USB modem and voice support
4,294件の閲覧回数
arisav
We are using Huawei K3520 USB dongle for phone call in Linux environment. Phone call connection is established with AT commands and voice stream starts to flow from /dev/ttyUSB1.
Problem is that voice stream produces only random noise from speaker although we have tried many different codecs in aplay and Audacity.
Which codecs are commonly used for voice streams in modems and how them are activated with AT commands?
ラベル(3)
3,648件の閲覧回数
Hi Ari
please check
https://boundarydevices.com/cellular-modems-on-i-mx6-boards/
regarding codecs one can look at attached Linux Manual
Chapter 28 Advanced Linux Sound Architecture (ALSA) System
voice through usb modem is described in common resources
Voice call through GSM modem - Stack Overflow
