configuration error - unkown item 'SYSLOG_SU_ENAB' during bitbake meta-toolchain-qt6
4,047件の閲覧回数
hansung_jung
I'm using a custom board with i.mx8qxp.
I'm trying to build a qt6 sdk image on yokto-kirkstone, but I got a configuration error.
I think the compilation is fine, but errors occurred while creating the rootfs.
Please check the attached log and let me know how I can fix it.
4 返答(返信)
4,032件の閲覧回数
Zhiming_Liu
Hi @hansung_jung
Can you share your host pc version?
You can try to grep SYSLOG_SU_ENAB in /etc folder , for example, if you find /etc/login.defs contains this config, comment out SYSLOG_SU_ENAB in this file.
4,017件の閲覧回数
hansung_jung
I am using Debian 5.10.197 on vmware.
Do you mean the /etc folder in host pc?
If so, I tried to comment out SYSLOG_SU_ENAB in /etc/login.defs, but it still has error.
If not, please let me know how I can comment out of /etc folder in sysroot for target board.
4,015件の閲覧回数
Zhiming_Liu
Hi @hansung_jung
There is no such issue on Ubuntu as the Yocto guide recommend use Ubuntu20, you can choose to use Ubuntu20.Or comment all SYSLOG_SU_ENAB under /etc  files, open a new terminal and try to build sdk again.
4,011件の閲覧回数
hansung_jung
Thanks for your reply.
Following your guide, I commented all of them(actully, only /etc/login.defs) under /etc folder.
However, there are still errors.
And I am afraid, I have to use Debian for policy.
NOTE: recipe meta-toolchain-qt6-1.0-r0: task do_populate_sdk: Started
ERROR: meta-toolchain-qt6-1.0-r0 do_populate_sdk: Unable to install packages. Command '/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/opkg-sdk-target.conf -t /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/temp/ipktemp/ -o /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --force_postinstall --prefer-arch-to-version install attr-dbg attr-dev base-files-dbg base-files-dev base-passwd-dbg base-passwd-dev bzip2-dbg bzip2-dev ca-certificates-dbg ca-certificates-dev connman-dbg connman-dev dbus-dbg dbus-dev gcc-runtime-dbg glibc-locale-dbg icu-dbg icu-dev imx-gpu-viv-dbg imx-gpu-viv-dev iptables-dbg iptables-dev libarchive-dbg libarchive-dev libasound-dbg libasound-dev libcap-dbg libcap-dev libcrypt-dbg libcrypt-dev libdrm-dbg libdrm-dev libegl-imx-dev libexpat-dbg libexpat-dev libffi-dbg libffi-dev libfontconfig-dbg libfontconfig-dev libfreetype-dbg libfreetype-dev libgal-imx-dev libgbm-imx-dev libgcc-s-dbg libgles2-imx-dev libglib-2.0-dbg libglib-2.0-dev libgmp-dbg libgmp-dev libgnutls-dbg libgnutls-dev libjpeg-dbg libjpeg-dev liblzo2-dbg liblzo2-dev libpcre-dbg libpcre-dev libpcre2-dbg libpcre2-dev libpng16-dbg libpng16-dev libqt6coap-dbg libqt6coap-dev libqt6core5compat-dbg libqt6core5compat-dev libqt6graphs-dbg libqt6graphs-dev libqt6httpserver-dbg libqt6httpserver-dev libqt6interfaceframework-dbg libqt6interfaceframework-dev libqt6location-dbg libqt6location-dev libqt6mqtt-dbg libqt6mqtt-dev libqt6networkauth-dbg libqt6networkauth-dev libqt6networksettings-dbg libqt6networksettings-dev libqt6quicktimeline-dbg libqt6quicktimeline-dev libqt6serialbus-dbg libqt6serialbus-dev libqt6serialport-dbg libqt6serialport-dev libqt6shadertools-dbg libqt6shadertools-dev libqt6texttospeech-dbg libqt6texttospeech-dev libqt6virtualkeyboard-dbg libqt6virtualkeyboard-dev libqt6websockets-dbg libqt6websockets-dev libsocketcan-dbg libsocketcan-dev libsqlite3-dev libtag-dbg libtag-dev libtiff-dbg libtiff-dev libunistring-dbg libunistring-dev libuuid-dbg libuuid-dev libwebp-dbg libwebp-dev libyaml-0-dbg libyaml-0-dev libz-dbg libz-dev nettle-dbg nettle-dev openssl-dbg openssl-dev opkg-utils-dbg packagegroup-core-standalone-sdk-target-dbg packagegroup-core-standalone-sdk-target-dev python3-antlr4-runtime-dbg python3-antlr4-runtime-dev python3-argh-dbg python3-argh-dev python3-asn1crypto-dbg python3-asn1crypto-dev python3-atomicwrites-dbg python3-atomicwrites-dev python3-attrs-dbg python3-attrs-dev python3-certifi-dbg python3-certifi-dev python3-cffi-dbg python3-cffi-dev