Video Decoder Suggestion For 4 Analog Cameras
Wobaffet
Senior Contributor I
Hello, we will be using 4 analog NTSC cameras and we want a decoder which can split the screen into 1,2 or 4 by choice. Decoder output will be passed to an application process (linux) and there will be also a surround view application so can anyone suggest a decoder that can fit for our needs and having a linux driver? Thank you in advance.
Bio_TICFSL
You can get them via 2 MIPI CSI and 2 USB CAM with the MX8Mplus.
Wobaffet
Thank you for your reply, we were thinking a solution like a separate decoder with multiple ADC's? Can you suggest any IC for a solution like this?
Wobaffet
Can I use ISL79987? Cameras will be Analog NTSC so I can't use usb.
