prefix/tmp/protobuf-populate-gitclone.cmake:39 (message):
| Failed to clone repository: 'https://github.com/protocolbuffers/protobuf'
| FAILED: protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download
| cd /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build && /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/bin/cmake -P /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/tmp/protobuf-populate-gitclone.cmake && /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/bin/cmake -E touch /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/build/_deps/protobuf-subbuild/protobuf-populate-prefix/src/protobuf-populate-stamp/protobuf-populate-download
| ninja: build stopped: subcommand failed.
| CMake Error at /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1679 (message):
| Build step for protobuf failed: 1
| Call Stack (most recent call first):
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1819:EVAL:2 (__FetchContent_directPopulate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/recipe-sysroot-native/usr/share/cmake-3.28/Modules/FetchContent.cmake:1819 (cmake_language)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/OverridableFetchContent.cmake:537 (FetchContent_Populate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/protobuf.cmake:37 (OverridableFetchContent_Populate)
| /workdir/build/tmp/work/x86_64-linux/tensorflow-lite-host-tools-native/2.16.2/git/tensorflow/lite/tools/cmake/modules/Findprotobuf.cmake:18 (include)
| protobuf/CMakeLists.txt:34 (find_package)
| -- Configuring incomplete, errors occurred!
| WARNING: exit code 1 from a shell command.
| + bb_sh_exit_handler
| + ret=1
| + [ 1 != 0 ]
| + echo WARNING: exit code 1 from a shell command.
| + exit 1
ERROR: Task (virtual:native:/workdir/sources/meta-imx/meta-imx-ml/recipes-libraries/tensorflow-lite/tensorflow-lite-host-tools_2.16.2.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5477 tasks of which 5471 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 9 seconds
1,321件の閲覧回数
Bio_TICFSL
You need to erase everything and restart to download yocto, since I can not reproduce the issue in my building. If you are working with none BSP from NXP, please contact your vendor for this issue.
1,028件の閲覧回数
greeran
hello
after a number of deletions and build i have found a workaround for the problem. it seems that the branch and has for the matter did not match between the downloads/github..matter.git to the bb file. i added to my site.conf
SRCBRANCH:pn-matter = "release/v1.4.
SRCREV:pn-matter = "9042e9281bf619ce0d06d043d5ac3c0c34c24bbe"
and that solved the parsing error. after that  i have a fetch error that tried to get the thirdparty/nxp_matter_support that i did not find in my downloads (which successfully build an image with internet). so to workaround this problem i removed all the installs for "packagegroup-nxp-matter" and such.
This did not solve the problem but enabled me to build my image and because i do not need the application that use the matter it is a sufficient workaround
thanks
1,380件の閲覧回数
Bio_TICFSL
If you download the complete bsp and build the full-image you should not have any issue, please tell us which BSP are you using to test.