python3-chardet-dbg python3-chardet-dev python3-click-dbg python3-click-dev python3-cryptography-dbg python3-cryptography-dev python3-dbg python3-dev python3-idna-dbg python3-idna-dev python3-importlib-metadata-dbg python3-importlib-metadata-dev python3-iniconfig-dbg python3-iniconfig-dev python3-jinja2-dbg python3-jinja2-dev python3-markupsafe-dbg python3-markupsafe-dev python3-more-itertools-dbg python3-more-itertools-dev python3-ndg-httpsclient-dbg python3-ndg-httpsclient-dev python3-packaging-dbg python3-packaging-dev python3-path-dbg python3-path-dev python3-pathlib2-dbg python3-pathlib2-dev python3-pathtools3-dbg python3-pathtools3-dev python3-pluggy-dbg python3-pluggy-dev python3-ply-dbg python3-ply-dev python3-py-dbg python3-py-dev python3-pyasn1-dbg python3-pyasn1-dev python3-pycparser-dbg python3-pycparser-dev python3-pyopenssl-dbg python3-pyopenssl-dev python3-pyparsing-dbg python3-pyparsing-dev python3-pysocks-dbg python3-pysocks-dev python3-pytest-dbg python3-pytest-dev python3-pyyaml-dbg python3-pyyaml-dev python3-qface-dbg python3-qface-dev python3-requests-dbg python3-requests-dev python3-setuptools-dbg python3-setuptools-dev python3-six-dbg python3-six-dev python3-tomli-dbg python3-tomli-dev python3-urllib3-dbg python3-urllib3-dev python3-watchdog-dbg python3-watchdog-dev python3-wcwidth-dbg python3-wcwidth-dev python3-zipp-dbg python3-zipp-dev qt3d-dbg qt3d-dev qtapplicationmanager-dbg qtapplicationmanager-dev qtbase-dbg qtbase-dev qtcharts-dbg qtcharts-dev qtconnectivity-dbg qtconnectivity-dev qtdatavis3d-dbg qtdatavis3d-dev qtdeclarative-dbg qtdeclarative-dev qtgrpc-dbg qtgrpc-dev qtimageformats-dbg qtimageformats-dev qtlanguageserver-dbg qtlanguageserver-dev qtmultimedia-dbg qtmultimedia-dev qtopcua-dbg qtopcua-dev qtpositioning-dbg qtpositioning-dev qtquick3d-dbg qtquick3d-dev qtquick3dphysics-dbg qtquick3dphysics-dev qtquickdesigner-components-dbg qtquickdesigner-components-dev qtremoteobjects-dbg qtremoteobjects-dev qtscxml-dbg qtscxml-dev qtsensors-dbg qtsensors-dev qtsvg-dbg qtsvg-dev qttools-dbg qttools-dev qttranslations-dev qtwayland-dbg qtwayland-dev qtwebchannel-dbg qtwebchannel-dev shadow-dbg shadow-dev shadow-securetty-dbg shadow-securetty-dev sqlite3-dbg systemd-dbg systemd-dev target-sdk-provides-dummy-dbg target-sdk-provides-dummy-dev util-linux-dbg util-linux-dev wayland-dbg wayland-dev xz-dbg xz-dev zstd-dbg zstd-dev' returned 255:
attr-dbg: unsatisfied recommendation for libattr-dbg
Installing attr-dbg (2.5.1) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/attr-dbg_2.5.1-r0_armv8a.ipk.
attr-dev: unsatisfied recommendation for libattr-dev
attr-dev: unsatisfied recommendation for update-alternatives-opkg-dev
Installing attr (2.5.1) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/attr_2.5.1-r0_armv8a.ipk.
Installing attr-dev (2.5.1) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/attr-dev_2.5.1-r0_armv8a.ipk.
Installing base-files-dbg (3.0.14) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/fs30imx8/base-files-dbg_3.0.14-r89_fs30imx8.ipk.
Installing base-files-dev (3.0.14) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/fs30imx8/base-files-dev_3.0.14-r89_fs30imx8.ipk.
Installing base-passwd-dbg (3.5.29) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/base-passwd-dbg_3.5.29-r0_armv8a.ipk.
Installing base-passwd-dev (3.5.29) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/base-passwd-dev_3.5.29-r0_armv8a.ipk.
bzip2-dbg: unsatisfied recommendation for libbz2-dbg
Installing bzip2-dbg (1.0.8) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/bzip2-dbg_1.0.8-r0_armv8a.ipk.
bzip2-dev: unsatisfied recommendation for libbz2-dev
bzip2-dev: unsatisfied recommendation for update-alternatives-opkg-dev
Installing bzip2 (1.0.8) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/bzip2_1.0.8-r0_armv8a.ipk.
Installing bzip2-dev (1.0.8) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/bzip2-dev_1.0.8-r0_armv8a.ipk.
