Where do I checkout android/imx source code?
5,699 次查看
XXiao1z
is there a public repo or git somewhere to track the work on android/imx5x? or we will just wait for a full release whenever freescale is ready to release?
i wish the former is true that a community can be built for android on imx5x.
标记 (1)
10 回复数
5,279 次查看
RobertDaniels
Okay, clearly I'm a newbie at git and gitweb - I found the correct URL to access the linux kernel sources clearly stated on the summary page (http://opensource.freescale.com/git?p=imx/linux-2.6-imx.git;a=summary) so for anyone else that's git illiterate:
git clone http://opensource.freescale.com/pub/scm/imx/linux-2.6-imx.git
This information was also located here: http://www.imxdev.org/wiki/index.php?title=All_Boards_Linux#Buildin...
http://www.imxdev.org/wiki/index.php?title=All_Boards_Linux#Building_Kernel_from_Freescale_Opensourc...
Robert Daniels said:
In addition to my original question - I can't seem to access this git clone.  I get the following error whenever I try to access git via http:
fatal: http://opensource.freescale.com/git/info/refs not found: did you run git update-server-info on the server?
No matter what path I try... what am I doing wrong?
What is the relationship between the code in http://opensource.freescale.com/git and the Linux kernel included in Freescale's version of LTIB?
5,277 次查看
EricNelson
Senior Contributor II
A public git repository will allow all of us working with the Android source base to be much more productive. Catching the periodic code drops from Freescale causes a lot of disruption in the work-flow downstream
Stanley Lee said:
Our android team shows positive attitude on this issue. Due to management process issue, we still have some steps to go. Anyway, thanks for your voice to push us improve our customer support work. Please keep touch. Thanks again.
5,277 次查看
RobertDaniels
5,277 次查看
RobertDaniels
5,277 次查看
BharathiSubrama
Hoping for the best. Similarly, I also hoping to see many low cost iMx boards. Many hobby and prototype project needs the low cost boards.
5,277 次查看
StanleyLee
X Xiao said:
Thanks. That's the one I am using. My point is that it should have an open android git, like the rest of the world(TI, Qualcomm,etc). FSL is still too closed as far as android devel is concerned, which means it's impossible to build a community around it. sigh.
Stanley Lee said:
Please look into this one:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX5...
X Xiao said:
I'm aware of that git tree, however it's not for Android.
thanks for the ack.
5,277 次查看
XXiao1z
thanks for the ack.
5,277 次查看
StanleyLee
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX51ANDROID&fpsp=1&tab=Design_Tools_...
thanks for the ack.
5,277 次查看
XXiao1z
thanks for the ack.
5,278 次查看
StanleyLee
Glad to hear your voice. And any further suggestion regarding how to run the forum better is welcomed. You can find what you want here:
