i.MX6: What does the DTE/DCE in i.MX6's UART do and how are RTS and CTS affected by the UARTxUFCR[DTEDCE] bit?
Question:
What exactly does the DTE/DCE interface in the i.MX6's UART module do and how are RTS and CTS affected by the UARTxUFCR[DTEDCE] bit?
In i.MX6 RM, revision 1:
Sections 64.2.1.2.1  (CTS) and 64.2.1.2.2 (RTS) both state that CTS and RTS change direction between DCE and DTE modes.  However, sections 64.4.3.1 (RTS_B) and 64.4.3.8 (CTS_B) state they do not change functions.  Is this a documentation error, or is there a difference between CTS/RTS and CTS_B/RTS_B?
It appears that some of this is covered in the IOMUX daisy chain by switching which pins are connected to CTS and RTS.
Answer:
Example 1: UART1 in DTE mode. RTS is an output from the UART IP block so it must be routed to a CTS pin.
Therefore, the SELECT_INPUT register could only use settings 00 or 10.
Example 2: UART1 in DCE mode. RTS is an input to the UART IP block so it must be routed to an RTS pin.
Therefore, the SELECT_INPUT register could only be set to 01 or 11.
At this point, we have assumed that the internal signals connected to the UART block do not change direction.  We believe that DCEDTE from the UART block connects into the IOMUX logic and controls the direction of the PAD.  Then, the IOMUX INPUT_SELECT mux is used to choose one of four pads to connect to the UART inputs while the IMOUX MUX_CTRL connects the output path.  Further, we assume it is an error to connect the UART input to a pad configured as an output or a UART output to a pad configured as an input.
The attached shows our assumptions
For the Uart IP, the CTS_B is always an output and RTS_B always an input. But the RTS_B &CTS_B IO will be swapped  when UART operates in different DTE or DCE mode.
IO port
DTE mode
DCE mode
direction
Uart IP port(internal)
direction
UART_CTS_B
O
CTS_B
I
RTS_B
UART_RTS_B
I
RTS_B
O
CTS_B
UART_TXD
O
TXD
I
RXD
UART_RXD
I
RXD
O
TXD
Regarding how to configure the IOMUX, please see the attached PDF.
タグ(5)
添付
コメント
This is very useful information.
But it seems that there is a typo in your table. In my opinion, DCE/DTE text in your table must be swapped.
DCE mode is selected if DCEDTE bit=0, according to iMX6 Dual/Quad Reference Manual, Rev.1, 04/2013,
page 5239, and your example text and UART MUX.pdf file says the same.
If DCEDTE=0, then UART_RTS_B is input, UART_CTS_B is output, UART_TXD is output and UART_RXD is input.
If DCEDTE=1, then UART_RTS_B is output, UART_CTS_B is input, UART_TXD is input and UART_RXD is output.
Here is the updated table:
IO Port
DCE Mode (DCEDTE=0)
DTE Mode (DCEDTE=1)
IO Direction
UART IP port
IO Direction
UART IP port
UART_CTS_B
O
CTS_B
I
RTS_B
UART_RTS_B
I
RTS_B
O
CTS_B
UART_TXD
O
TXD
I
RXD
UART_RXD
I
RXD
O
TXD
UART IP ports have always fixed direction for RxD/TxD and RTS/CTS, but the associated iMX6 IO ports have not.
Please correct me if I'm wrong.
Martin.
Martin,
you are right
If normal dce mode, then UART_RTS_B is input, UART_CTS_B is output, UART_TXD is output and UART_RXD is input.
If dte-mode, then UART_RTS_B is output, UART_CTS_B is input, UART_TXD is input and UART_RXD is output.
Does this mean that regardless of whether you configure a pinmux as DTE_RX or DCE_TX that pin will be used as the transmit for the iMX uart interface corresponding to it.
I'm bringing up a board where one of the peripheral's UARTs was connected in reverse by mistake, and I was hoping to use the pin mux to compensate for this in software but it seems that's not possible. Is that correct?
In other words, these two configurations do not affect which pin the iMx listens and transmits on?
        MX6UL_PAD_UART5_TX_DATA__UART5_DTE_RX    0x000010B0
        MX6UL_PAD_GPIO1_IO05__UART5_DTE_TX       0x000010B0
        MX6UL_PAD_UART5_TX_DATA__UART5_DCE_TX    0x000010B0
        MX6UL_PAD_GPIO1_IO05__UART5_DCE_RX       0x000010B0
Don't forget to set "fsl,dte-mode" in the device tree also.
Hi all,
I try to achieve the following configuration (on UART4):
IO portDirection
CSI0_DATA12 (ALT3, UART4_TX_DATA)O
CSI0_DATA13 (ALT3, UART4_RX_DATA)I
CSI0_DATA16 (ALT3, UART4_RTS_B)O :smileyalert:
CSI0_DATA17 (ALT3, UART4_CTS_B)I :smileyalert:
So, basically I want to cross only the CTS and RTS signals, being the UART4_CTS_B be the input, just as in DTE mode, but keep TX and RX direction as in DCE.
I have found the Select Input Register IOMUXC_UART4_UART_RTS_B_SELECT_INPUT (reg offset 0x910) what has the following description (which I admit is confusing to me):
(bit 0):
Input Select (DAISY) Field
Selecting Pads Involved in Daisy Chain.
Route RTS_B signal to pad when UART is in DCE mode. Route CTS_B signal to pad when UART is in
DTE mode.
0 CSI0_DATA16_ALT3 — Selecting ALT3 mode of pad CSI0_DAT16 for UART4_RTS_B.
1 CSI0_DATA17_ALT3 — Selecting ALT3 mode of pad CSI0_DAT17 for UART4_CTS_B.
Based on that I assumed that I am able to cross only the RTS/CTS pins, but I was not able to succeed.
I have found that imx6dl-pinfunc.h uses this register, and defines the seemingly needed pin functions:
#define MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x064 0x378 0x910 0x3 0x0
#define MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B 0x064 0x378 0x000 0x3 0x0
#define MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x068 0x37c 0x000 0x3 0x0
#define MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B 0x068 0x37c 0x910 0x3 0x1
So, I tried the following dts:
+ uart4 {
+ pinctrl_uart4: uart4grp {
+ fsl,pins = <
+ MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x1b0b1
+ MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x1b0b1
+ MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B 0x1b0b1
+ MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B 0x1b0b1
+&uart4 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_uart4>;
+ fsl,uart-has-rtscts;
+ status = "okay";
Unfortunately, it seems that it is not working as I would expect. The TX pin is ok, if I switch off crtscts, I can send out bytes on the TX, but it seems that the uart still reads the RTS pin as input flow control (I am not 100% sure, but as that pin is not connected and I cannot send bytes when crtscts is enabled, I guess that is the reason).
What am I getting wrong? Is it possible to implement this configuration? Or it should work like I wish, so I should double check my hw?
Thanks in advance:
Ferenc
hi,
 I too struck up with that, If you resolves that issue kindly reply me.
Hello Ferec,
I am also stuck in the same problem.
Did you get any solution?
Shreyans
What document does the diagram in the "UART MUX.pdf" attachment come from?  Can someone provide a link?  I haven't been able to find an "IMX6 RM" anywhere.  There are reference manuals for IMX6UL, etc.
I'd be interested to see the same picture expanded to include TXD and RXD pins in addition to CTS_B and RTS_B.  There seems to be some confusion (me included) whether DCEDTE swaps those as well, which could be cleared up via a diagram with all the UART pins and muxes.
See also this thread
i.MX6: how to use RTS/CTS properly using UART (DTE/DCE)
Marco Cavallini | KOAN sas | Bergamo - Italia
embedded software engineering
https://KoanSoftware.com
%3CLINGO-SUB%20id%3D%22lingo-sub-1105540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%3A%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B3%AA%E5%95%8F%3A%3C%2FP%3E%3CP%3Ei.MX6%20%E3%81%AE%20UART%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%20DTE%2FDCE%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AF%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6%20RM%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%201%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%2064.2.1.2.1(CTS)%E3%81%A8%2064.2.1.2.2(RTS)%E3%81%AB%E3%81%AF%E3%80%81CTS%20%E3%81%A8%20RTS%20%E3%81%8C%20DCE%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%20DTE%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E9%96%93%E3%81%A7%E6%96%B9%E5%90%91%E3%82%92%E5%A4%89%E3%81%88%E3%82%8B%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%2064.4.3.1%20(RTS_B)%20%E3%81%A8%2064.4.3.8%20(CTS_B)%20%E3%81%A7%E3%81%AF%E3%80%81%E6%A9%9F%E8%83%BD%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%A4%E3%82%8A%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%20CTS%2FRTS%20%E3%81%A8%20CTS_B%2FRTS_B%20%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AF%E3%80%81CTS%E3%81%A8RTS%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7IOMUX%E3%83%87%E3%82%A4%E3%82%B8%E3%83%BC%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%A7%E3%82%AB%E3%83%90%E3%83%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%AD%94%E3%81%88%3A%3C%2FP%3E%3CP%3E%E4%BE%8B%201%3A%20DTE%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20UART1%E3%80%82RTS%20%E3%81%AF%20UART%20IP%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81CTS%20%E3%83%94%E3%83%B3%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81SELECT_INPUT%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E8%A8%AD%E5%AE%9A00%E3%81%BE%E3%81%9F%E3%81%AF10%E3%81%97%E3%81%8B%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%202%3A%20DCE%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20UART1%E3%80%82RTS%20%E3%81%AF%20UART%20IP%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%B8%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81RTS%20%E3%83%94%E3%83%B3%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81SELECT_INPUT%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF01%E3%81%BE%E3%81%9F%E3%81%AF11%E3%81%AB%E3%81%97%E3%81%8B%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81UART%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%86%85%E9%83%A8%E4%BF%A1%E5%8F%B7%E3%81%AE%E6%96%B9%E5%90%91%E3%81%8C%E5%A4%89%E3%82%8F%E3%82%89%E3%81%AA%E3%81%84%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82UART%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%20DCEDTE%20%E3%81%AF%20IOMUX%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81PAD%20%E3%81%AE%E6%96%B9%E5%90%91%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81IOMUX%20INPUT_SELECT%20mux%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20UART%20%E5%85%A5%E5%8A%9B%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%204%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%89%E3%81%8B%E3%82%89%201%20%E3%81%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81IMOUX%20MUX_CTRL%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%83%91%E3%82%B9%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81UART%E5%85%A5%E5%8A%9B%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81UART%E5%87%BA%E5%8A%9B%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E4%BB%AE%E5%AE%9A%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EUart%20IP%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81CTS_B%E3%81%AF%E5%B8%B8%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81RTS_B%E3%81%AF%E5%B8%B8%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97CTS_B%E3%80%81RTS_B%20%E3%81%A8%20IO%20%E3%81%AF%E3%80%81UART%20%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%20DTE%20%E3%81%BE%E3%81%9F%E3%81%AF%20DCE%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E4%BA%A4%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20width%3D%22497%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20nowrap%3D%22nowrap%22%20rowspan%3D%222%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2292%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EIOPORT%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20colspan%3D%222%22%20nowrap%3D%22nowrap%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22201%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EDTE%20mode%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20colspan%3D%222%22%20nowrap%3D%22nowrap%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22204%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EDCE%20mode%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2262%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3E%E6%96%B9%E5%90%91%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22140%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EUart%20IP%E3%83%9D%E3%83%BC%E3%83%88(%E5%86%85%E9%83%A8)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2263%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3E%E6%96%B9%E5%90%91%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22141%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EUart%20IP%E3%83%9D%E3%83%BC%E3%83%88(%E5%86%85%E9%83%A8)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2292%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EUART_CTS_B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2262%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22140%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ECTS_B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2263%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22141%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ERTS_B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2292%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EUART_RTS_B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2262%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22140%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ERTS_B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2263%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22141%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ECTS_B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2292%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EUART_TXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2262%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22140%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ETXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2263%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22141%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ERXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2292%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EUART_RXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2262%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22140%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ERXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%2263%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20%23575757%3B%20font-size%3A%2010pt%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20nowrap%3D%22nowrap%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22bottom%22%20width%3D%22141%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3ETXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3EIOMUX%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AEPDF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F390320%22%20target%3D%22_blank%22%3Ei.MX6%3AUART(DTE%2FDCE)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FRTS%2FCTS%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E4%BD%BF%E3%81%84%E6%96%B9%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E--%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%AB%E3%82%B3%E3%83%BB%E3%82%AB%E3%83%B4%E3%82%A1%E3%83%AA%E3%83%BC%E3%83%8B%20%7C%E5%85%AC%E6%A1%88%20sas%20%7C%E3%83%99%E3%83%AB%E3%82%AC%E3%83%A2%20-%20%E3%82%A4%E3%82%BF%E3%83%AA%E3%82%A2%20%3CBR%20%2F%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%20%3CBR%20%2F%3E%3CA%20class%3D%22%22%20href%3D%22https%3A%2F%2FKoanSoftware.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2FKoanSoftware.com%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8CUART%20MUX.pdf%E3%80%8D%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%80%E3%82%A4%E3%82%A2%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E6%9D%A5%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%BC%B5%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%80%8CIMX6%20RM%E3%80%8D%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E3%82%82%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82IMX6UL%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E5%9B%B3%E3%81%8C%E6%8B%A1%E5%BC%B5%E3%81%95%E3%82%8C%E3%80%81CTS_B%20%E3%83%94%E3%83%B3%E3%81%A8%20RTS_B%20%E3%83%94%E3%83%B3%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%20TXD%20%E3%83%94%E3%83%B3%E3%81%A8%20RXD%20%E3%83%94%E3%83%B3%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82DCEDTE%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%89%E3%82%82%E4%BA%A4%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B(%E7%A7%81%E3%82%92%E5%90%AB%E3%82%80)%E6%B7%B7%E4%B9%B1%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEUART%E3%83%94%E3%83%B3%E3%81%A8%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%81%AE%E5%9B%B3%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Ferec%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E5%B7%BB%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E3%81%9D%E3%82%8C%E3%81%AB%E6%89%93%E3%81%A1%E5%8B%9D%E3%81%A3%E3%81%9F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E8%A6%AA%E5%88%87%E3%81%AB%E7%A7%81%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99(UART4%E3%81%A7)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20height%3D%22163%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22446%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%20style%3D%22width%3A%20340.4px%3B%22%3EIOPORT%3C%2FTH%3E%3CTH%20style%3D%22width%3A%2082.8px%3B%22%3E%E6%96%B9%E5%90%91%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22width%3A%20340.4px%3B%22%3ECSI0_DATA12%20(ALT3%2C%20UART4_TX_DATA)%3C%2FTD%3E%3CTD%20style%3D%22width%3A%2082.8px%3B%22%3EO%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22width%3A%20340.4px%3B%22%3E%3CSPAN%3ECSI0_DATA13%20(ALT3%2C%20UART4_RX_DATA)%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%2082.8px%3B%22%3EI%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22width%3A%20340.4px%3B%22%3ECSI0_DATA16%20(ALT3%2C%20UART4_RTS_B)%3C%2FTD%3E%3CTD%20style%3D%22width%3A%2082.8px%3B%22%3EO%20%3Asmileyalert%3A%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22width%3A%20340.4px%3B%22%3E%3CSPAN%3ECSI0_DATA17%20(ALT3%E3%80%81UART4_CTS_B)%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22width%3A%2082.8px%3B%22%3E%E7%A7%81%E3%81%AF%20%3Asmileyalert%3A%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81DTE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E5%85%A5%E5%8A%9BUART4_CTS_B%E3%81%A7%E3%81%82%E3%82%8BCTS%E4%BF%A1%E5%8F%B