Installing ca-certificates-dbg (20211016) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/all/ca-certificates-dbg_20211016-r0_all.ipk.
ca-certificates-dev: unsatisfied recommendation for openssl-bin-dev
openssl-dev: unsatisfied recommendation for libcrypto-dev
openssl-dev: unsatisfied recommendation for libssl-dev
openssl-dev: unsatisfied recommendation for openssl-conf-dev
Installing openssl-dev (3.0.13) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/openssl-dev_3.0.13-r0_armv8a.ipk.
Installing ca-certificates-dev (20211016) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/all/ca-certificates-dev_20211016-r0_all.ipk.
dbus-dbg: unsatisfied recommendation for dbus-lib-dbg
dbus-dbg: unsatisfied recommendation for libsystemd-dbg
connman-dbg: unsatisfied recommendation for dbus-lib-dbg
libpcre-dbg: unsatisfied recommendation for libpcreposix-dbg
libpcre-dbg: unsatisfied recommendation for libstdc++-dbg
libglib-2.0-dbg: unsatisfied recommendation for util-linux-libmount-dbg
libgmp-dbg: unsatisfied recommendation for libstdc++-dbg
libgnutls-dbg: unsatisfied recommendation for libstdc++-dbg
libreadline-dbg: unsatisfied recommendation for ncurses-libtinfo-dbg
Installing dbus-dbg (1.14.8) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/dbus-dbg_1.14.8-r0_armv8a.ipk.
Installing libexpat-dbg (2.5.0) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libexpat-dbg_2.5.0-r0_armv8a.ipk.
Installing libglib-2.0-dbg (2.72.3) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libglib-2.0-dbg_2.72.3-r0_armv8a.ipk.
Installing libffi-dbg (3.4.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libffi-dbg_3.4.4-r0_armv8a.ipk.
Installing libpcre-dbg (8.45) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libpcre-dbg_8.45-r0_armv8a.ipk.
Installing libgcc-s-dbg (11.4.0) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libgcc-s-dbg_11.4.0-r0_armv8a.ipk.
Installing libz-dbg (1.2.11) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libz-dbg_1.2.11-r0_armv8a.ipk.
Installing libgnutls-dbg (3.7.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libgnutls-dbg_3.7.4-r0_armv8a.ipk.
Installing libgmp-dbg (6.2.1) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libgmp-dbg_6.2.1-r0_armv8a.ipk.
Installing libunistring-dbg (1.0) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libunistring-dbg_1.0-r0_armv8a.ipk.
Installing nettle-dbg (3.7.3) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/nettle-dbg_3.7.3-r0_armv8a.ipk.
Installing iptables-dbg (1.8.7) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/iptables-dbg_1.8.7-r0_armv8a.ipk.
Installing libreadline-dbg (8.1.2) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libreadline-dbg_8.1.2-r0_armv8a.ipk.
Installing connman-dbg (1.41) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/connman-dbg_1.41-r0_armv8a.ipk.
dbus-dev: unsatisfied recommendation for autoconf-archive-dev
dbus-dev: unsatisfied recommendation for dbus-common-dev
dbus-dev: unsatisfied recommendation for dbus-lib-dev
dbus-dev: unsatisfied recommendation for dbus-tools-dev
libpcre-dev: unsatisfied recommendation for libpcrecpp-dev
libpcre-dev: unsatisfied recommendation for libpcreposix-dev
python3-dev: unsatisfied recommendation for ldconfig-dev
python3-dev: unsatisfied recommendation for libbz2-dev
python3-dev: unsatisfied recommendation for libcrypto-dev
python3-dev: unsatisfied recommendation for liblzma-dev
python3-dev: unsatisfied recommendation for libpython3-dev
python3-dev: unsatisfied recommendation for libssl-dev
package libtinfo5 suggests installing ncurses-terminfo
ncurses-dev: unsatisfied recommendation for ncurses-libform-dev
ncurses-dev: unsatisfied recommendation for ncurses-libformw-dev
ncurses-dev: unsatisfied recommendation for ncurses-libmenu-dev
ncurses-dev: unsatisfied recommendation for ncurses-libmenuw-dev
ncurses-dev: unsatisfied recommendation for ncurses-libncurses-dev
ncurses-dev: unsatisfied recommendation for ncurses-libncursesw-dev
ncurses-dev: unsatisfied recommendation for ncurses-libpanel-dev
ncurses-dev: unsatisfied recommendation for ncurses-libpanelw-dev
ncurses-dev: unsatisfied recommendation for ncurses-libtic-dev
ncurses-dev: unsatisfied recommendation for ncurses-libticw-dev
ncurses-dev: unsatisfied recommendation for ncurses-libtinfo-dev
ncurses-dev: unsatisfied recommendation for ncurses-terminfo-base-dev
ncurses-dev: unsatisfied recommendation for update-alternatives-opkg-dev
python3-dev: unsatisfied recommendation for ncurses-libncursesw-dev
python3-dev: unsatisfied recommendation for ncurses-libpanelw-dev
python3-dev: unsatisfied recommendation for ncurses-libtinfo-dev
python3-dev: unsatisfied recommendation for python3-2to3-dev
python3-dev: unsatisfied recommendation for python3-asyncio-dev
python3-dev: unsatisfied recommendation for python3-audio-dev
python3-dev: unsatisfied recommendation for python3-codecs-dev
python3-dev: unsatisfied recommendation for python3-compile-dev
python3-dev: unsatisfied recommendation for python3-compression-dev
python3-dev: unsatisfied recommendation for python3-core-dev
python3-dev: unsatisfied recommendation for python3-crypt-dev
python3-dev: unsatisfied recommendation for python3-ctypes-dev
python3-dev: unsatisfied recommendation for python3-curses-dev
python3-dev: unsatisfied recommendation for python3-datetime-dev
python3-dev: unsatisfied recommendation for python3-db-dev
python3-dev: unsatisfied recommendation for python3-debugger-dev
python3-dev: unsatisfied recommendation for python3-difflib-dev
python3-dev: unsatisfied recommendation for python3-distutils-dev
python3-dev: unsatisfied recommendation for python3-doctest-dev
python3-dev: unsatisfied recommendation for python3-email-dev
python3-dev: unsatisfied recommendation for python3-fcntl-dev
python3-dev: unsatisfied recommendation for python3-html-dev
python3-dev: unsatisfied recommendation for python3-idle-dev
python3-dev: unsatisfied recommendation for python3-image-dev
python3-dev: unsatisfied recommendation for python3-io-dev