1,218件の閲覧回数
greeran
i am deleted all the build and download and sstate. i am now building from scratch and hopefully tomorrow i will be able to test it with a clean build on a machine without internet
%3CLINGO-SUB%20id%3D%22lingo-sub-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp%20Scarthgap%E3%81%AE%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7TensorFlow%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3EScarthgap%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20i.MX8MP%20%E7%94%A8%E3%81%AE%20fsl-image-qt6%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E3%82%82%E3%81%93%E3%81%AE%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%83%AD%E3%83%BC%E3%82%92%E4%BB%96%E3%81%AE%20BSP%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(Kirkstone%E3%80%81Zeus%20%E3%81%AA%E3%81%A9)%20%E3%81%A7%E4%BD%95%E5%BA%A6%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%20BSP%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E5%90%8C%E3%81%98%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81tensorflow-lite-tools-native%20%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%8B%A1%E5%BC%B5%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B5%E3%83%BC%E3%83%89%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%20(protobuf%20%E3%81%AA%E3%81%A9)%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%20tar.gz%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%AE%E3%81%AB%E4%B8%8D%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97SO%E3%81%AA%E3%82%89%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E5%89%8D%E3%82%82%E3%81%A3%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2157039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%E4%BD%95%E5%BA%A6%E3%81%8B%E5%89%8A%E9%99%A4%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A8%20has%20%E3%81%8C%E3%80%81downloads%2Fgithub..matter.git%20%E3%81%A8%20bb%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E9%96%93%E3%81%A7%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82site.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESRCBRANCH%3Apn-%E3%83%9E%E3%82%BF%E3%83%BC%20%3D%20%22%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2Fv1.4%E3%80%82%3C%2FP%3E%3CP%3ESRCREV%3Apn-%E3%83%9E%E3%82%BF%E3%83%BC%20%3D%20%229042e9281bf619ce0d06d043d5ac3c0c34c24bbe%22%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E8%A7%A3%E6%9E%90%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%20thirdparty%2Fnxp_matter_support%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%81%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%E3%80%82SO%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%80%8Cpackagegroup-nxp-%E3%83%9E%E3%82%BF%E3%83%BC%E3%80%8D%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9E%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E5%8D%81%E5%88%86%E3%81%AA%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%20sstate%20%E3%81%97%E3%80%81%E6%9C%80%E5%88%9D%E3%81%8B%E3%82%89%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E9%95%B7%E3%81%84%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81build_xwayland%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A8%20sstate%20%E3%83%91%E3%82%B9%E3%81%AF%20site.conf%20%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%3C%2FP%3E%3CP%3EBB_NO_NETWORK%20%3D%20%221%22%3CBR%20%2F%3E%20BB_FETCH_PREMIRRORONLY%20%3D%20%221%22%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82bitbake%20fsl-image-qt6%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E8%A7%A3%E6%9E%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%20%2Fworkdir%2Fvar-fslc-Yocto%2Fsources%2Fmeta-nxp-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%2Fmeta-nxp-%E3%83%9E%E3%82%BF%E3%83%BC-baseline%2Frecipes-%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC.bb%3Afetcher_hashes_dummyfunc%20%E3%81%AE%20build_dependencies%20%E4%B8%AD%E3%81%AB%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%7C%20ETA%3A%200%3A00%3A04%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%2Fworkdir%2Fvar-fslc-Yocto%2Fsources%2Fmeta-nxp-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%2Fmeta-nxp-%E3%83%9E%E3%82%BF%E3%83%BC-baseline%2Frecipes-%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC.bb%3A%2Fworkdir%2Fvar-fslc-Yocto%2Fsources%2Fmeta-nxp-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%2Fmeta-nxp-%E3%83%9E%E3%82%BF%E3%83%BC-baseline%2Frecipes-%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC.bb%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%BA%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fworkdir%2Fvar-fslc-Yocto%2Fsources%2Fmeta-nxp-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%2Fmeta-nxp-%E3%83%9E%E3%82%BF%E3%83%BC-baseline%2Frecipes-%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC%2F%E3%83%9E%E3%82%BF%E3%83%BC.bb%20%E3%81%AE%E8%A7%A3%E6%9E%90%E4%B8%AD%E3%81%AB%20ExpansionError%