What document may have connection information?
2,974 次查看
erwinw
if I want to interface a particular video decoder to the i.MX53, such as the AL242, what documentation is available that explains the justification and orientation of the 16 bits from the decoder to the 20 bits of the i/MX53?
标记 (3)
2,913 次查看
Yuri
Please use i.MX53 Datasheet(s).
For example - section 4.7.7.1 (IPU Sensor Interface Signal Mapping) of
IMX53CEC, Rev. 5, 12/2012.
2,914 次查看
Yuri
2,913 次查看
erwinw
Thank you, I also found that to be section 4.7.8.1 for the i.MX534/6 or i.MX53xA datasheet. Appreciate the support