python3-dev: unsatisfied recommendation for python3-json-dev
python3-dev: unsatisfied recommendation for python3-logging-dev
python3-dev: unsatisfied recommendation for python3-mailbox-dev
python3-dev: unsatisfied recommendation for python3-math-dev
python3-dev: unsatisfied recommendation for python3-mime-dev
python3-dev: unsatisfied recommendation for python3-misc-dev
python3-dev: unsatisfied recommendation for python3-mmap-dev
python3-dev: unsatisfied recommendation for python3-modules-dev
python3-dev: unsatisfied recommendation for python3-multiprocessing-dev
python3-dev: unsatisfied recommendation for python3-netclient-dev
python3-dev: unsatisfied recommendation for python3-netserver-dev
python3-dev: unsatisfied recommendation for python3-numbers-dev
python3-dev: unsatisfied recommendation for python3-pickle-dev
python3-dev: unsatisfied recommendation for python3-pkgutil-dev
python3-dev: unsatisfied recommendation for python3-plistlib-dev
python3-dev: unsatisfied recommendation for python3-pprint-dev
python3-dev: unsatisfied recommendation for python3-profile-dev
python3-dev: unsatisfied recommendation for python3-pydoc-dev
python3-dev: unsatisfied recommendation for python3-resource-dev
python3-dev: unsatisfied recommendation for python3-shell-dev
python3-dev: unsatisfied recommendation for python3-smtpd-dev
python3-dev: unsatisfied recommendation for python3-sqlite3-dev
python3-dev: unsatisfied recommendation for python3-statistics-dev
python3-dev: unsatisfied recommendation for python3-stringold-dev
python3-dev: unsatisfied recommendation for python3-syslog-dev
python3-dev: unsatisfied recommendation for python3-terminal-dev
python3-dev: unsatisfied recommendation for python3-threading-dev
python3-dev: unsatisfied recommendation for python3-tkinter-dev
python3-dev: unsatisfied recommendation for python3-unittest-dev
python3-dev: unsatisfied recommendation for python3-unixadmin-dev
python3-dev: unsatisfied recommendation for python3-venv-dev
python3-dev: unsatisfied recommendation for python3-xml-dev
python3-dev: unsatisfied recommendation for python3-xmlrpc-dev
python3-dev: unsatisfied recommendation for sqlite3-dev
python3-dev: unsatisfied recommendation for update-alternatives-opkg-dev
xz-dev: unsatisfied recommendation for liblzma-dev
xz-dev: unsatisfied recommendation for update-alternatives-opkg-dev
libglib-2.0-dev: unsatisfied recommendation for python3-distutils-dev
libglib-2.0-dev: unsatisfied recommendation for python3-xml-dev
util-linux-dev: unsatisfied recommendation for ncurses-libncursesw-dev
util-linux-dev: unsatisfied recommendation for ncurses-libtinfo-dev
util-linux-dev: unsatisfied recommendation for update-alternatives-opkg-dev
util-linux-dev: unsatisfied recommendation for util-linux-libfdisk-dev
util-linux-dev: unsatisfied recommendation for util-linux-libsmartcols-dev
util-linux-dev: unsatisfied recommendation for util-linux-lsblk-dev
util-linux-dev: unsatisfied recommendation for util-linux-swapoff-dev
util-linux-dev: unsatisfied recommendation for util-linux-swapon-dev
dbus-dev: unsatisfied recommendation for libsystemd-dev
shadow-dev: unsatisfied recommendation for libattr-dev
shadow-dev: unsatisfied recommendation for shadow-base-dev
shadow-dev: unsatisfied recommendation for update-alternatives-opkg-dev
shadow-dev: unsatisfied recommendation for util-linux-sulogin-dev
dbus-dev: unsatisfied recommendation for shadow-sysroot-dev
systemd: unsatisfied recommendation for kernel-module-autofs4
systemd: unsatisfied recommendation for kernel-module-ipv6
systemd: unsatisfied recommendation for kernel-module-sch-fq-codel
systemd: unsatisfied recommendation for kernel-module-unix
kmod-dev: unsatisfied recommendation for libkmod-dev
kmod-dev: unsatisfied recommendation for liblzma-dev
kmod-dev: unsatisfied recommendation for update-alternatives-opkg-dev
systemd-dev: unsatisfied recommendation for ldconfig-dev
systemd-dev: unsatisfied recommendation for libkmod-dev
systemd-dev: unsatisfied recommendation for liblzma-dev
systemd-dev: unsatisfied recommendation for libnss-myhostname-dev
systemd-dev: unsatisfied recommendation for libsystemd-dev
systemd-dev: unsatisfied recommendation for libsystemd-shared-dev
libtss2-dev: unsatisfied recommendation for libcrypto-dev
libtss2-mu-dev: unsatisfied recommendation for shadow-sysroot-dev
libtss2-dev: unsatisfied recommendation for shadow-sysroot-dev
libtss2-tcti-device-dev: unsatisfied recommendation for shadow-sysroot-dev
systemd-dev: unsatisfied recommendation for libudev-dev
systemd-dev: unsatisfied recommendation for libzstd-dev
systemd-dev: unsatisfied recommendation for shadow-sysroot-dev
systemd-dev: unsatisfied recommendation for systemd-udev-rules-dev
systemd-dev: unsatisfied recommendation for systemd-vconsole-setup-dev
systemd-dev: unsatisfied recommendation for tpm2-tss-dev
systemd-dev: unsatisfied recommendation for udev-dev
systemd-dev: unsatisfied recommendation for update-alternatives-opkg-dev
systemd-dev: unsatisfied recommendation for util-linux-agetty-dev
systemd-dev: unsatisfied recommendation for util-linux-fsck-dev
systemd-dev: unsatisfied recommendation for util-linux-mount-dev
systemd-dev: unsatisfied recommendation for util-linux-umount-dev
zstd-dev: unsatisfied recommendation for libzstd-dev
connman-dev: unsatisfied recommendation for dbus-lib-dev
libgmp-dev: unsatisfied recommendation for libgmpxx-dev
libgnutls-dev: unsatisfied recommendation for gnutls-openssl-dev
libgnutls-dev: unsatisfied recommendation for gnutls-xx-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-ah-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-dnat-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-dnpt-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-dst-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-eui64-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-frag-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-hbh-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-hl-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-icmp6-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-ipv6header-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-log-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-masquerade-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-mh-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-netmap-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-redirect-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-reject-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-rt-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-snat-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-snpt-dev
