Webview : WebGL unavailable if the application id does not contains the word "chromium"
2,663 次查看
guerinyoann
We develop a board based on an iMX8MM with an Android 9 and an Android System WebView 95.0.4638.74.
The WebGL is unavailable if the application id does not contains the word "chromium".
If I create a app nammed "tech.chromium.test_webview3" the WebGL in the webview works.
If I create a app nammed "tech.other.test_webview3" the WebGL in the webview does not work.
Could you explain me the issue?
2,617 次查看
guerinyoann
2,636 次查看
guerinyoann
Please to explain me the issue quickly.
2,651 次查看
guerinyoann
We have post a request to Google.
https://bugs.chromium.org/p/chromium/issues/detail?id=1329195#c4
The problem seems in your code.
Could you explain me this issue?
