What are available options for ISP on IMX95
877 次查看
Rathore-pioneer
I am using IMX95 EVK with ox03c10 camera setup.
I am running 3 cameras with Maxim serdes I want to scale down the video using hardware accelerator.
This is the working camera pipeline for recording a file:
gst-launch-1.0 -v -e libcamerasrc camera-name="/base/soc/bus@42000000/i2c@42530000/max96724@27/i2c-mux/i2c@0/mx95mbcam@40" src::stream-role=view-finder ! video/x-raw,format=NV16,width=1920,height=1280,framerate=30/1 ! videoconvert ! v4l2h264enc ! h264parse ! mp4mux ! filesink location=/tmp/cam0_processed.mp4
From this pipeline, I wanted to remove dependency from cpu and wanted to use only the hardware accelerator.
Please suggest the changes.
5 回复数
865 次查看
Rathore-pioneer
Are there any gst plugins available for encoding, decoding, and scaling?
846 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
This is the command advised for running multiple ox03c10 cameras.
gst-launch-1.0 imxcompositor_g2d name=comp \
> sink_0::xpos=0 sink_0::ypos=0 sink_0::width=640 sink_0::height=480 \
> sink_1::xpos=0 sink_1::ypos=480 sink_1::width=640 sink_1::height=480 \
> sink_2::xpos=640 sink_2::ypos=0 sink_2::width=640 sink_2::height=480 \
> sink_3::xpos=640 sink_3::ypos=480 sink_3::width=640 sink_3::height=480 ! \
> video/x-raw,format=BGRA ! autovideosink \
> v4l2src device=/dev/video15 ! video/x-raw,format=YUY2,framerate=30/1,width=1920,height=1280  !  comp.sink_0 \
> v4l2src device=/dev/video22 ! video/x-raw,format=YUY2,framerate=30/1,width=1920,height=1280  !  comp.sink_1 \
> v4l2src device=/dev/video28 ! video/x-raw,format=YUY2,framerate=30/1,width=1920,height=1280  !  comp.sink_2 \
> v4l2src device=/dev/video34 ! video/x-raw,format=YUY2,framerate=30/1,width=1920,height=1280  !  comp.sink_3
Make sure to use the Neo ISP library and review the GST plugins in Linux Users Guide. It advises disabling PipeWire.
systemctl --user stop pipewire ; systemctl --user mask pipewire
833 次查看
Rathore-pioneer
Currently, I connected only 3 cameras without a display.
I just need to store the camera feed in the file.
Exiting pipe line is not working for me.
Also, how will I get to know which video node is for which camera?
772 次查看
JosephAtNXP
For the plugins, I found in Release Notes the downscale, encode and decode plugins.
• imxvideoconvert_g2d: GPU2D-based video convert plugin.
• imxvideoconvert_ipu: IPU-based video convert plugin.
• imxvideoconvert_pxp: PXP-based video convert plugin.
• imxvideoconvert_ocl: OpenCL-based video convert plugin.
• autovideoconvert: select the i.MX hardware based video convert plugins or other
video convert plugins according to the input and output format.
• v4l2convert: V4L2 memory-to-memory based convert plugin.
• For imxvideoconvert_ocl, rotation is not supported currently. CSC, deinterlace,
downscale, dewarp, video crop, and color range convertion are supported.
• For v4l2convert, it is automatically registered on the platforms with ISI memory-to-
memory supported.
• v4l2h264enc: VPU-based AVC/H.264 video encoder
• v4l2h265enc: VPU-based HEVC video encoder
• v4l2jpegenc: V4L2 JPEG encoder
For the camera topology, you can use the following commands to print the topology and identify the cameras.
−media-ctl  -d /dev/media8  --print-dot > media8.dot     (in i.MX95 EVK target board)
−dot  -Tpng media0.dot  -o  media0-ap1302.png   (in ubuntu PC)
748 次查看
Rathore-pioneer
Here is the camera topology from my imx95 evk.
I can run the camera using this pipeline with libcamerasrc:
gst-launch-1.0 -e libcamerasrc camera-name="/base/soc/bus@42000000/i2c@42530000/max96724@27/i2c-mux/i2c@0/mx95mbcam@40" src::stream-role=view-finder ! video/x-raw,format=NV12,width=1920,height=1280,framerate=30/1 ! videoconvert ! v4l2h264enc ! h264parse ! mp4mux ! filesink location=/tmp/cam0_processed.mp4
How can I run my camera using v4l2src? Also, what is the plugin for scaling down the video without cropping the view to 1920*382 using a hardware accelerator?
