Where can I get the uboot source code?
5,215 次查看
xuxiang
Hi:
    I have a customer designed board just like imx6ul-14x14-evk,I wonder how to get the source code of u-boot ? I can get the bsp and design files from nxp's website,but can't found the source code of u-boot (uboot-2015-04.tar.gz).
   I know how to port kernel and drivers,but a green hand at uboot.
5,028 次查看
Rita_Wang
Take the imx-yocto-L4.14.98_2.0.0_ga BSP as an example, you can see the porting guide
5 回复数
5,028 次查看
xuxiang
5,029 次查看
Rita_Wang
5,028 次查看
xuxiang
Thanks for your help.
Follow your example,I found the    i.MX_BSP_Porting_Guide.pdf    at     fsl-yocto-L3.14.38_6ul-ga.tar.gz       finally.
5,028 次查看
Rita_Wang
Which version BSP are you using ?
5,028 次查看
xuxiang