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%EF%BC%88%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C%EF%BC%89%3A%3CBR%20%2F%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fworkdir%2Fvar-fslc-Yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__%20.py%22%E3%80%81%E8%A1%8C%201248%E3%80%81srcrev_internal_helper(ud%3D%3CBB.FETCH2.FETCHDATA%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3D%22%22%3E%20%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(0x78233207c820)%E3%80%81name%3D'default')%3A%20d.setVar(%22__BBAUTOREV_ACTED_UPON%22%2C%20True)%3CBR%20%2F%3E%3CBR%20%2F%3E%20%26gt%3B%20srcrev%20%3D%20ud.method.latest_revision(ud%2Cd%E3%80%81%E5%90%8D%E5%89%8D%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F__init__%20.py%22%E3%80%81%E8%A1%8C%201670%E3%80%81GitSM.latest_revision(ud%3D%3CBB.FETCH2.FETCHDATA%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3D%22%22%3E%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20(0x78232b81e3d0)%E3%80%81d%3D%3CBB.DATA_SMART.DATASMART%3E%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(0x78233207c820)%E3%80%81name%3D'default')%3A%20KeyError%E3%82%92%E9%99%A4%E3%81%8F%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%20%26gt%3B%20revs%5B%E3%82%AD%E3%83%BC%5D%20%3D%20rev%20%3D%20self._latest_revision(ud%2Cd%E3%80%81%E5%90%8D%E5%89%8D%EF%BC%89%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E5%9B%9E%E8%BB%A2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%22%E3%80%81%E8%A1%8C%20850%E3%80%81GitSM._latest_revision(ud%3D%3CBB.FETCH2.FETCHDATA%3E%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(0x78232b81e3d0)%E3%80%81d%3D%3CBB.DATA_SMART.DATASMART%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3D%22%22%3E%20%E5%87%BA%E5%8A%9B%20%3D%20self._lsremote(ud%2C%3CBR%20%2F%3E%3CBR%20%2F%3Ed%2C%20%22%22)%3CBR%20%2F%3E%20%23%20%5E%7B%7D%20%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%82%BF%E3%82%B0%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2Fgit.py%22%E3%80%81%E8%A1%8C%20832%E3%80%81GitSM._lsremote(ud%3D%3CBB.FETCH2.FETCHDATA%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3D%22%22%3E%3CBB.FETCH2.FETCHDATA%20object%3D%22%22%20at%3D%22%22%200x78232b81e3d0%3D%22%22%3E%20(0x78232b81e3d0)%E3%80%81d%3D%3CBB.DATA_SMART.DATASMART%3E%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(0x78233207c820)%E3%80%81%E6%A4%9C%E7%B4%A2%3D'')%3A%20ud.proto.lower()%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E!%3D%20'%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB'%3A%3CBR%20%2F%3E%20%26gt%3B%20bb.fetch2.check_network_access(d%2Ccmd%E3%80%81repourl)%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%20%3D%20runfetchcmd(cmd%2C%20d%2C%20True)%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fworkdir%2Fvar-fslc-yocto%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Ffetch2%2F%20__init__%20.py%22%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20970%E3%80%81check_network_access(d%3D%3CBB.DATA_SMART.DATASMART%20object%3D%22%22%20at%3D%22%22%200x78233207c820%3D%22%22%3E%E3%80%81info%3D'git%20-c%20gc.autoDetach%3Dfalse%20-c%20core.pager%3Dcat-c%20safe.bareRepository%3D%E3%81%99%E3%81%B9%E3%81%A6ls-remote%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%20'%2C%20url%3D'%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%20')%3A%3CBR%20%2F%3Ebb.utils.to_boolean(d.getVar(%22BB_NO_NETWORK%22))%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E%26gt%3B%20NetworkAccess(url%2C%20info)%20%E3%82%92%E4%B8%8A%E3%81%92%E3%82%8B%3CBR%20%2F%3Eelif%20not%20trusted_network(d%2C%20url)%3A%3CBR%20%2F%3E%20bb.data_smart.ExpansionError%3A%20%E5%A4%89%E6%95%B0%20fetcher_hashes_dummyfunc%5Bvardepvalue%5D%20%E3%81%AE%E5%B1%95%E9%96%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%BC%8F%E3%81%AF%24%7B%40bb.fetch.get_hashvalue(d)%7D%E3%81%A7%E3%80%81%E4%BE%8B%E5%A4%96%20NetworkAccess%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20BB_NO_NETWORK%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E3%81%BE%E3%81%9F%E3%81%AF%20BB_FETCH_PREMIRRORONLY%20%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%82%88%E3%82%8A%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%20%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20git%20-c%20gc.autoDetach%3Dfalse%20-c%20core.pager%3Dcat%20%E3%81%A7%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F-c%20safe.bareRepository%3D%E3%81%99%E3%81%B9%E3%81%A6ls-remote%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%20(URL%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fmatter.git%3C%2FA%3E%E3%81%AE%E5%A0%B4%E5%90%88)%3CBR%20%2F%3E%E5%A4%B1%E6%95%97%E3%81%AE%E5%A4%89%E6%95%B0%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%20fetcher_hashes_dummyfunc%5Bvardepvalue%5D%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FBB.DATA_SMART.DATASMART%3E%3C%2FBB.FETCH2.FETCHDATA%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