%3CLINGO-SUB%20id%3D%22lingo-sub-2304624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX95%20%E4%B8%8A%E6%9C%89%E5%93%AA%E4%BA%9B%E5%8F%AF%E7%94%A8%E7%9A%84%20ISP%20%E9%80%89%E9%A1%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20IMX95%20EVK%20%E5%92%8C%20ox03c10%20%E6%91%84%E5%83%8F%E6%9C%BA%E8%AE%BE%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E5%99%A8%E7%BC%A9%E6%94%BE%E8%A7%86%E9%A2%91%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E6%91%84%E5%83%8F%E6%9C%BA%E8%AE%B0%E5%BD%95%E6%96%87%E4%BB%B6%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%B5%81%E6%B0%B4%E7%BA%BF%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Egst-launch-1.0-v-e%20libcamerasrc%20camera-name%3D%20%22%20%2Fbase%2Fsoc%2Fbus%20%4042000000%20%2Fi2c%20%4042530000%20%2Fmax96724%20%4027%20%2Fi2c-mux%2Fi2c%20%400%20%2Fmx95mbcam%20%4040%20%22%20src%3A%3A%20stream-role%3D%E5%8F%96%E6%99%AF%E5%99%A8%EF%BC%81video%2Fx-raw%EF%BC%8C%E6%A0%BC%E5%BC%8F%20%3D%20nv16%EF%BC%8C%E5%AE%BD%E5%BA%A6%20%3D%201920%EF%BC%8C%E9%AB%98%E5%BA%A6%20%3D%201280%EF%BC%8C%E5%B8%A7%E7%8E%87%20%3D%2030%2F1%EF%BC%81%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%EF%BC%81v4l2h264enc%EF%BC%81h264parse%EF%BC%81mp4mux%EF%BC%81filesink%20%E4%BD%8D%E7%BD%AE%3D%2Ftmp%2Fcam0_processed.mp4%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FSTRONG%3E%E4%BB%8E%E8%BF%99%E4%B8%AA%E6%B5%81%E6%B0%B4%E7%BA%BF%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E6%B6%88%E9%99%A4%E5%AF%B9%20CPU%20%E7%9A%84%E4%BE%9D%E8%B5%96%EF%BC%8C%E5%8F%AA%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%8F%90%E5%87%BA%E4%BF%AE%E6%94%B9%E6%84%8F%E8%A7%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20are%20available%20options%20for%20ISP%20on%20IMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E5%8F%AA%E8%BF%9E%E6%8E%A5%E4%BA%86%203%20%E5%8F%B0%E6%B2%A1%E6%9C%89%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%E6%91%84%E5%83%8F%E6%9C%BA%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%8F%AA%E9%9C%80%E8%A6%81%E5%9C%A8%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AD%98%E5%82%A8%E6%91%84%E5%83%8F%E5%A4%B4%E7%94%BB%E9%9D%A2%E3%80%82%3CBR%20%2F%3E%E9%80%80%E5%87%BA%E7%AE%A1%E9%81%93%E7%BA%BF%E5%AF%B9%E6%88%91%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E5%A6%82%E4%BD%95%E7%9F%A5%E9%81%93%E5%93%AA%E4%B8%AA%E8%A7%86%E9%A2%91%E8%8A%82%E7%82%B9%E6%98%AF%E5%93%AA%E4%B8%AA%E6%91%84%E5%83%8F%E6%9C%BA%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20are%20available%20options%20for%20ISP%20on%20IMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E4%BA%A7%E5%93%81%E7%9A%84%E5%85%B3%E6%B3%A8%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%91%BD%E4%BB%A4%E8%BF%90%E8%A1%8C%E5%A4%9A%E5%8F%B0%20ox03c10%20%E6%91%84%E5%83%8F%E6%9C%BA%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Egst-launch-1.0%20imxcompositor_g2d%20name%3Dcomp%20%5C%0A%26gt%3B%20sink_0%3A%3Axpos%3D0%20sink_0%3A%3Aypos%3D0%20sink_0%3A%3Awidth%3D640%20sink_0%3A%3Aheight%3D480%20%5C%0A%26gt%3B%20sink_1%3A%3Axpos%3D0%20sink_1%3A%3Aypos%3D480%20sink_1%3A%3Awidth%3D640%20sink_1%3A%3Aheight%3D480%20%5C%0A%26gt%3B%20sink_2%3A%3Axpos%3D640%20sink_2%3A%3Aypos%3D0%20sink_2%3A%3Awidth%3D640%20sink_2%3A%3Aheight%3D480%20%5C%0A%26gt%3B%20sink_3%3A%3Axpos%3D640%20sink_3%3A%3Aypos%3D480%20sink_3%3A%3Awidth%3D640%20sink_3%3A%3Aheight%3D480%20!%20%5C%0A%26gt%3B%20video%2Fx-raw%2Cformat%3DBGRA%20!