USB start failed in Uboot
2,531 次查看
rahul_raja
I have flashed the i.MX8M Mini board and interrupted the boot process to access the U-Boot prompt. However, when I run the usb start command, I receive the following output
u-boot=> usb start
starting USB...
Bus usb@32e40000: Port not available.
Bus usb@32e50000: Port not available.
It seems that the USB ports are not being detected or initialized correctly in U-Boot. I need to access USB functionality from U-Boot for further testing. Could you please guide me on how to debug or resolve this issue?
Looking forward to your suggestions.
5 回复数
2,473 次查看
rahul_raja
BSP Version: Yocto Scarthgap (6.6.52)
Boot Device: SD Card
Additional Information:
I have modified the U-Boot Device Tree Source (DTS) file by setting dr_mode = "host" for the usbotg2 node (usb@32e50000). Following this change, the USB controller at usb@32e50000 is now functional and successfully detecting connected USB devices.
However, the USB controller at usb@32e40000 (usbotg1) is still experiencing detection issues. The current configuration for usbotg1 has dr_mode = "otg".
2,417 次查看
Rita_Wang
How about your design, usb1 work as otg and usb2 work as host? Which usb interface are you using, type-C or micro usb?
2,385 次查看
rahul_raja
Yes, our design configures USB1 to work as OTG and USB2 to function as host and also using micro usb
2,368 次查看
Rita_Wang
You modify the usb2 setting may not affect the USB1 in generally, are you changing in the board dts file or chip dts file?
2,482 次查看
Rita_Wang
Which version BSP are you using? And which boot device you boot up from here, SD card or emmc?
%3CLINGO-SUB%20id%3D%22lingo-sub-2131388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUboot%20%E5%90%AF%E5%8A%A8%20USB%20%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%B7%E6%96%B0%E4%BA%86%20i.MX8M%20%E8%BF%B7%E4%BD%A0%E6%9D%BF%E5%B9%B6%E4%B8%AD%E6%96%AD%E4%BA%86%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%BB%A5%E8%AE%BF%E9%97%AE%20U-Boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%3CSTRONG%3Eusb%20start%3C%2FSTRONG%3E%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E5%8D%B4%E6%94%B6%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%9C%3C%2FP%3E%3CP%3E%3CSTRONG%3Eu-boot%3D%26gt%3B%20usb%20start%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%BC%80%E5%A7%8B%E5%90%AF%E5%8A%A8%20USB...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E6%80%BB%E7%BA%BF%20usb%4032e40000%3A%20%E7%AB%AF%E5%8F%A3%E4%B8%8D%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E6%80%BB%E7%BA%BF%20usb%4032e50000%EF%BC%9A%E7%AB%AF%E5%8F%A3%E4%B8%8D%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%9C%8B%E6%9D%A5%E5%9C%A8%20U-%E5%90%AF%E5%8A%A8%20%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E6%A3%80%E6%B5%8B%E5%88%B0%E6%88%96%E5%88%9D%E5%A7%8B%E5%8C%96%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E4%BB%8E%20U-%E5%90%AF%E5%8A%A8%20%E8%AE%BF%E9%97%AE%20USB%20%E5%8A%9F%E8%83%BD%E4%BB%A5%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%B5%8B%E8%AF%95%E3%80%82%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E8%B0%83%E8%AF%95%E6%88%96%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2131388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20start%20failed%20in%20Uboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%80%E8%88%AC%E8%80%8C%E8%A8%80%EF%BC%8C%E4%BD%A0%E4%BF%AE%E6%94%B9%20usb2%20%E8%AE%BE%E7%BD%AE%E5%8F%AF%E8%83%BD%E4%B8%8D%E4%BC%9A%E5%BD%B1%E5%93%8D%20USB1%EF%BC%8C%E4%BD%A0%E6%98%AF%E5%9C%A8%E6%9D%BF%20dts%20%E6%96%87%E4%BB%B6%E8%BF%98%E6%98%AF%E8%8A%AF%E7%89%87%20dts%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20start%20failed%20in%20Uboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B0%86%20USB1%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20OTG%EF%BC%8C%E5%B0%86%20USB2%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%BB%E6%9C%BA%EF%BC%8C%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%20micro%20usb%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20start%20failed%20in%20Uboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%A6%82%E4%BD%95%EF%BC%8Cusb1%20%E7%94%A8%E4%BD%9C%E6%8E%A7%E5%88%B6%E7%AB%AF%EF%BC%8Cusb2%20%E7%94%A8%E4%BD%9C%E4%B8%BB%E6%9C%BA%EF%BC%9F%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%20USB%20%E6%8E%A5%E5%8F%A3%EF%BC%8CType-C%20%E8%BF%98%E6%98%AF%20micro%20USB%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20start%20failed%20in%20Uboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3EYocto%20Scarthgap%20(6.6.52)%20%3CBR%20%2F%3E%3CSTRONG%3E%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%EF%BC%9A%3C%2FSTRONG%3ESD%20%E5%8D%A1%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%85%B6%E4%BB%96%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BF%AE%E6%94%B9%E4%BA%86%20U-Boot%20%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%E6%BA%90%20(DTS)%20%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%BA%20usbotg2%20%E8%8A%82%E7%82%B9%20(usb%20%4032e50000)%20%E8%AE%BE%E7%BD%AE%20dr_mode%20%3D%20%22%20%E4%B8%BB%E6%9C%BA%20%22%E3%80%82%E5%9C%A8%E6%AD%A4%E6%9B%B4%E6%94%B9%E4%B9%8B%E5%90%8E%EF%BC%8Cusb%20%4032e50000%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8E%A7%E5%88%B6%E5%99%A8%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%B9%B6%E6%88%90%E5%8A%9F%E6%A3%80%E6%B5%8B%E5%88%B0%E8%BF%9E%E6%8E%A5%E7%9A%84%20USB%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8Cusb%4032e40000%20(usbotg1)%20%E7%9A%84%20USB%20%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E6%A3%80%E6%B5%8B%E9%97%AE%E9%A2%98%E3%80%82usbotg1%20%E7%9A%84%E5%BD%93%E5%89%8D%E9%85%8D%E7%BD%AE%E4%B8%BA%20dr_mode%20%3D%22otg%22%20%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20USB%20start%20failed%20in%20Uboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%9F%E8%BF%98%E6%9C%89%E4%BD%A0%E4%BB%8E%E8%BF%99%E9%87%8C%E5%BC%95%E5%AF%BC%E5%93%AA%E4%B8%AA%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%EF%BC%8CSD%20%E5%8D%A1%E8%BF%98%E6%98%AF%20emmc%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
