VPU encode on i.MX8
VPU encode on i.MX8
6,225 次查看
xu_ji1
Does i.MX8 VPU encode support V4L2_Y12 format input source to make avi or mp4?
use unit_test/V4L2_VPU/ or GSTL VPU used demo
5,846 次查看
joanxie
yes, vpu supports yuv420 only
14 回复数
5,846 次查看
xu_ji1
is there any voice?
5,846 次查看
joanxie
sorry for my delay, do you mean raw 12 bits data input, right? current vpu doesn't support this format, and imx8x uses ISI to capture video and can support raw data, you can convert this in the ISI first, then send it to the vpu
5,846 次查看
xu_ji1
How about Raw 16 bits,VPU support or not?
How does IPU convert it?any API in IPU side?
5,846 次查看
joanxie
vpu doesn't support raw data, but ISI does, i.mx8x uses ISI to convert data, for detailed information about ISI, pls refer to the imx8x reference manual, which has detailed information, and also check Figure 1-1. i.MX 8QuadXPlus/i.MX 8DualXPlus Simplified Block Diagram, you can find the data flow from camera
5,846 次查看
xu_ji1
please give the answer
5,847 次查看
joanxie
5,846 次查看
xu_ji1
Which image format does VPU support? I see from unit_test/V4L2_VPU/mxc_v4l2_vpu_enc VPU only support NV12 now,is it right?
5,846 次查看
xu_ji1
How about my question?
5,846 次查看
xu_ji1
hi,
Any one can help this question?
5,846 次查看
xu_ji1
is any one can help my question?
5,846 次查看
joanxie
what imx8 products  do you mean?i.mx8MQ, imx8X or iMX8MM?
5,846 次查看
xu_ji1
5,846 次查看
xu_ji1
hello Joan,
5,846 次查看
xu_ji1
it is imx8X
