When I create a Device Tree, I get "Missing #address-cels" in the imx7s.dtsi file
270 次查看
tamotsu
Hello.
The imx7s.dtsi file is included to create the Device Tree.
A warning message appears saying "imx7s.dtsi: Missing #address-cels in interrupt provider".
imx7d.dtsi gives the warning "usbphynop2: missing or empty reg/range property".
  usbphynop2: usbphynop2 {
      compatible = "usb-nop-xceiv";
      clocks = <&clks IMX7D_USB_PHY2_CLK>;
      clock-names = "main_clk";
Why are these warnings appearing if this was made for the SABRE board?
Thank you.
246 次查看
Rita_Wang
For the warnings you can ignore it, are you met the error in your side?
247 次查看
Rita_Wang
237 次查看
tamotsu
Thank you.
I understand that the warning can be ignored.
I'm still debugging, so I haven't checked the warning part yet.
Anything without warnings is working fine.
If I have any problems debugging the warning part, I'll ask again.
Best regards.
225 次查看
Rita_Wang
You are welcome, any question contact us freely.
Wish you have a nice day
