IMX8MP LVDS does not work
3,421件の閲覧回数
koo_sensei
Hello.
I'm trying to work with mistubishi LVDS panel directly connected to LVDS of i.MX8m PLUS.
I'm working with custom board but it is based on imx8mp evk.
I refered to imx8mp-evk-jdi-wuxga-lvds-panel.dts, so this is the .dts what I made.
	lvds0_panel {
        compatible = "panel-lvds";
	    backlight = <&lvds_backlight>;
		status = "okay";
		data-mapping = "jeida-24";
		width-mm = <160>;
		height-mm = <120>;
		panel-timing {
	                clock-frequency = <50000000>;
        	        hactive = <320>;
	                vactive = <240>;
        	        hback-porch = <65>;
	                hfront-porch = <65>;
        	        vback-porch = <14>;
                	vfront-porch = <3>;
	                hsync-len = <32>;
        	        vsync-len = <5>;
                	hsync-active = <0>;
	                vsync-active = <0>;
        	        de-active = <1>;
                	pixelclk-active = <0>;
	                power-on-delay = <40>;
        	        power-off-delay = <16>;
                	relax-delay = <1000>;
        port {
              	panel_lvds_in: endpoint {
					remote-endpoint = <&lvds_out>;
&lcdif1 {
	status = "okay";
&lcdif2 {
	status = "okay";
&lcdif3 {
	status = "okay";
	thres-low  = <1 2>;             /* (FIFO * 1 / 2) */
	thres-high =  4>;             /* (FIFO * 3 / 4) */
&ldb_phy {
	status = "okay";
&ldb {
	status = "okay";
	fsl,dual-channel;
        lvds-channel@0 {
                fsl,data-mapping = "spwg";
		status = "okay";
		/delete-node/ port@1;
                port@1 {
                        reg = <1>;
                        lvds_out: endpoint {
                                remote-endpoint = <&panel_lvds_in>;
And according to dmesg log, panel-lvds probe completed. as I know, there should be the file something like /sys/class/drm/card1-LVDS-1, but there's file list of /sys/class/drm/ in my situation is pretty different.
root@imx8mpevk:/sys/class/drm# ls
card0 renderD128 version
So, when I excute 'weston-flower' after weston-start, there's errors that says cannot find display.
root@imx8mpevk:~# weston-start
root@imx8mpevk:~# weston-flower
failed to connect to Wayland display: No such file or directory
failed to create display: No such file or directory
I read many of NXP community articles that similar of my case, but any of them was not helpful.
Can I get any clue of this situation?
タグ(1)
3 返答(返信)
1,094件の閲覧回数
SanthoshRajavel
@Zhiming_Liu  Iam also facing the same problem in IMX8MPlus . Can you guide that
3,374件の閲覧回数
Zhiming_Liu
The lvds driver isn't probed correctly.
For single channel panel, the dts node should like below.
&ldb {
	status = "okay";
	lvds-channel@0 {
		fsl,data-width = <24>;
		status = "okay";
		port@1 {
			reg = <1>;
				remote-endpoint = <&xxxxx>;
 You should confirm the pixel format, jeida or spwg in panel-lvds
3,364件の閲覧回数
koo_sensei
Dear @Zhiming_Liu .
I did you advised, but it does not work.
I'm using Kernel 5.4.70, and I checked some source code below /drivers/gpu.
Properties like 'fsl,data-mapping' and 'fsl,data-width' are used in "of_get_bus_format()" in /drivers/gpu/drm/bridge/fsl-imx-ldb.c. I add printk msg in "of_get_bus_format()" function but I cannot find my printk msg at dmesg log.
And of_get_bus_format() functions is called by function binds ldb, but Kernel does not call this function.
I also checked imx8mp_ldb_bind() in drivers/gpu/imx/imx8mp-ldb.c, and I don't know why imx8mp_ldb_bind() does not called.
Can you advise how can I bind LDB interface in 5.4.70 Kernel?
