IMX8 - unable to override OCOTP shadow registers. Is there a way?
ParkerJesme
I am trying to emulate fuse registries but the the source code does not support the `override` command in uboot.
I have tried using `devmem2` for reading and still no luck.
```c
devmem2 0x08000000
/dev/mem opened.
Memory mapped at address 0xffffa04b9000.
Read at address 0x08000000 (0xffffa04b9000): 0xA000AC62
Is there a way to write and read to the fuse registers in userspace?
Tags (2)
AldoG
It is impossible to write the shadow registers without programming the fuses. For security reasons, the OCOTP can only be modified by the SECO.
And the SECO (nor the SCU) doesn't export any API to write only the shadow registers without programming the fuses.
Aldo.
