bitbake create linux problem
3,353件の閲覧回数
jizengchao19860
ERROR: u-boot-fw-utils-2016.03-r0 do_fetch: Fetcher failure: Unable to find revision 4b094406a0c17db99552ed3631000b9bfd8fee65 in branch myd-y6ulx-hmi even from upstream
ERROR: u-boot-fw-utils-2016.03-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://///home/vmuser/MYiR-iMX-Uboot;protocol=file;branch=myd-y6ulx-hmi'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/vmuser/MYS6ULx-devel/04-Sources/fsl-release-yocto/build/tmp/work/mys6ul14x14-poky-linux-gnueabi/u-boot-fw-utils/2016.03-r0/temp/log.do_fetch.34196
ERROR: Task 400 (/home/vmuser/MYS6ULx-devel/04-Sources/fsl-release-yocto/sources/poky/meta/recipes-bsp/u-boot/u-boot-fw-utils_2016.03.bb, do_fetch) failed with exit code '1'
タグ(1)
3 返答(返信)
3,226件の閲覧回数
jizengchao19860
Hi Rita Wang,
                  My BSP version is 4.1.15. Thanks for your help.
3,226件の閲覧回数
Rita_Wang
You can try to refer to this thread https://community.nxp.com/docs/DOC-346089 , it will do help for you.
3,226件の閲覧回数
Rita_Wang
Which version BSP are you using?
