Testing signed images
3,618件の閲覧回数
eduardo3
I am in the process of adding signed images to our board but I was left with questions on how to test that.
After getting a signed os_cntr_signed.bin image, it boots fine. On u-boot when I try ahab_status, I see SECO events (because I don't have my keys fused yet).
Initially I thought I could use u-boot fuse override for testing the fuse values I need to use, but that is not implemented. After searching on how to use fuse shadow registers, I found that it is not possible. Examples:
https://community.nxp.com/t5/i-MX-Processors/Access-to-OCOTP-registers-from-SCU-on-IMX8QM-leads-to-h...
https://community.nxp.com/t5/i-MX-Processors/IMX8-unable-to-override-OCOTP-shadow-registers-Is-there...
Initially If thought I could implement something like what is mentioned in the first link.
Based on that, how am I supposed to test secure boot keys / commands without permanently fusing the keys or bricking the board?
What is NXP advice on that?
For reference, we are using i.MX8X (imx8qxp).
3,571件の閲覧回数
Bio_TICFSL
If not burning the SRK fuse, you may can use OPENSSL command to analyze the images with their key.
3 返答(返信)
3,542件の閲覧回数
eduardo3
I'll try the openssl approach in the future. Another FAE we contacted also confirmed there is no way of testing on a imx8 board without fusing the keys. His suggestion in that case was to fuse (if we are fine with that) but not close the device.
3,572件の閲覧回数
Bio_TICFSL
1,950件の閲覧回数
imx8mp_developer
I am interested in this topic!
I need to verify the os_cntr_signed.bin container coming out from a Yocto AHAB-signed build for imx93
If I do:
~/cst-4.0.0/linux64/bin/ahab_image_verifier os_cntr_signed.bin 0 0
I get:
Signature Block:
 Version: 0
 Length: 2648 bytes
 Tag: 0x90
 Certificate Offset: 0x0
 SRK Table/Array Offset: 0x10
 SRK Table:
   Tag: 0xD7
   Length: 2112 bytes
   Version: 66
   SRK Record:
     Tag: 0xE1
     Length: 527 bytes
     Sign Algorithm: RSA
     Hash Algorithm: SHA2_384
     Key Size/Curve: RSA4096
     SRK Flags: CA Flags
     Modulus (N):
Signature verification failed
This doesn't happen for imx-boot-imx93-var-som-aski-sd.bin-flash_singleboot_gdet
Signature Block:
 Version: 0
 Length: 400 bytes
 Tag: 0x90
 SRK Table:
   Tag: 0xD7
   Length: 308 bytes
   Version: 66
   SRK Record:
     Tag: 0xE1
     Length: 76 bytes
     Sign Algorithm: ECDSA
     Hash Algorithm: SHA2_256
     Key Size/Curve: PRIME256V1
     SRK Flags: None
     X Coordinate:  ....
     Y Coordinate:  ...
Signature verification successful
I am using a Digicert HSM for the signature
does anybody have a clue about the verification failed for os_cntr_signed ?
does anybody have a hint on how to verify the signature with openssl ?(just to exclude the issue is ahab_image_verifier itself)
%3CLINGO-SUB%20id%3D%22lingo-sub-1667502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1667502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%96%91%E5%95%8F%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9F%20os_cntr_signed.bin%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82u-boot%20%E3%81%A7%20ahab_status%20%E3%82%92%E8%A9%A6%E3%81%99%E3%81%A8%E3%80%81SECO%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(%E3%82%AD%E3%83%BC%E3%81%8C%E3%81%BE%E3%81%A0%E8%9E%8D%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81)%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E5%88%9D%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E5%80%A4%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20u-boot%20%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%20%E3%82%B7%E3%83%A3%E3%83%89%E3%82%A6%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BE%8B%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FAccess-to-OCOTP-registers-from-SCU-on-IMX8QM-leads-to-hang%2Ftd-p%2F1335399%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FSCU%20%E3%81%8B%E3%82%89%E3%81%AE%20OCOTP%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%20IMX8QM%20%E4%B8%8A%E3%81%A7%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%2Ftd-p%2F1335399%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FIMX8-unable-to-override-OCOTP-shadow-registers-Is-there-a-way%2Ftd-p%2F1424010%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FIMX8-unable-to-override-OCOTP-shadow-registers-Is-there-a-way%2Ftd-p%2F1424010%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E5%88%9D%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%82%AD%E3%83%BC%E3%82%92%E6%B0%B8%E4%B9%85%E7%9A%84%E3%81%AB%E6%BA%B6%E3%81%8B%E3%81%97%E3%81%9F%E3%82%8A%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%A3%8A%E3%81%97%E3%81%9F%E3%82%8A%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%BC%2F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6NXP%20%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81i.MX8X%20(imx8qxp)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Testing%20signed%20images%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99!