can imx6dl support 10-bit raw RGB csc process?
1,360 次查看
kevinhuhui
I want to use ov8858 with imx6dl. ov8858 can only support output 10-bit raw RGB image.
my question is : can imx6dl support convert 10-bit raw RGB to other color space,for exp, raw rgb --> yuv, or raw rgb --> rgb888 ?
thks.
标签 (4)
1,179 次查看
Hi kevin
in general it can, using conversion matrix described in sect.37.4.5.4
Main Processing Section i.MX6DQ Reference Manual (rev.3  7/2015)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
1,179 次查看
kevinhuhui
HI igor
     thank you for your reply.
     the 10bit raw rgb format for ov8858  is BG/GR bayer.
     can you give me the matrix example for BG/GR to yuv conversion?
1,179 次查看
Hi kevin
one can look at csc examples below and modify for own needs, if necessary
https://community.freescale.com/docs/DOC-94961
~igor