7%E3%81%A8RTS%E4%BF%A1%E5%8F%B7%E3%81%AE%E3%81%BF%E3%82%92%E4%BA%A4%E5%B7%AE%E3%81%95%E3%81%9B%E3%80%81TX%E3%81%A8RX%E3%81%AE%E6%96%B9%E5%90%91%E3%81%AFDCE%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%B6%AD%E6%8C%81%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESelect%20Input%20Register%20IOMUXC_UART4_UART_RTS_B_SELECT_INPUT(reg%20offset%200x910)%E3%81%AB%E6%AC%A1%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%8C%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F(%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%AF%E6%B7%B7%E4%B9%B1%E3%82%92%E6%8B%9B%E3%81%8F%E3%81%93%E3%81%A8%E3%82%92%E8%AA%8D%E3%82%81%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E(%E3%83%93%E3%83%83%E3%83%88%200)%3A%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%E9%81%B8%E6%8A%9E(DAISY)%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3CBR%20%2F%3E%E3%83%87%E3%82%A4%E3%82%B8%E3%83%BC%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AB%E9%96%A2%E4%B8%8E%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%89%E3%81%AE%E9%81%B8%E6%8A%9E%E3%80%82%3CBR%20%2F%3ERTS_B%20%E3%81%8C%20DCE%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82UART%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%ABCTS_B%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3EDTE%E3%83%A2%E3%83%BC%E3%83%89%E3%80%82%3CBR%20%2F%3E0%20CSI0_DATA16_ALT3%20-%20UART4_RTS_B%E3%81%AE%E3%83%91%E3%83%83%E3%83%89CSI0_DAT16%E3%81%AEALT3%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20CSI0_DATA17_ALT3%20%E2%80%94%20UART4_CTS_B%E3%81%AE%E3%83%91%E3%83%83%E3%83%89CSI0_DAT17%E3%81%AEALT3%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81RTS%20%2F%20CTS%E3%83%94%E3%83%B3%E3%81%AE%E3%81%BF%E3%82%92%E9%80%9A%E9%81%8E%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Eimx6dl-pinfunc.h%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%83%94%E3%83%B3%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%23define%20MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B%200x064%200x378%200x910%200x3%200x0%3CBR%20%2F%3E%23define%20MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B%200x064%200x378%200x000%200x3%200x0%3C%2FP%3E%3CP%3E%5B...%5D%3C%2FP%3E%3CP%3E%23define%20MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B%200x068%200x37c%200x000%200x3%200x0%3CBR%20%2F%3E%23define%20MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B%200x068%200x37c%200x910%200x3%200x1%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AEdts%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%2B%20uart4%20%7B%3CBR%20%2F%3E%2B%20pinctrl_uart4%3A%20uart4grp%20%7B%3CBR%20%2F%3E%2B%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%2B%20MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA%200x1b0b1%3CBR%20%2F%3E%2B%20MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA%200x1b0b1%3CBR%20%2F%3E%2B%20MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B%200x1b0b1%3CBR%20%2F%3E%2B%20MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B%200x1b0b1%3CBR%20%2F%3E%2B%20%26gt%3B%3B%3CBR%20%2F%3E%2B%20%7D%3B%3CBR%20%2F%3E%2B%20%7D%3B%3C%2FP%3E%3CP%3E%5B...%5D%3C%2FP%3E%3CP%3E%2B%26amp%3Buart4%20%7B%3CBR%20%2F%3E%2B%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%2B%20%E3%83%94%E3%83%B3Ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart4%26gt%3B%3B%3CBR%20%2F%3E%2B%20FSL%E3%80%81UART-HAS-RTSCTS%3B%3CBR%20%2F%3E%2B%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%2B%7D%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E6%80%9D%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82TX%E3%83%94%E3%83%B3%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81crtscts%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81TX%E3%81%A7%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81uart%E3%81%AF%E3%81%BE%E3%81%A0RTS%E3%83%94%E3%83%B3%E3%82%92%E5%85%A5%E5%8A%9B%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%A8%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99(100%25%E7%A2%BA%E4%BF%A1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81crtscts%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E7%90%86%E7%94%B1%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BD%95%E3%82%92%E9%96%93%E9%81%95%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E7%A7%81%E3%81%8C%E6%9C%9B%E3%82%80%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81hw%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A7%E3%83%AC%E3%83%B3%E3%83%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%80%8Cfsl%2Cdte-mode%E3%80%8D%E3%82%82%E5%BF%98%E3%82%8C%E3%81%9A%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%82%92%20DTE_RX%20%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81DCE_TX%20%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81%E3%81%9D%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%20iMX%20uart%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AEUART%E3%81%AE1%E3%81%A4%E3%81%8C%E8%AA%A4%E3%81%A3%E3%81%A6%E9%80%86%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A1%E5%87%BA%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A3%9C%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81iMx%20%E3%81%8C%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%81%AB%E3%81%AF%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6UL_PAD_UART5_TX_DATA__UART5_DTE_RX%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x000010B0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6UL_PAD_GPIO1_IO05__UART5_DTE_TX%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x000010B0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMX6UL_PAD_UART5_TX_DATA__UART5_DCE_TX%200x000010B0%3CBR%20%2F%3EMX6UL_PAD_GPIO1_IO05__UART5_DCE_RX%200x000010B0