Hello @AldoG ,thank you for your answer. I fixed the problem by creating a patch for the /gpu/drm/bridge/sec-dsim.c file. Here’s what I did.
I replaced this lines :
mvporch |= MVPORCH_SET_MAINVBP(vmode->vback_porch) | MVPORCH_SET_STABLEVFP(vmode->vfront_porch) | MVPORCH_SET_CMDALLOW(0x0);
with this lines
mvporch |= MVPORCH_SET_MAINVBP(vmode->vback_porch) | MVPORCH_SET_STABLEVFP(vmode->vfront_porch - 15) | MVPORCH_SET_CMDALLOW(0xf);
Then i added MIPI_DSI_MODE_VSYNC_FLUSH to dsi->mode_flags when setting mode, typically inside the panel driver.
