Hello there,
I have to make some changes to a system which uses i.MX353  (MCIMX353CJQ5C) and runs  Linux 3.18.24. Could you tell me, where could I find an SDK?
I also need a tool which could read an entire NAND flash and also program it. It seems that I should use Advanced Toolkit (ATK) for that. However, all download links seems to be dead.
Solved! Go to Solution.
imx35 is too old to find this, I only find SDK for 2.6. if you need it, I can send it to you
I send all packages what I have to you by mail, pls check
Thank you.