E8%A7%A3%E6%9E%90%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%20%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%202%20%E4%BB%B6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%202%20%E3%81%A4%E3%81%AE%20ERROR%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81bitbake%20fsl-image-qt6%20--runall%3Dfetch%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%81%AF%20runall%3Dfetch%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E4%BD%95%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%AA%E3%81%9C%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2160999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%80%81sstate%20%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E4%BB%8A%E3%80%81%E3%82%BC%E3%83%AD%E3%81%8B%E3%82%89%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%98%8E%E6%97%A5%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%81%AE%E3%81%AA%E3%81%84%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81Yocto%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82NXP%20%E3%81%AE%20BSP%20%E4%BB%A5%E5%A4%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%202%20%E5%9B%9E%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%20(BB_NO_NETWORK%20%3D%20%221%22%20%E3%81%8A%E3%82%88%E3%81%B3%20BB%2BGENERATE_MIRROR_TARBALLS%20%3D%20%221%22)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CMANIFEST%3E%3CBR%20%2F%3E%3CINCLUDE%20name%3D%22imx-6.6.52-2.2.0.xml%22%3E%3C%2FINCLUDE%3E%3CBR%20%2F%3E%3C%2FMANIFEST%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E3%81%AE%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CMANIFEST%3E%3C%2FMANIFEST%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Escarthgap%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8C%E6%9C%9F-j%3C%2FSPAN%3E%20%3D%20%22%20%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgit.yoctoproject.org%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgit.yoctoproject.org%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eyp-gh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fyoctoproject%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fyoctoproject%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eoe%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fopenembedded%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fopenembedded%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Ekraj%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fkraj%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fkraj%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eossystems%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOSSystems%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FOSSystems%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eqt%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FYoeDistro%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FYoeDistro%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Etimesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FTimesysGit%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FTimesysGit%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx-%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esbabic%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fsbabic%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fsbabic%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fvarigit%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fvarigit%3C%2FA%3E%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%9D%E3%82%AD%E3%83%BC%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eyp-gh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fpoky%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E200d12b6a58ad961d60a7774ca0f7a9d29498724%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-openembedded%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eoe%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-openembedded%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E72018ca1b1a471226917e8246e8bbf9a374ccf97%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%A9%E3%83%B3%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Ekraj%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-clang%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E2b7433611d80f6d0ee1b04156fa91fc73d3c2665%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-freescale%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E0627128b341cfb2bef7a0832ce8cac0ce1127f13%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-freescale-3rdparty%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-freescale-3rdparty%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E6c063450d464eb2f380443c7d9af1b94ce9b9d75%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-freescale-distro%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-freescale-distro%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