Does i.MX8 VPU encode support V4L2_Y12 format input source to make avi or mp4?
use unit_test/V4L2_VPU/ or GSTL VPU used demo
解決済! 解決策の投稿を見る。
is there any voice?
sorry for my delay, do you mean raw 12 bits data input, right? current vpu doesn't support this format, and imx8x uses ISI to capture video and can support raw data, you can convert this in the ISI first, then send it to the vpu
How about Raw 16 bits,VPU support or not?
How does IPU convert it?any API in IPU side?
vpu doesn't support raw data, but ISI does, i.mx8x uses ISI to convert data, for detailed information about ISI, pls refer to the imx8x reference manual, which has detailed information, and also check Figure 1-1. i.MX 8QuadXPlus/i.MX 8DualXPlus Simplified Block Diagram, you can find the data flow from camera
please give the answer
yes, vpu supports yuv420 only
Which image format does VPU support? I see from unit_test/V4L2_VPU/mxc_v4l2_vpu_enc VPU only support NV12 now,is it right?
How about my question?
hi,
Any one can help this question?
is any one can help my question?
what imx8 products do you mean?i.mx8MQ, imx8X or iMX8MM?
hello Joan,
it is imx8X
