VIDIOC_DQBUF failed: Resource temporarily unavailable
14,457 次查看
yangthomas
     I use camera on platform of IMX6.Use selcect or epoll to control camera, but print this log.
int epoll_wait(int epfd, struct epoll_event * events, int maxevents, int timeout);
timeout = -1;
标签 (2)
9,870 次查看
yangthomas
Thanks.
I slove it.
drivers/media/video/mxc/capture/mxc_v4l2_capture.c
epoll has a bug.
6 回复数
9,870 次查看
umit_kayacik
Can you pls share the patch?
9,866 次查看
Hi Yang
this error is V4L2 Capture IOCTLs error, described for example at
VIDIOC_DQBUF: Resource temporarily unavailable · Issue #3 · fsphil/fswebcam · GitHub
you may wish to test camera with FSL-UT-V4L2-capture tests described in
attached document sect.5.5.2 Video4Linux API test.
9,871 次查看
yangthomas
Thanks.
I slove it.
epoll has a bug.
9,866 次查看
rbabu
Please share the patch to fix the issue.
9,866 次查看
chrisroed
Hi Thomas.
What is the epoll bug?
9,866 次查看
yangthomas
Camera can capture video.