eb9d6a5d9931922558046d230c1f5f4ef6ee72345%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-Arm%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-arm%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E950a4afce46a359def2958bd9ae33fc08ff9bb0d%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-qt6%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eqt%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-qt6%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E586a6cb5aec755803a3be3cec359baafe89d6432%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E6.8%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ename%3C%2FSPAN%3E%20%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%A1%E3%82%BF%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eossystems%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-browser%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Edc31889c0899971def535dc1c040edf18bc16691%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3Emeta-%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-security%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3E459d837338ca230254baa2994f870bf6eb9d0139%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-timesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Etimesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-timesys%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E4dc3f4bdfde4a86904b6e1a3d58df4696e7a63fa%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%A1%E3%82%BF%E4%BB%AE%E6%83%B3%E5%8C%96%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eyp%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-virtualization%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E6f3c1d8f90947408a6587be222fec575a1ca5195%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E219f6d04a4c339eb6f2dc626f944bbdf9a716ff5%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap-6.6.52-2.2.0%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3Etools%2Fimx-setup-release.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx-setup-release.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%20%3D%20%22%20%3CSPAN%20class%3D%22%22%3EREADME%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3EREADME-IMXBSP%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-nxp-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-nxp-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Ef58365ec75a5768ff3e8e8bcd64f237738c93160%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx_matter_2024_q3-post%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-nxp-demo-experience%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eimx-%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-nxp-demo-experience%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Ee8e646e22b1f926aac83bb7ad522efa9cd8ccc45%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap-6.6.52-2.2.0%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-swupdate%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esbabic%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-swupdate%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Ed598d4e675b541301ea1dfc8f0c8931983b4dcd0%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-variscite-bsp-common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-bsp-common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E10fb8ca3956c6359a9f744da47197048cc28a483%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-variscite-bsp-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-bsp-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3E19052e7e0b96814b84069fdfd0d03568271c7ec6%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-variscite-hab%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2Fmeta-variscite-hab%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eec4e9f1b2f99ad03077af6b847c38f6e9c2378a7%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%A1%E3%82%BF%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88-sdk-common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-sdk-common%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Eee4ade553e063e5daed4e083c62ebff647d9e7dd%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Emeta-variscite-sdk-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fmeta-variscite-sdk-imx%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Efbd0a9e4a7390f66e63af63ec7338bced09686f1%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3Escripts%2Fvar-setup-release.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3Evar-setup-release.