iptables-dev: unsatisfied recommendation for iptables-module-ip6t-srh-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-ah-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-clusterip-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-dnat-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-ecn-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-icmp-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-log-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-masquerade-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-netmap-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-realm-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-redirect-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-reject-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-snat-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-ttl-dev
iptables-dev: unsatisfied recommendation for iptables-module-ipt-ulog-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-addrtype-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-audit-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-bpf-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-cgroup-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-checksum-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-classify-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-cluster-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-comment-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-connbytes-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-connlimit-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-connmark-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-connsecmark-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-conntrack-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-cpu-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-ct-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-dccp-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-devgroup-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-dscp-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-ecn-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-esp-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-hashlimit-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-helper-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-hmark-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-idletimer-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-ipcomp-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-iprange-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-ipvs-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-led-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-length-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-limit-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-mac-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-mark-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-multiport-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-nfacct-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-nflog-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-nfqueue-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-osf-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-owner-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-physdev-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-pkttype-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-policy-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-quota-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-rateest-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-recent-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-rpfilter-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-sctp-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-secmark-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-set-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-socket-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-standard-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-statistic-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-string-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-synproxy-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-tcp-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-tcpmss-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-tcpoptstrip-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-tee-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-time-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-tos-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-tproxy-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-trace-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-u32-dev
iptables-dev: unsatisfied recommendation for iptables-module-xt-udp-dev
ppp-dev: unsatisfied recommendation for libcrypto-dev
ppp-dev: unsatisfied recommendation for libssl-dev
libreadline-dev: unsatisfied recommendation for ncurses-libtinfo-dev
libreadline-dev: unsatisfied recommendation for update-alternatives-opkg-dev
connman-dev: unsatisfied recommendation for update-alternatives-opkg-dev
Installing dbus-dev (1.14.8) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/dbus-dev_1.14.8-r0_armv8a.ipk.
Installing libexpat-dev (2.5.0) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libexpat-dev_2.5.0-r0_armv8a.ipk.
Installing libglib-2.0-dev (2.72.3) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libglib-2.0-dev_2.72.3-r0_armv8a.ipk.
