What is the difference between A0 & B0 Silicon Revisions of IMX8QX Processor ?
5,251件の閲覧回数
rvalvekar
Hello Everyone,
I have been trying to search extensively for the difference between the Silicon Version of IMX8 Processors. I am unable to find a concrete information about this revision change.
Where would be a good place to get this information ?
Also does the Revision Change affect the bootloader, the scu-firmware and the arm trusted firmware ? Since then the revisions will also affect the flash.bin container.
Thank You for the support and information.
4,632件の閲覧回数
Hi Rohan
B0 fixed some errata and implemented various performance and design changes.
3 返答(返信)
4,633件の閲覧回数
Hi Rohan
4,632件の閲覧回数
dhty2015
Hello Igor,
Now the provided image can no longer be used directly in A0 version. What configuration should I modify if I compile it myself?
4,632件の閲覧回数
rvalvekar
Hello Igor,
Thank you for Your assistance and support.