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMartin%2C%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%E9%80%9A%E5%B8%B8%E3%81%AEdce%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81UART_RTS_B%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_CTS_B%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_TXD%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_RXD%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3Edte-mode%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81UART_RTS_B%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_CTS_B%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_TXD%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_RXD%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20i.MX6%20%E3%81%AE%20UART%20%E3%81%AE%20DTE%2FDCE%20%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81RTS%20%E3%81%A8%20CTS%20%E3%81%AF%20UARTxUFCR%5BDTEDCE%5D%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%97%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%9C%89%E7%94%A8%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%97%E3%83%9F%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E6%84%8F%E8%A6%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E5%86%85%E3%81%AEDCE%20%2F%20DTE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AF%E4%BA%A4%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EDCE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%20iMX6%20Dual%2FQuad%20Reference%20Manual%2C%20Rev.1%2C%2004%2F2013%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%20DCEDTE%E3%83%93%E3%83%83%E3%83%88%3D%200%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E9%81%B8%E6%8A%9E%20%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%205239%E3%83%9A%E3%83%BC%E3%82%B8%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BE%8B%E3%81%AE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A8UART%20MUX.pdf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EDCEDTE%3D0%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81UART_RTS_B%20%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_CTS_B%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_TXD%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_RXD%20%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3EDCEDTE%3D1%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81UART_RTS_B%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_CTS_B%20%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_TXD%20%E3%81%8C%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81UART_RXD%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20rowspan%3D%222%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22123%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EIO%20%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20colspan%3D%222%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22215%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSTRONG%3EDCE%20Mode%20(DCEDTE%3D0)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20colspan%3D%222%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22217%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSTRONG%3EDTE%20Mode%20(DCEDTE%3D1)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22102%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EIO%E6%96%B9%E5%90%91%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EUART%20IP%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22104%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EIO%E6%96%B9%E5%90%91%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EUART%20IP%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22123%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EUART_CTS_B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22102%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ECTS_B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22104%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ERTS_B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22123%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EUART_RTS_B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22102%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ERTS_B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22104%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ECTS_B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22123%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EUART_TXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22102%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ETXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22104%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ERXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22123%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EUART_RXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22102%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EI%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ERXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22104%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3EO%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22113%22%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ETXD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3EUART%20IP%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%20RxD%2FTxD%20%E3%81%A8%20RTS%2FCTS%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%B8%B8%E3%81%AB%E6%96%B9%E5%90%91%E3%81%8C%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20iMX6%20IO%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%82%89%E8%A8%82%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMartin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎10-14-2013 08:41 PM
更新者:
