PXP testing
PXP testing
3,948 次查看
EricNelson
Senior Contributor II
Hi all,
We've had an ongoing discussion on the meta-freescale list about how to test the Pixel Pipeline (PXP) device.
     https://lists.yoctoproject.org/pipermail/meta-freescale/2015-April/thread.html#13349
In short, it appears that the unit_test program for the PXP is broken and not well documented, though the
gstreamer-1.0 pxp elements are partially functional.
Carlos used the gstreamer elements to perform a very thorough test of all pixel formats that are advertised by the driver:
     https://lists.yoctoproject.org/pipermail/meta-freescale/2015-April/013376.html
It appears that support for many are broken.
Please join the conversation if you have knowledge in this area.
4 回复数
2,316 次查看
LaurenPost
I did forward the community thread on and waiting for a reply from the team that owns PXP.
PXP (includdng unit test cases) will have updates in next release but not sure if that addresses this issue you reported.
2,316 次查看
daiane_angolini
I tested PXP unit-test with the latest imx7D release and I faced exactly the same error.
2,316 次查看
jamesbone
OtavioSalvador, can you please comment on this?
2,316 次查看
EricNelson
Hi James,
Otavio is the one who pointed out that we weren't including PXP in our device tree!