Installing bash-completion (2.11) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/bash-completion_2.11-r0_armv8a.ipk.
Installing bash-completion-dev (2.11) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/bash-completion-dev_2.11-r0_armv8a.ipk.
Installing libffi-dev (3.4.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libffi-dev_3.4.4-r0_armv8a.ipk.
Installing libpcrecpp0 (8.45) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libpcrecpp0_8.45-r0_armv8a.ipk.
Installing libpcreposix0 (8.45) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libpcreposix0_8.45-r0_armv8a.ipk.
Installing libpcre-dev (8.45) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libpcre-dev_8.45-r0_armv8a.ipk.
Installing libz-dev (1.2.11) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libz-dev_1.2.11-r0_armv8a.ipk.
Installing python3-distutils (3.10.13) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/python3-distutils_3.10.13-r0_armv8a.ipk.
Installing python3-dev (3.10.13) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/python3-dev_3.10.13-r0_armv8a.ipk.
Installing libtirpc3 (1.3.2) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libtirpc3_1.3.2-r0_armv8a.ipk.
Installing libnsl3 (2.0.0) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libnsl3_2.0.0-r0_armv8a.ipk.
Installing libtirpc-dev (1.3.2) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libtirpc-dev_1.3.2-r0_armv8a.ipk.
Installing libnsl-dev (2.0.0) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libnsl-dev_2.0.0-r0_armv8a.ipk.
Installing libsqlite3-dev (3.38.5) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libsqlite3-dev_3.38.5-r0_armv8a.ipk.
Installing libcrypt-dev (4.4.33) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libcrypt-dev_4.4.33-r0_armv8a.ipk.
Installing libtinfo5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libtinfo5_6.3+20220423-r0_armv8a.ipk.
Installing ncurses (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/ncurses_6.3+20220423-r0_armv8a.ipk.
Installing libncurses5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libncurses5_6.3+20220423-r0_armv8a.ipk.
Installing libform5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libform5_6.3+20220423-r0_armv8a.ipk.
Installing libncursesw5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libncursesw5_6.3+20220423-r0_armv8a.ipk.
Installing libformw5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libformw5_6.3+20220423-r0_armv8a.ipk.
Installing libmenu5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libmenu5_6.3+20220423-r0_armv8a.ipk.
Installing libmenuw5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libmenuw5_6.3+20220423-r0_armv8a.ipk.
Installing libpanel5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libpanel5_6.3+20220423-r0_armv8a.ipk.
Installing libpanelw5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libpanelw5_6.3+20220423-r0_armv8a.ipk.
Installing libtic5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libtic5_6.3+20220423-r0_armv8a.ipk.
Installing libticw5 (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libticw5_6.3+20220423-r0_armv8a.ipk.
Installing ncurses-dev (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/ncurses-dev_6.3+20220423-r0_armv8a.ipk.
Installing ncurses-terminfo-base (6.3+20220423) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/ncurses-terminfo-base_6.3+20220423-r0_armv8a.ipk.
Installing libuuid-dev (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libuuid-dev_2.37.4-r0_armv8a.ipk.
Installing xz (5.2.6) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/xz_5.2.6-r0_armv8a.ipk.
Installing xz-dev (5.2.6) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/xz-dev_5.2.6-r0_armv8a.ipk.
Installing util-linux (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux_2.37.4-r0_armv8a.ipk.
Installing libfdisk1 (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libfdisk1_2.37.4-r0_armv8a.ipk.
Installing libsmartcols1 (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libsmartcols1_2.37.4-r0_armv8a.ipk.
Installing util-linux-dev (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-dev_2.37.4-r0_armv8a.ipk.
Installing util-linux-addpart (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-addpart_2.37.4-r0_armv8a.ipk.
Installing util-linux-agetty (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-agetty_2.37.4-r0_armv8a.ipk.
Installing util-linux-blkdiscard (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-blkdiscard_2.37.4-r0_armv8a.ipk.
Installing util-linux-blkid (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-blkid_2.37.4-r0_armv8a.ipk.
Installing util-linux-blkzone (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-blkzone_2.37.4-r0_armv8a.ipk.
Installing util-linux-blockdev (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-blockdev_2.37.4-r0_armv8a.ipk.
Installing util-linux-cal (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-cal_2.37.4-r0_armv8a.ipk.
Installing util-linux-cfdisk (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-cfdisk_2.37.4-r0_armv8a.ipk.
Installing util-linux-chcpu (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-chcpu_2.37.4-r0_armv8a.ipk.
Installing util-linux-chmem (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-chmem_2.37.4-r0_armv8a.ipk.
Installing util-linux-choom (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-choom_2.37.4-r0_armv8a.ipk.
Installing util-linux-chrt (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-chrt_2.37.4-r0_armv8a.ipk.
Installing util-linux-col (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-col_2.37.4-r0_armv8a.ipk.
Installing util-linux-colcrt (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-colcrt_2.37.4-r0_armv8a.ipk.
