Using X11 + EPDC results in "Division by zero in kernel" error under some conditions
1,555件の閲覧回数
meelikkiik
I am using the Sololite i.MX6 evaluation board with a slightly modified 'fsl-image-qt5' image from the yocto build. When I run the mxc_epdc_fb_x11 test and fiddle around with the graphical interface a bit the test program terminates during a MXCFB_WAIT_FOR_UPDATE_COMPLETE ioctl call, notifying me of "Division by zero in kernel" error, and it also crashes the kernel in some cases. Check the attachment for a more detailed log.
How should I go about fixing this problem?
Original Attachment has been moved to: epdc_x11_zerodivision_log.txt.zip
ラベル(4)
1,233件の閲覧回数
Bio_TICFSL
Hi Meelik,
Appaeretnly the resolution and the pxp is causing this issue please check:
https://community.freescale.com/thread/352087
https://community.freescale.com/thread/351740
Hope this helps
