Webview : WebGL unavailable if the application id does not contains the word "chromium"
guerinyoann
We develop a board based on an iMX8MM with an Android 9 and an Android System WebView 95.0.4638.74.
The WebGL is unavailable if the application id does not contains the word "chromium".
If I create a app nammed "tech.chromium.test_webview3" the WebGL in the webview works.
If I create a app nammed "tech.other.test_webview3" the WebGL in the webview does not work.
Could you explain me the issue?
guerinyoann
guerinyoann
Please to explain me the issue quickly.
guerinyoann
We have post a request to Google.
https://bugs.chromium.org/p/chromium/issues/detail?id=1329195#c4
The problem seems in your code.
Could you explain me this issue?