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88-BSP-%E3%83%99%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fbase%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Efa940410b6fa12155da5827c06351791147107d0%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%B8%8A%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20class%3D%22%22%3Escarthgap_6.6.52-2.2.0_var01%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%20%3D%20%22%3CSPAN%20class%3D%22%22%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E7%92%B0%E5%A2%83%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%20%3D%22%3CSPAN%20class%3D%22%22%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E7%92%B0%E5%A2%83%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%20%3D%20%22%20%3CSPAN%20class%3D%22%22%3EREADME%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3EREADME%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Esrc%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3Escripts%2Fvar-start-container.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Edest%3C%2FSPAN%3E%20%3D%22%20%3CSPAN%20class%3D%22%22%3Evar-start-container.sh%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26lt%3B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3D%20%22%20%3CSPAN%20class%3D%22%22%3Evar-host-docker-containers%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%83%AA%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Esources%2Fvar-host-docker-containers%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3D%22%20%3CSPAN%20class%3D%22%22%3Edd7218bb6e1c76db77cf40552b4cad7dfaa795fc%3C%2FSPAN%3E%20%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3D%22%3CSPAN%20class%3D%22%22%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3C%2FSPAN%3E%22%3C%2FSPAN%3E%20%2F%26gt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%8C%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%20...%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20tensorflow-lite-host-tools-native-2.16.2-r0%20do_configure%3A%20ExecutionError('%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftemp%2Frun.do_configure.179032'%2C%201%2C%20None%2C%20None)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftemp%2Flog.do_configure.179032%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CBR%20%2F%3E%20%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%3A%20%E7%9B%B4%E6%8E%A5%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AF%20%5B'%2Fworkdir%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fcmake%2Fcmake-native_3.28.3.bb%3Ado_populate_sysroot'%2C'%2Fworkdir%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fquilt%2Fquilt-native_0.67.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2Fworkdir%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fninja%2Fninja_1.11.1.bb%3Ado_populate_sysroot'%5D%3CBR%20%2F%3E%7C%20%E6%B3%A8%E8%A8%98%3A%20sysroot%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3A%20%5B%5D%3CBR%20%2F%3E%20%7C%20%E6%B3%A8%E6%84%8F%3A%20sysroot%20%E3%81%AB%E6%97%A2%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3A%20%5B'gettext-minimal-native'%E3%80%81'cmake-native'%E3%80%81'libtool-native'%E3%80%81'quilt-native'%E3%80%81'texinfo-dummy-native'%E3%80%81'openssl-native'%E3%80%81'ncurses-native'%E3%80%81'zlib-native'%E3%80%81'make-native'%E3%80%81'ninja-native'%E3%80%81'perl-native'%E3%80%81'bzip2-native'%E3%80%81'xz-native'%E3%80%81'zstd-native'%E3%80%81'gdbm-native'%E3%80%81're2c-native'%5D%3CBR%20%2F%3E%20%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%20%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_configure%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%2B%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20HTTP_PROXY%3D%3CBR%20%2F%3E%20%7C%20%2B%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20HTTPS_PROXY%3D%3CBR%20%2F%3E%20%7C%20%2B%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20http_proxy%3D%3CBR%20%2F%3E%20%7C%20%2B%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20https_proxy%3D%3CBR%20%2F%3E%20%7C%20%2B%20cmake_do_configure%3CBR%20%2F%3E%20%7C%20%2B%20%5B%20%5D%3CBR%20%2F%3E%20%7C%20%2B%20%5B%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%20%3D%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%20%5D%3CBR%20%2F%3E%20%7C%20%2B%20%5B%20-e%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fsite-file.cmake%20%5D%3CBR%20%2F%3E%20%7C%20%2B%20oecmake_sitefile%3D%3CBR%20%2F%3E%20%7C%20%2B%20cmake%20-G%20Ninja%20-DCMAKE_MAKE_PROGRAM%3Dninja%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fnative_tools%20-DCMAKE_INSTALL_PREFIX%3APATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%20-DCMAKE_INSTALL_BINDIR%3APATH%3Dbin%20-DCMAKE_INSTALL_SBINDIR%3APATH%3Dsbin%20-DCMAKE_INSTALL_LIBEXECDIR%3APATH%3Dlibexec%20-DCMAKE_INSTALL_SYSCONFDIR%3APATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fetc%20-DCMAKE_INSTALL_SHAREDSTATEDIR%3APATH%3D..