Hai
we have a custom board same as iMX6SLEVK.
we downloaded Yocto 4.1.15 and compiled fsl-image-gui.
Then by using Mfgtools flashed compiled fsl-image-gui images to sdcard successfully.
But at the booting time it is getting stop at "cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)" without any errors.
if we use the same sdcard in iMX6SLEVK it is booting properly.
when we compare custom board & iMX6SLEVK logs "cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)" is coming in both of the logs.
for reference we attached custom board logs and iMX6SLEVK logs .
Thanks & Regards,
D.Jansirani
Original Attachment has been moved to: yocto-4.1.15-SLEVK-booting-logs.DAT.zip
Original Attachment has been moved to: yocto-4.1.15-Customboard-booting-logs.DAT.zip
