UART CTS/RTS
UART CTS/RTS
6,317 次查看
deepanrajanbara
Hi Sir,
Ours is Custom board based on imx6 and we required to check the UART flow control for our board.But we are not sure how to check the flow control for imx6 UART.Can anyone please help me in checking the UART flow control(CTS/RTS) in software Kernel level.
Thank you,
Deepanraj.A
6 回复数
4,606 次查看
4,606 次查看
deepanrajanbara
Actually i wanted to check it applications wise is there any application in Linux to check Hardware flow control.
Thank you,
Deepanraj.A
4,606 次查看
saurabh206
Senior Contributor III
You can use mxc_uart_test.
Saurabh
4,606 次查看
JithCR
Hi Saurabh,
May I know how we can test the CTS/RTS using mxc_uart_test.(A high level information)
4,606 次查看
Hi Jith
please look at attached doc file from
imx-test-3.0.35-4.1.0.
~igor
4,606 次查看
saurabh206