Installing util-linux-colrm (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-colrm_2.37.4-r0_armv8a.ipk.
Installing util-linux-column (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-column_2.37.4-r0_armv8a.ipk.
Installing util-linux-ctrlaltdel (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ctrlaltdel_2.37.4-r0_armv8a.ipk.
Installing util-linux-delpart (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-delpart_2.37.4-r0_armv8a.ipk.
Installing util-linux-dmesg (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-dmesg_2.37.4-r0_armv8a.ipk.
Installing util-linux-eject (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-eject_2.37.4-r0_armv8a.ipk.
Installing util-linux-fallocate (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fallocate_2.37.4-r0_armv8a.ipk.
Installing util-linux-fdisk (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fdisk_2.37.4-r0_armv8a.ipk.
Installing util-linux-fincore (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fincore_2.37.4-r0_armv8a.ipk.
Installing util-linux-findfs (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-findfs_2.37.4-r0_armv8a.ipk.
Installing util-linux-findmnt (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-findmnt_2.37.4-r0_armv8a.ipk.
Installing util-linux-flock (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-flock_2.37.4-r0_armv8a.ipk.
Installing util-linux-fsck (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fsck_2.37.4-r0_armv8a.ipk.
Installing util-linux-fsck.cramfs (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fsck.cramfs_2.37.4-r0_armv8a.ipk.
Installing util-linux-fsfreeze (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fsfreeze_2.37.4-r0_armv8a.ipk.
Installing util-linux-fstrim (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-fstrim_2.37.4-r0_armv8a.ipk.
Installing util-linux-getopt (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-getopt_2.37.4-r0_armv8a.ipk.
Installing util-linux-hardlink (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-hardlink_2.37.4-r0_armv8a.ipk.
Installing util-linux-hexdump (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-hexdump_2.37.4-r0_armv8a.ipk.
Installing util-linux-hwclock (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-hwclock_2.37.4-r0_armv8a.ipk.
Installing util-linux-ionice (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ionice_2.37.4-r0_armv8a.ipk.
Installing util-linux-ipcmk (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ipcmk_2.37.4-r0_armv8a.ipk.
Installing util-linux-ipcrm (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ipcrm_2.37.4-r0_armv8a.ipk.
Installing util-linux-ipcs (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ipcs_2.37.4-r0_armv8a.ipk.
Installing util-linux-irqtop (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-irqtop_2.37.4-r0_armv8a.ipk.
Installing util-linux-isosize (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-isosize_2.37.4-r0_armv8a.ipk.
Installing util-linux-kill (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-kill_2.37.4-r0_armv8a.ipk.
Installing util-linux-last (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-last_2.37.4-r0_armv8a.ipk.
Installing util-linux-ldattach (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ldattach_2.37.4-r0_armv8a.ipk.
Installing util-linux-logger (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-logger_2.37.4-r0_armv8a.ipk.
Installing util-linux-look (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-look_2.37.4-r0_armv8a.ipk.
Installing util-linux-losetup (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-losetup_2.37.4-r0_armv8a.ipk.
Installing util-linux-lsblk (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lsblk_2.37.4-r0_armv8a.ipk.
Installing util-linux-lscpu (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lscpu_2.37.4-r0_armv8a.ipk.
Installing util-linux-lsipc (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lsipc_2.37.4-r0_armv8a.ipk.
Installing util-linux-lsirq (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lsirq_2.37.4-r0_armv8a.ipk.
Installing util-linux-lslocks (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lslocks_2.37.4-r0_armv8a.ipk.
Installing util-linux-lslogins (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lslogins_2.37.4-r0_armv8a.ipk.
Installing util-linux-lsmem (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lsmem_2.37.4-r0_armv8a.ipk.
Installing util-linux-lsns (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-lsns_2.37.4-r0_armv8a.ipk.
Installing util-linux-mcookie (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mcookie_2.37.4-r0_armv8a.ipk.
Installing util-linux-mesg (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mesg_2.37.4-r0_armv8a.ipk.
Installing util-linux-mkfs (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mkfs_2.37.4-r0_armv8a.ipk.
Installing util-linux-mkfs.cramfs (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mkfs.cramfs_2.37.4-r0_armv8a.ipk.
Installing util-linux-mkswap (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mkswap_2.37.4-r0_armv8a.ipk.
Installing util-linux-more (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-more_2.37.4-r0_armv8a.ipk.
Installing util-linux-mount (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mount_2.37.4-r0_armv8a.ipk.
Installing util-linux-mountpoint (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-mountpoint_2.37.4-r0_armv8a.ipk.
Installing util-linux-namei (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-namei_2.37.4-r0_armv8a.ipk.
Installing util-linux-nologin (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-nologin_2.37.4-r0_armv8a.ipk.
Installing util-linux-nsenter (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-nsenter_2.37.4-r0_armv8a.ipk.
Installing util-linux-partx (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-partx_2.37.4-r0_armv8a.ipk.
Installing util-linux-pivot-root (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-pivot-root_2.37.4-r0_armv8a.ipk.
