V4L2_MEMORY_USERPTR support in MIPI camera
2,762 次查看
titusstalin
Contributor V
Dear All,
iMX MIPI camera supports V4L2_MEMORY_USERPTR method ?
Currently I'm using V4L2_MEMORY_MMAP method, want to use USERPTR.
Can you please reply to this question ?
Titus S.
2,139 次查看
Yuri
  the following may be helpful
https://community.nxp.com/thread/359579
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
2,140 次查看
Yuri
Yuri
button. Thank you!
2,139 次查看
titusstalin
Contributor V
Sounds good.
Thanks for the reply.