%20autovideosink%20%5C%0A%26gt%3B%20v4l2src%20device%3D%2Fdev%2Fvideo15%20!%20video%2Fx-raw%2Cformat%3DYUY2%2Cframerate%3D30%2F1%2Cwidth%3D1920%2Cheight%3D1280%20%20!%20%20comp.sink_0%20%5C%0A%26gt%3B%20v4l2src%20device%3D%2Fdev%2Fvideo22%20!%20video%2Fx-raw%2Cformat%3DYUY2%2Cframerate%3D30%2F1%2Cwidth%3D1920%2Cheight%3D1280%20%20!%20%20comp.sink_1%20%5C%0A%26gt%3B%20v4l2src%20device%3D%2Fdev%2Fvideo28%20!%20video%2Fx-raw%2Cformat%3DYUY2%2Cframerate%3D30%2F1%2Cwidth%3D1920%2Cheight%3D1280%20%20!%20%20comp.sink_2%20%5C%0A%26gt%3B%20v4l2src%20device%3D%2Fdev%2Fvideo34%20!%20video%2Fx-raw%2Cformat%3DYUY2%2Cframerate%3D30%2F1%2Cwidth%3D1920%2Cheight%3D1280%20%20!%20%20comp.sink_3%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E7%A1%AE%E4%BF%9D%E4%BD%BF%E7%94%A8%20Neo%20ISP%20%E5%BA%93%EF%BC%8C%E5%B9%B6%E6%9F%A5%E7%9C%8B%E3%80%8A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUG10163.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELinux%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%8B%3C%2FA%3E%E4%B8%AD%E7%9A%84%20GST%20%E6%8F%92%E4%BB%B6%E3%80%82%E5%BB%BA%E8%AE%AE%E7%A6%81%E7%94%A8%20PipeWire%E3%80%82%3C%2FP%3E%0A%3CP%3Esystemctl%20--user%20stop%20pipewire%20%3B%20systemctl%20--user%20mask%20pipewire%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20are%20available%20options%20for%20ISP%20on%20IMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E7%94%A8%E4%BA%8E%E7%BC%96%E7%A0%81%E3%80%81%E8%A7%A3%E7%A0%81%E5%92%8C%E7%BC%A9%E6%94%BE%E7%9A%84%20gst%20%E6%8F%92%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2310242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20are%20available%20options%20for%20ISP%20on%20IMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2310242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%8F%92%E4%BB%B6%EF%BC%8C%E6%88%91%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Frelease-note%2FRN00210.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%3C%2FA%3E%E4%B8%AD%E6%89%BE%E5%88%B0%E4%BA%86%E9%99%8D%E7%BA%A7%E3%80%81%E7%BC%96%E7%A0%81%E5%92%8C%E8%A7%A3%E7%A0%81%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E-%20imxvideoconvert_g2d%EF%BC%9A%E5%9F%BA%E4%BA%8E%20GPU2D%20%E7%9A%84%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E3%80%82%3CBR%20%2F%3E-%20imxvideoconvert_ipu%EF%BC%9A%E5%9F%BA%E4%BA%8E%20IPU%20%E7%9A%84%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E3%80%82%3CBR%20%2F%3E-%20imxvideoconvert_pxp%EF%BC%9A%E5%9F%BA%E4%BA%8E%20PXP%20%E7%9A%84%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E3%80%82%3CBR%20%2F%3E-%20imxvideoconvert_ocl%EF%BC%9A%E5%9F%BA%E4%BA%8E%20OpenCL%20%E7%9A%84%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E3%80%82%3CBR%20%2F%3E-%20%E8%87%AA%E5%8A%A8%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%EF%BC%9A%E6%A0%B9%E6%8D%AE%E8%BE%93%E5%85%A5%E5%92%8C%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%E9%80%89%E6%8B%A9%E5%9F%BA%E4%BA%8E%20i.MX%20%E7%A1%AC%E4%BB%B6%E7%9A%84%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E6%88%96%E5%85%B6%E4%BB%96%3CBR%20%2F%3E%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E3%80%82%3CBR%20%2F%3E-%20v4l2convert%EF%BC%9A%E5%9F%BA%E4%BA%8E%20V4L2%20%E5%86%85%E5%AD%98%E5%88%B0%E5%86%85%E5%AD%98%E7%9A%84%E8%BD%AC%E6%8D%A2%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3CBR%20%2F%3E-%20%E5%AF%B9%E4%BA%8E%20imxvideoconvert_ocl%EF%BC%8C%E7%9B%AE%E5%89%8D%E4%B8%8D%E6%94%AF%E6%8C%81%E6%97%8B%E8%BD%AC%E3%80%82%E6%94%AF%E6%8C%81%20