When using 8mplus to play qtdemo, the screen occasionally flickers
3,103 次查看
Eddy1
Hi:
Recently, while testing qtdemo on 8mplus, I noticed that the screen occasionally flickers when running the qtdemo provided by NXP BSP. I have attached a video for reference. Can you please help me identify the cause?
3,027 次查看
Eddy1
Hi:
Thank you for your reply. I have updated the Weston version (V9.0.0) and Wayland-protocols (V1.22) on BSP 5.10.9, and after testing, the flickering issue is no longer present.
4 回复数
3,066 次查看
jimmychan
which board are you using? we tried on the 8mp evk and we don't see this problem.
3,062 次查看
Eddy1
Hi:
Thank you for your reply!
We are using a customized board based on the 8mpevk development board. Additionally, BSP 5.10.72 is slightly better, but the default use of NXP’s official 5.10.9 wic file results in a higher frequency of screen flickering
3,033 次查看
jimmychan
Which display/screen are you using? what is the different between your own board and the evk? Have you modify the dts file to fit your own board?
3,028 次查看
Eddy1
Hi:
