Wanted i.MX35 SDK and Advanced Toolkit
1,501件の閲覧回数
AFaustas
Hello there,
I have to make some changes to a system which uses i.MX353  (MCIMX353CJQ5C) and runs  Linux 3.18.24. Could you tell me, where could I find an SDK?
I also need a tool which could read an entire NAND flash and also program it. It seems that I should use Advanced Toolkit (ATK) for that. However, all download links seems to be dead.
タグ(2)
1,444件の閲覧回数
joanxie
I send all packages what I have to you by mail, pls check
5 返答(返信)
1,463件の閲覧回数
joanxie
imx35 is too old to find this, I only find SDK for 2.6. if you need it, I can send it to you
1,455件の閲覧回数
AFaustas
Please send me the SDK which you have.
If you can't find Advanced Toolkit, could you find any other compatible tool which could read an entire NAND flash and also program it?
タグ(2)
1,445件の閲覧回数
joanxie
12件の閲覧回数
Tauqeer
Fresh Out Contributor
Wanted i.MX31 SDK and Advanced Toolkit for windows 10.
search all engines but still found old ATK that one not working properly drivers not found in that package.
please
1,328件の閲覧回数
AFaustas
Thank you.