CSC%E3%80%81%E5%8E%BB%E9%9A%94%3CBR%20%2F%3E%E8%A1%8C%E3%80%81%E7%BC%A9%E5%B0%8F%E6%AF%94%E4%BE%8B%E3%80%81%E5%B9%BF%E8%A7%92%E9%B1%BC%E7%9C%BC%E7%95%B8%E5%8F%98%E6%A0%A1%E6%AD%A3%E3%80%81%E8%A7%86%E9%A2%91%E8%A3%81%E5%89%AA%E5%92%8C%E8%89%B2%E5%BD%A9%E8%8C%83%E5%9B%B4%E8%BD%AC%E6%8D%A2%E3%80%82%3CBR%20%2F%3E-%20%E5%AF%B9%E4%BA%8E%20v4l2convert%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%9C%A8%E6%94%AF%E6%8C%81%20ISI%20%E5%86%85%E5%AD%98%E8%BD%AC%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%E8%87%AA%E5%8A%A8%E6%B3%A8%E5%86%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E-%20v4l2h264enc%EF%BC%9A%E5%9F%BA%E4%BA%8E%20VPU%20%E7%9A%84%20AVC%2FH.264%E8%A7%86%E9%A2%91%E7%BC%96%E7%A0%81%E5%99%A8%3CBR%20%2F%3E-%20v4l2h265enc%EF%BC%9A%E5%9F%BA%E4%BA%8E%20VPU%20%E7%9A%84%20HEVC%20%E8%A7%86%E9%A2%91%E7%BC%96%E7%A0%81%E5%99%A8%3CBR%20%2F%3E-%20v4l2jpegenc%EF%BC%9AV4L2%20JPEG%20%E7%BC%96%E7%A0%81%E5%99%A8%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%91%84%E5%83%8F%E6%9C%BA%E6%8B%93%E6%89%91%E7%BB%93%E6%9E%84%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%89%93%E5%8D%B0%E6%8B%93%E6%89%91%E7%BB%93%E6%9E%84%E5%B9%B6%E8%AF%86%E5%88%AB%E6%91%84%E5%83%8F%E6%9C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E-media-ctl%20-d%20%2Fdev%2Fmedia8%20--print-dot%26gt%3B%20media8.dot%20%20%20%20%EF%BC%88%E5%9C%A8%20i.mx95%20EVK%20%E7%9B%AE%E6%A0%87%E6%9D%BF%E4%B8%AD%EF%BC%89%3C%2FP%3E%0A%3CP%3E-dot%20-Tpng%20media0.dot%20-o%20media0-ap1302.png%20%20(%E5%9C%A8%E4%B9%8C%E7%8F%AD%E5%9B%BE%E7%94%B5%E8%84%91%E4%B8%AD%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20are%20available%20options%20for%20ISP%20on%20IMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%20imx95%20evk%20%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%E6%8B%93%E6%89%91%E7%BB%93%E6%9E%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22media8-ap1302.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22media8-ap1302.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375616i7BFB71FDD44FCA6D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22media8-ap1302.png%22%20alt%3D%22media8-ap1302.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20libcamerasrc%20%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E7%AE%A1%E9%81%93%E8%BF%90%E8%A1%8C%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3Egst-launch-1.0-e%20libcamerasrc%20camera-name%3D%20%22%20%2Fbase%2Fsoc%2Fbus%20%4042000000%20%2Fi2c%20%4042530000%20%2Fmax96724%20%4027%20%2Fi2c-mux%2Fi2c%20%400%20%2Fmx95mbcam%20%4040%20%22%20src%3A%3A%20stream-role%3D%E5%8F%96%E6%99%AF%E5%99%A8%EF%BC%81video%2Fx-raw%EF%BC%8C%E6%A0%BC%E5%BC%8F%20%3D%20nv12%EF%BC%8C%E5%AE%BD%E5%BA%A6%20%3D%201920%EF%BC%8C%E9%AB%98%E5%BA%A6%20%3D%201280%EF%BC%8C%E5%B8%A7%E7%8E%87%20%3D%2030%2F1%EF%BC%81%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%EF%BC%81v4l2h264enc%EF%BC%81h264parse%EF%BC%81mp4mux%EF%BC%81filesink%20%E4%BD%8D%E7%BD%AE%3D%2Ftmp%2Fcam0_processed.mp4%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FSTRONG%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20v4l2src%20%E8%BF%90%E8%A1%8C%E6%91%84%E5%83%8F%E6%9C%BA%EF%BC%9F%E6%AD%A4%E5%A4%96%EF%BC%8C%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E5%99%A8%E7%BC%A9%E6%94%BE%E8%A7%86%E9%A2%91%E8%80%8C%E4%B8%8D%E5%B0%86%E8%A7%86%E5%9B%BE%E8%A3%81%E5%89%AA%E4%B8%BA%201920*382%20%E7%9A%84%E6%8F%92%E4%BB%B6%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E