Installing util-linux-prlimit (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-prlimit_2.37.4-r0_armv8a.ipk.
Installing util-linux-readprofile (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-readprofile_2.37.4-r0_armv8a.ipk.
Installing util-linux-rename (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-rename_2.37.4-r0_armv8a.ipk.
Installing util-linux-renice (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-renice_2.37.4-r0_armv8a.ipk.
Installing util-linux-resizepart (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-resizepart_2.37.4-r0_armv8a.ipk.
Installing util-linux-rev (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-rev_2.37.4-r0_armv8a.ipk.
Installing util-linux-rfkill (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-rfkill_2.37.4-r0_armv8a.ipk.
Installing util-linux-rtcwake (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-rtcwake_2.37.4-r0_armv8a.ipk.
Installing util-linux-script (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-script_2.37.4-r0_armv8a.ipk.
Installing util-linux-scriptlive (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-scriptlive_2.37.4-r0_armv8a.ipk.
Installing util-linux-scriptreplay (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-scriptreplay_2.37.4-r0_armv8a.ipk.
Installing util-linux-setarch (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-setarch_2.37.4-r0_armv8a.ipk.
Installing libcap-ng (0.8.2) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/libcap-ng_0.8.2-r0_armv8a.ipk.
Installing util-linux-setpriv (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-setpriv_2.37.4-r0_armv8a.ipk.
Installing util-linux-setsid (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-setsid_2.37.4-r0_armv8a.ipk.
Installing util-linux-setterm (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-setterm_2.37.4-r0_armv8a.ipk.
Installing util-linux-sfdisk (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-sfdisk_2.37.4-r0_armv8a.ipk.
Installing util-linux-swaplabel (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-swaplabel_2.37.4-r0_armv8a.ipk.
Installing util-linux-swapoff (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-swapoff_2.37.4-r0_armv8a.ipk.
Installing util-linux-swapon (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-swapon_2.37.4-r0_armv8a.ipk.
Installing util-linux-switch-root (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-switch-root_2.37.4-r0_armv8a.ipk.
Installing util-linux-taskset (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-taskset_2.37.4-r0_armv8a.ipk.
Installing util-linux-uclampset (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-uclampset_2.37.4-r0_armv8a.ipk.
Installing util-linux-ul (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-ul_2.37.4-r0_armv8a.ipk.
Installing util-linux-umount (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-umount_2.37.4-r0_armv8a.ipk.
Installing util-linux-unshare (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-unshare_2.37.4-r0_armv8a.ipk.
Installing util-linux-utmpdump (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-utmpdump_2.37.4-r0_armv8a.ipk.
Installing util-linux-uuidd (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-uuidd_2.37.4-r0_armv8a.ipk.
Installing util-linux-uuidgen (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-uuidgen_2.37.4-r0_armv8a.ipk.
Installing util-linux-uuidparse (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-uuidparse_2.37.4-r0_armv8a.ipk.
Installing util-linux-wall (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-wall_2.37.4-r0_armv8a.ipk.
Installing util-linux-wdctl (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-wdctl_2.37.4-r0_armv8a.ipk.
Installing util-linux-whereis (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-whereis_2.37.4-r0_armv8a.ipk.
Installing util-linux-wipefs (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-wipefs_2.37.4-r0_armv8a.ipk.
Installing util-linux-write (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-write_2.37.4-r0_armv8a.ipk.
Installing util-linux-zramctl (2.37.4) on root.
Downloading file:/home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/oe-sdk-repo/armv8a/util-linux-zramctl_2.37.4-r0_armv8a.ipk.
Installing libcap-ng-dev (0.8.2) on root.
Downloading file:/home/one/projects/tool/meta-Running groupadd commands...
NOTE: tpm2-tss: Performing groupadd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --gid 508 --system tss]
configuration error - unknown item 'SYSLOG_SU_ENAB' (notify administrator)
configuration error - unknown item 'SYSLOG_SG_ENAB' (notify administrator)
Running useradd commands...
NOTE: tpm2-tss: Performing useradd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --home-dir / --gid 508 --no-create-home --system --shell /sbin/nologin --uid 508 tss]
NOTE: systemd: Performing groupadd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --gid 988 --system render]
NOTE: systemd: Performing groupadd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --gid 980 --system sgx]
NOTE: systemd: Performing groupadd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --gid 997 --system systemd-journal]
NOTE: systemd: Performing groupadd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --gid 994 systemd-resolve]
NOTE: systemd: Performing groupadd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --gid 996 systemd-timesync]
NOTE: systemd: Performing useradd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --home-dir / --gid 994 --no-create-home --system --shell /sbin/nologin --uid 996 systemd-resolve]
NOTE: systemd: Performing useradd with [--root /home/one/projects/tool/meta-fs30/build/tmp/work/armv8a-ccp-linux/meta-toolchain-qt6/1.0-r0/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/armv8a-ccp-linux --home-dir / --gid 996 --no-create-home --system --shell /sbin/nologin --uid 998 systemd-timesync]
