XEN Hypervisor DomU Set IP Address
1,604 次查看
cbl
Contributor V
I am running Yocto image and Android Automotive OS on XEN hypervisor.
Domain-0 Yocto image. DomU is Android Automotive OS.
After creating DomU I want to give IP to DomU. However, I want to run "xl console DomU" command and do it via Domain-0, not from Android Terminal.
But I don't know how to do it. Can you help with this?
What linux command or what XEN configuration do I need to set the IP of DomU@ from Domain-0?
1,593 次查看
cbl
Contributor V
I assigned the ip to DomU using tmux from the terminal of Domain-0 and this is how I solved the problem.
Efecan
1,590 次查看
Bio_TICFSL
Good!
