USB LDO
2,452 次查看
joshk
     I have an IMx6SL and would like to know what the USB LDO Register value is so I can modify the voltage in 25mV steps as outlined in the manual 36.4 USB LDO Regulator
Thank you!
~Josh
2,353 次查看
Hi Josh
as PMU is similar to i.MX6DQ, one can use description in
sect.50.7.2 Regulator 3P0 Register (PMU_REG_3P0) IMX6DQRM
2,354 次查看
Hi Josh
2,353 次查看
joshk
Thanks, I was guessing this was the correct register after looking at the SDK but this clarifies everything! :smileyhappy:
