Where I can get source code for kd_8003_1fc9.dll
3,783 次查看
Norihiro
Senior Contributor II
Hello NXP,
We received kd_8003_1fc9.dll from Microsoft to debug our custom i.MX8MPlus board via ethernet.
This DLL works fine on i.MX8MPlus EVK, but it didn't work on our i.MX8MPlus board.
It seems to check MAC address or something information of external GbE PHY.
To check how this DLL works inside of i.MX8MPlus, could you provide source code of kd_8003_1fc9.dll?
Norihiro Michigami
AVNET
11 回复数
3,745 次查看
Norihiro
Hello Salas,
Thank you for your reply.
We already got in touch with Microsoft and they suggested us to request the source code to NXP.
Do you know which party the source code of kd_8003_1fc9.dll is belong to?
If it is written by Microsoft, we will ask them to provide the sourcec code again.
Norihiro Michigami
AVNET
3,628 次查看
Manuel_Salas
Hello @Norihiro and @george
I could confirm with internal team that actually, yes. NXP has the source code for the kd_8003_1fc9.dll, but unfortunately it can be shared for license issues.
Internal team is working to get more information about of this.
I will let you know any update.
Salas.
3,563 次查看
Manuel_Salas
It appears NXP can not share the sources of the required.
As reference the source codes are based on the examples available by installing Windows Driver Kit at this path: Program Files (x86)\Windows Kits\10\Debuggers\ddk\samples\kdnet.
Salas.
3,449 次查看
Norihiro
Hello Salas,
Our Microsoft team also got in touch with Microsoft Japan on this topic.
Microsoft Japan team worked with Microsoft U.S. and
Microsoft Japan told us that Microsoft permitted the
distribution of source code from NXP.
Could you check this comment with responsible person in NXP?
Norihiro Michigami
AVNET
3,430 次查看
Manuel_Salas
Hello @Norihiro
I asked again about of this situation but it appears that is not possible.
This is the exact answer from internal team:
"I discussed the possibility of sharing with our NXP legal this week and unfortunately it is not possible to share the source codes at this time. Microsoft provided the source codes without licenses and according to NXP rules these cannot be shared with customers."
Also, internal team told me that they are still working in it.
Salas.
2,762 次查看
Norihiro
Hello Salas,
After that, any situtaion at NXP has been changed for this request?
As I told you before Microsoft Japan told us that they permitted
NXP to distribute the source code.
I understand that supporting WoA by NXP has been moved to Pro support.
So, if customer needs to sign up the contract for pro support to get the source code,
please let me know.
Norihiro Michigami
AVNET
3,413 次查看
Norihiro
Hello Salas,
Thank you for your work on this topic.
I understood that NXP couldn't share the source code without license or license header.
Do you mean that NXP is requesting license for the source code from Microsoft?
Norihiro Michigami
AVNET
3,405 次查看
Manuel_Salas
Hello @Norihiro
I am not sure if requesting from Microsoft or doing something related to NXP licensing to be able to share the sources later.
Salas.
3,690 次查看
Manuel_Salas
Hello @Norihiro
I asked to the internal Windows team, I will let you know any update.
Salas.
3,644 次查看
george
Hello @Manuel_Salas,
I am working with @Norihiro to support a customer on this issue.
Is there an update for this issue?
George
3,751 次查看
Manuel_Salas
Hello @Norihiro
It appears you should contact to Microsoft and ask them to share that source code. Unfortunately we have not the source code for it.
Apologies any inconvenient.
Salas.
