Using OTPMK for encryption/decryption
2,133 次查看
ericg
Is it possible to use OTPMK directly to encrypt/decrypt data using CAAM through Cryptodev? Security reference manual says that you can put your key as a black key (encrypted using OTPMK) and use that key to encrypt/decrypt data. Basically what I'm looking for is the way to avoid putting keys from user space. Thanks.
1,853 次查看
Yuri
   The OTPMK may be used only for key encryption in blob technology for
black key encryption / decryption by CAAM.
Yuri
1,854 次查看
Yuri
Yuri