%2Fcom%20-DCMAKE_INSTALL_LOCALSTATEDIR%3APATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fvar%20-DCMAKE_INSTALL_LIBDIR%3APATH%3Dlib%20-DCMAKE_INSTALL_INCLUDEDIR%3APATH%3Dinclude%20-DCMAKE_INSTALL_DATAROOTDIR%3APATH%3Dshare%20-DPYTHON_EXECUTABLE%3APATH%3D%2Fusr%2Fbin%2Fpython3%20-DPython_EXECUTABLE%3APATH%3D%2Fusr%2Fbin%2Fpython3%20-DPython3_EXECUTABLE%3APATH%3D%2Fusr%2Fbin%2Fpython3%20-DLIB_SUFFIX%3D%20-DCMAKE_INSTALL_SO_NO_EXE%3D0%20-DCMAKE_TOOLCHAIN_FILE%3AFILEPATH%3D%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Ftoolchain.cmake%20-DCMAKE_NO_SYSTEM_FROM_IMPORTED%3D1%20-DCMAKE_EXPORT_NO_PACKAGE_REGISTRY%3DON%20-DFETCHCONTENT_FULLY_DISCONNECTED%3DON%20-DCMAKE_EXPORT_COMPILE_COMMANDS%3ABOOL%3DON%20-DFETCHCONTENT_FULLY_DISCONNECTED%3DOFF%20-DCMAKE_SYSROOT%3D%20-Wno-dev%3CBR%20%2F%3E%20%7C%20--%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E8%AD%98%E5%88%A5%E3%81%AFGNU%209.4.0%E3%81%A7%E3%81%99%3CBR%20%2F%3E%7C%20--%20CXX%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E8%AD%98%E5%88%A5%E3%81%AFGNU%209.4.0%E3%81%A7%E3%81%99%3CBR%20%2F%3E%7C%20--%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9ABI%E6%83%85%E5%A0%B1%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20--%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9ABI%E6%83%85%E5%A0%B1%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%7C%20--%20%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BC%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%BC%E3%81%AE%E7%A2%BA%E8%AA%8D%3A%20%2Fworkdir%2Fbuild%2Ftmp%2Fhosttools%2Fgcc%20-%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%3CBR%20%2F%3E%7C%20--%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%A9%9F%E8%83%BD%E3%81%AE%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%7C%20--%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%A9%9F%E8%83%BD%E3%81%AE%E6%A4%9C%E5%87%BA%20-%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%7C%20--%20CXX%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9ABI%E6%83%85%E5%A0%B1%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20--%20CXX%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%20ABI%20%E6%83%85%E5%A0%B1%E3%82%92%E6%A4%9C%E5%87%BA%20-%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%7C%20--%20%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BCXX%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%BC%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%3A%20%2Fworkdir%2Fbuild%2Ftmp%2Fhosttools%2Fg%2B%2B%20-%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%3CBR%20%2F%3E%7C%20--%20CXX%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%A9%9F%E8%83%BD%E3%81%AE%E6%A4%9C%E5%87%BA%3CBR%20%2F%3E%7C%20--%20CXX%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%A9%9F%E8%83%BD%E3%81%AE%E6%A4%9C%E5%87%BA%20-%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%7C%20--%20flatbuffers%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%3CA%20href%3D%22http%3A%2F%2Flocalhost%3A8080%2F7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttp%3A%2F%2Flocalhost%3A8080%2F7d6d99c6befa635780a4e944d37ebfd58e68a108.tar.gz%3C%2FA%3E%E3%81%8B%E3%82%89%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2F..%2Fthird_party%2Fflatbuffers%2Fworkspace.bzl%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20--%20flatbuffers%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%207d6d99c6befa635780a4e944d37ebfd58e68a108%20%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2F..%2Fthird_party%2Fflatbuffers%2Fworkspace.bzl%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7C%20--%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2023.5.26.0%20%E3%81%A7%E7%B6%9A%E8%A1%8C%3CBR%20%2F%3E%7C%20--%20strtof_l%20%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20--%20strtof_l%20%E3%82%92%E6%A4%9C%E7%B4%A2%20-%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20--%20strtoull_l%20%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20--%20strtoull_l%20%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20--%20%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%91%E3%82%B9%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20--%20realpath%20%E3%82%92%E6%A4%9C%E7%B4%A2%20-%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20--%20CMAKE_CXX_FLAGS%3A%20-isystem%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Finclude%20-O2%20-pipe%3CBR%20%2F%3E%20%7C%20--%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%20%E3%81%AE%3C%2FA%3E%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%7C%20%5B1%2F9%5D%20'protobuf-populate'%20%E7%94%A8%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3E%7C%20%5B1%2F9%5D%20'protobuf-populate'%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%89%8B%E9%A0%86%20(git%20clone)%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20'protobuf'%20%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%7C%20%E8%87%B4%E5%91%BD%E7%9A%84%3A%20'%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%3C%2FA%3E%20'%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20github.com%3CBR%20%2F%3E%7C%20'protobuf'%20%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%7C%20%E8%87%B4%E5%91%BD%E7%9A%84%3A%20'%