%3CBR%20%2F%3E%3CSPAN%3Eimx93%E7%94%A8%E3%81%AEYocto%20AHAB%E7%BD%B2%E5%90%8D%E3%83%93%E3%83%AB%E3%83%89%E3%81%8B%E3%82%89%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8Bos_cntr_signed.bin%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%82%E3%81%97%E7%A7%81%E3%81%8C%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%81%AA%E3%82%89%3A%3CBR%20%2F%3E%20~%2Fcst-4.0.0%2Flinux64%2Fbin%2Fahab_image_verifier%20os_cntr_signed.bin%200%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%BE%97%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CFONT%20color%3D%22%23999999%22%3E%E7%BD%B2%E5%90%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E9%95%B7%E3%81%95%3A%202648%E3%83%90%E3%82%A4%E3%83%88%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%82%BF%E3%82%B0%3A%200x90%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%200x0%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23999999%22%3ESRK%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%2F%E9%85%8D%E5%88%97%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%200x10%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23999999%22%3ESRK%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%82%BF%E3%82%B0%3A%200xD7%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E9%95%B7%E3%81%95%3A%202112%E3%83%90%E3%82%A4%E3%83%88%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2066%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23999999%22%3ESRK%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%82%BF%E3%82%B0%3A%200xE1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E9%95%B7%E3%81%95%3A%20527%E3%83%90%E3%82%A4%E3%83%88%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E7%BD%B2%E5%90%8D%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3A%20RSA%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3A%20SHA2_384%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E3%82%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%2F%E6%9B%B2%E7%B7%9A%3A%20RSA4096%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23999999%22%3ESRK%E6%97%97%EF%BC%9ACA%E6%97%97%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E5%BC%BE%E6%80%A7%E7%8E%87%EF%BC%88N%EF%BC%89%3A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23999999%22%3E.....%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23999999%22%3E%E7%BD%B2%E5%90%8D%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eimx-boot-imx93-var-som-aski-sd.bin-flash_singleboot_gdet%E3%81%A7%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23808080%22%3E%3CSPAN%3E%E7%BD%B2%E5%90%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200%3CBR%20%2F%3E%E9%95%B7%E3%81%95%3A%20400%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E3%82%BF%E3%82%B0%3A%200x90%3CBR%20%2F%3E%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%200x0%3CBR%20%2F%3E%20SRK%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%2F%E9%85%8D%E5%88%97%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%200x10%3CBR%20%2F%3E%20SRK%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%3CBR%20%2F%3E%E3%82%BF%E3%82%B0%3A%200xD7%3CBR%20%2F%3E%E9%95%B7%E3%81%95%3A%20308%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2066%3CBR%20%2F%3E%20SRK%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3A%3CBR%20%2F%3E%E3%82%BF%E3%82%B0%3A%200xE1%3CBR%20%2F%3E%E9%95%B7%E3%81%95%3A%2076%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E7%BD%B2%E5%90%8D%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3A%20ECDSA%3CBR%20%2F%3E%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3A%20SHA2_256%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%2F%E3%82%AB%E3%83%BC%E3%83%96%3A%20PRIME256V1%3CBR%20%2F%3E%20SRK%E3%83%95%E3%83%A9%E3%82%B0%3A%20%E3%81%AA%E3%81%97%3CBR%20%2F%3EX%E5%BA%A7%E6%A8%99%3A%20....%3CBR%20%2F%3E%20Y%E5%BA%A7%E6%A8%99%3A%20...%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23808080%22%3E%3CSPAN%3E......%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CFONT%20color%3D%22%23808080%22%3E%E7%BD%B2%E5%90%8D%E6%A4%9C%E8%A8%BC%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FFONT%3E%E7%BD%B2%E5%90%8D%E3%81%AB%E3%81%AFDigicert%20HSM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3Eos_cntr_signed%20%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E7%90%86%E7%94%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%BD%95%E3%81%8B%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%20openssl%20%E3%81%A7%E7%BD%B2%E5%90%8D%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F(ahab_image_verifier%20%E8%87%AA%E4%BD%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E9%99%A4%E5%A4%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81)%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1670908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Testing%20signed%20images%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1670908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%8A%E5%BE%8C%E3%81%AF%20openssl%20%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%81%A3%E3%81%9F%E5%88%A5%E3%81%AE%20FAE%20%E3%82%82%E3%80%81%E3%82%AD%E3%83%BC%E3%82%92%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%AA%E3%81%97%E3%81%A7%20imx8%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AECASE%E3%81%AE%E5%BD%BC%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%E3%80%81%EF%BC%88%E3%81%9D%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%EF%BC%89%E8%9E%8D%E5%90%88%E3%81%99%E3%82%8B%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%96%89%E3%81%98%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1669327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Testing%20signed%20images%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1669327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ESRK%20%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E7%84%BC%E3%81%8D%E4%BB%98%E3%81%91%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81OPENSSL%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%BC%E3%81%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%88%86%E6%9E%90CAN%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
