building QtWebEngine in IMX6qp yocto platform
lavakumars
hi,
I am trying to build QtWebEngine allong with Qt5.7.0.
Now i am able to build the Qt5.7 and all its dependencies but when i try to build the QtWebEngine following error is coming
ERROR: "| /home/pase/freescale/fsl-release-ivi/build-xwayland/tmp/sysroots/i686-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: fatal error: libQt5WebEngineCore.so.5.7.0: mmap: failed to allocate 2029845748 bytes for output file: Cannot allocate memory"
Also check the below log and snapshots.
Please check and suggest me the workaround for building the QtWebEngine on the imx platform.
Please help its urgent.
Lavakumar S
Original Attachment has been moved to: log.do_compile.24188.zip
Original Attachment has been moved to: log.do_compile.zip
woutervh
I have the exact same issue. Were you able to solve it?
lavakumars
Not yet resolved for me.:(