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%3C%2FA%3E%20'%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20github.com%3CBR%20%2F%3E%7C%20'protobuf'%20%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%7C%20%E8%87%B4%E5%91%BD%E7%9A%84%3A%20'%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%2F%3C%2FA%3E%20'%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20github.com%3CBR%20%2F%3E%7C%20--%20git%20clone%20%E3%82%92%E8%A4%87%E6%95%B0%E5%9B%9E%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A%203%20%E5%9B%9E%E3%80%82%3CBR%20%2F%3E%7C%20_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Ftmp%2Fprotobuf-populate-gitclone.cmake%3A39%20%E3%81%A7%E3%81%AE%20CMake%20%E3%82%A8%E3%83%A9%E3%83%BC%20(%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8)%3A%3CBR%20%2F%3E%20%7C%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20'%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fprotocolbuffers%2Fprotobuf%3C%2FA%3E%20'%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%20%7C%3CBR%20%2F%3E%20%7C%20%E5%A4%B1%E6%95%97%3A%20protobuf-populate-prefix%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-download%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-download%3CBR%20%2F%3E%20%7C%20cd%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%20%26amp%3B%26amp%3B%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcmake%20-P%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Ftmp%2Fprotobuf-populate-gitclone.cmake%20%26amp%3B%26amp%3B%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fbin%2Fcmake%20-E%20touch%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fbuild%2F_deps%2Fprotobuf-subbuild%2Fprotobuf-populate-prefix%2Fsrc%2Fprotobuf-populate-stamp%2Fprotobuf-populate-download%3CBR%20%2F%3E%20%7C%20ninja%3A%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%82%B5%E3%83%96%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2FModules%2FFetchContent.cmake%3A1679%20%E3%81%A7%E3%81%AE%20CMake%20%E3%82%A8%E3%83%A9%E3%83%BC%20(%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8)%3A%3CBR%20%2F%3E%20%7C%20protobuf%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%201%3CBR%20%2F%3E%20%7C%20%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%20(%E6%9C%80%E6%96%B0%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E5%85%88%E9%A0%AD)%3A%3CBR%20%2F%3E%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2FModules%2FFetchContent.cmake%3A1819%3AEVAL%3A2%20(__FetchContent_directPopulate)%3CBR%20%2F%3E%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Frecipe-sysroot-native%2Fusr%2Fshare%2Fcmake-3.28%2FModules%2FFetchContent.cmake%3A1819%20(cmake_language)%3CBR%20%2F%3E%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2FOverridableFetchContent.cmake%3A537(FetchContent_Populate)%3CBR%20%2F%3E%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2Fprotobuf.cmake%3A37(%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84_%E3%83%9D%E3%83%94%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88)%3CBR%20%2F%3E%20%7C%20%2Fworkdir%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Ftensorflow-lite-host-tools-native%2F2.16.2%2Fgit%2Ftensorflow%2Flite%2Ftools%2Fcmake%2Fmodules%2FFindprotobuf.cmake%3A18%EF%BC%88%E5%90%AB%E3%82%80%EF%BC%89%3CBR%20%2F%3E%20%7C%20protobuf%2FCMakeLists.txt%3A34%20(%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A4%9C%E7%B4%A2)%3CBR%20%2F%3E%20%7C%3CBR%20%2F%3E%20%7C%3CBR%20%2F%3E%20%7C%20--%20%E8%A8%AD%E5%AE%9A%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7C%20%2B%20bb_sh_exit_handler%3CBR%20%2F%3E%20%7C%20%2B%20ret%3D1%3CBR%20%2F%3E%20%7C%20%2B%20%5B%201%20!%3D%200%20%5D%3CBR%20%2F%3E%20%7C%20%2B%20echo%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%7C%20%2B%20%E5%87%BA%E5%8F%A31%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(virtual%3Anative%3A%2Fworkdir%2Fsources%2Fmeta-imx%2Fmeta-imx-ml%2Frecipes-libraries%2Ftensorflow-lite%2Ftensorflow-lite-host-tools_2.16.2.bb%3Ado_configure)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%205477%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%205471%20%E4%BB%B6%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E4%BB%B6%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%83%93%E3%83%AB%E3%83%89%E5%B1%A5%E6%AD%B4%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%83%93%E3%83%AB%E3%83%89%E5%B1%A5%E6%AD%B4%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%9F%E6%99%82%E9%96%93%3A%209%E7%A7%92%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20build%20tensorflow%20on%20offline%20machine%20for%20imx8mp%20Scarthgap%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%AE%8C%E5%85%A8%E3%81%AA%20BSP%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%95%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8C%E3%81%B0%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20BSP%20%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
