android 12 boot loop on i.MX8M Plus
3,677 次查看
2744194
I compiled android 12.1.0_1.0.0 from scratch on ubuntu 18. I used these commands :
source build/envsetup.sh
lunch evk_8mp-userdebug
./imx-make.sh -j4 2>&1 | tee build-log.txt
compilation is successful. I used this command for flashing :
sudo ./uuu_imx_android_flash.sh -f imx8mp -D /home/user/Desktop/evk_8mp
flashing is successful also. but android does not boot. I think it crashes everytime and start again. I added boot log. Could you please help on this ?
6 回复数
3,653 次查看
Bio_TICFSL
You might check the boot switches, and try to erase and burn again you sd, if this does not work try to use the default demo image to see if this work.
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
3,651 次查看
2744194
Hello @Bio_TICFSL
Thanks for your reply.
I checked demo images and they are working. I am using emmc not sd. I set boot switches as 0001 for flashing images and 0010 for booting android from emmc. I cannot understand what is wrong ?
regards.
3,608 次查看
sow
I am also encountering similar issue with Android 13.0.0_2.0.0 (L6.1.22_2.0.0 BSP) software source code where demo images are working for imx8mq.
3,602 次查看
2744194
Hello @sow ,
could you please share your boot log ?
regards.
3,596 次查看
sow
Please find the below link where error log details has been provided.
3,594 次查看
sow