%3CLINGO-SUB%20id%3D%22lingo-sub-1648377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20LVDS%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1648377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81%E4%B8%89%E8%8F%B1%20LVDS%20%E3%83%91%E3%83%8D%E3%83%AB%E3%82%92%20i.MX8m%20PLUS%20%E3%81%AE%20LVDS%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E4%BD%9C%E6%A5%AD%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20imx8mp%20evk%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eimx8mp-evk-jdi-wuxga-lvds-panel.dts%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C.dts%E3%81%A7%E3%81%99%E7%A7%81%E3%81%8C%E4%BD%9C%E3%81%A3%E3%81%9F%E3%82%82%E3%81%AE%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%09lvds0_panel%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22panel-lvds%22%3B%0A%09%20%20%20%20backlight%20%3D%20%26lt%3B%26amp%3Blvds_backlight%26gt%3B%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09data-mapping%20%3D%20%22jeida-24%22%3B%0A%09%09width-mm%20%3D%20%26lt%3B160%26gt%3B%3B%0A%09%09height-mm%20%3D%20%26lt%3B120%26gt%3B%3B%0A%0A%09%09panel-timing%20%7B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B50000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B320%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B240%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B65%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B65%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B14%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09vfront-porch%20%3D%20%26lt%3B3%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B32%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B5%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09hsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vsync-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20de-active%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09pixelclk-active%20%3D%20%26lt%3B0%26gt%3B%3B%0A%0A%09%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20power-on-delay%20%3D%20%26lt%3B40%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%09%20%20%20%20%20%20%20%20power-off-delay%20%3D%20%26lt%3B16%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09relax-delay%20%3D%20%26lt%3B1000%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%20%20%20%20%20%20%20%20port%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09panel_lvds_in%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Blvds_out%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%0A%26amp%3Blcdif1%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Blcdif2%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Blcdif3%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09thres-low%20%20%3D%20%26lt%3B1%202%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20(FIFO%20*%201%20%2F%202)%20*%2F%0A%09thres-high%20%3D%20%3CLI-EMOJI%20id%3D%22lia_red-heart%22%20title%3D%22%3Ared_heart%3A%22%3E%3C%2FLI-EMOJI%3E%204%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20(FIFO%20*%203%20%2F%204)%20*%2F%0A%7D%3B%0A%0A%26amp%3Bldb_phy%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Bldb%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%09fsl%2Cdual-channel%3B%0A%0A%20%20%20%20%20%20%20%20lvds-channel%400%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20fsl%2Cdata-mapping%20%3D%20%22spwg%22%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%2Fdelete-node%2F%20port%401%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20lvds_out%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bpanel_lvds_in%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3Edmesg%20%E3%83%AD%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81panel-lvds%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%2Fsys%2Fclass%2Fdrm%2Fcard1-LVDS-1%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%AF%20%2Fsys%2Fclass%2Fdrm%2F%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8C%E3%81%8B%E3%81%AA%E3%82%8A%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A%2Fsys%2Fclass%2Fdrm%23%20ls%0Acard0%20renderD128%20version%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81weston-start%20%E3%81%AE%E5%BE%8C%E3%81%AB%20'weston-flower'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A~%23%20weston-start%0Aroot%40imx8mpevk%3A~%23%20weston-flower%0Afailed%20to%20connect%20to%20Wayland%20display%3A%20No%20such%20file%20or%20directory%0Afailed%20to%20create%20display%3A%20No%20such%20file%20or%20directory%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AB%E9%A1%9E%E4%BC%BC%E3%81%97%E3%81%9F%20NXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E8%A8%98%E4%BA%8B%E3%82%92%E5%A4%9A%E6%95%B0%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A9%E3%82%8C%E3%82%82%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1648377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20LVDS%20does%20not%20work%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%E7%A7%81%E3%82%82%20IMX8MPlus%20%E3%81%A7%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E6%A1%88%E5%86%85%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1651634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20LVDS%20does%20not%20work%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1651634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E9%80%9A%E3%82%8A%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%205.4.70%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%2Fdrivers%2Fgpu%20%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E'fsl%2Cdata-mapping'%20%E3%82%84%20'fsl%2Cdata-width'%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AF%E3%80%81%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Ffsl-imx-ldb.c%20%E3%81%AE%20%22of_get_bus_format()%22%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Cof_get_bus_format()%E3%80%8D%E9%96%A2%E6%95%B0%E3%81%AB%20printk%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81dmesg%20%E3%83%AD%E3%82%B0%E3%81%A7%20printk%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81of_get_bus_format()%20%E9%96%A2%E6%95%B0%E3%81%AF%E9%96%A2%E6%95%B0%20binds%20ldb%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81drivers%2Fgpu%2Fimx%2Fimx8mp-ldb.c%20%E3%81%AE%20imx8mp_ldb_bind()%20%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81imx8mp_ldb_bind()%20%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E5.4.70%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%20LDB%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1650689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20LVDS%20does%20not%20work%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1650689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Elvds%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81dts%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bldb%20%7B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09lvds-channel%400%20%7B%0A%09%09fsl%2Cdata-mapping%20%3D%20%22spwg%22%3B%0A%09%09fsl%2Cdata-width%20%3D%20%26lt%3B24%26gt%3B%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09port%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%0A%09%09%09lvds_out%3A%20endpoint%20%7B%0A%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bxxxxx%26gt%3B%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E3%83%91%E3%83%8D%E3%83%ABLVDS%E3%81%AE%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%EF%BC%88jeida%E3%81%BE%E3%81%9F%E3%81%AFspwg%EF%BC%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Qmiller_0-1684204146649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Qmiller_0-1684204146649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F223263i3E1A770F0B489848%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Qmiller_0-1684204146649.png%22%20alt%3D%22Qmiller_0-1684204146649.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
