Tensorflow SDK compile
7,782件の閲覧回数
weilly_li
     I get some error  When I compile SDK  using "bitbake -c populate_sdk imx-image-full"
     Error : Unable to locate package tensorflow-lite-staticdev
     BSP : L5.10.35.2.0.0
    How can I fix this problem ? Thank you
Weilly
7,643件の閲覧回数
weilly_li
Dear All,
I solved this problem about the newest bsp can't compile tensorflow DEMO issue by myself.
Please follow step
(1) Build BSP L5.10.35.2.0.0 SDK of i.MX8MPlus
      $ source ./imx-setup-release.sh -b bld-xwayland      $ Add in local.conf
         IMAGE_INSTALL_append += " packagegroup-imx-ml"
         TOOLCHAIN_TARGET_TASK_append += "tensorflow-lite-dev armnn-dev  onnxruntime-dev"
      $  bitbake -c populate_sdk imx-image-full
       Tip :  tensorflow-lite-staticdev package has some problem for this version
(2) Install SDK
      $  cd /home/weilly/fsl-yocto-8mp/bld-xwayland/tmp/deploy/sdk
      $ ./fsl-imx-xwayland-glibc-x86_64-imx-image-full-cortexa53-crypto-imx8mpevk-toolchain-5.10-hardknott.sh
(3) Setting Environment
     $ source /opt/fsl-imx-xwayland/5.10-hardknott/environment-setup-cortexa53-crypto-poky-linux
(4) Download Tensorflow Lite Source Code
     $ git clone https://github.com/tensorflow/tensorflow
     $ git checkout v2.4.0
(5) Compile Code
     $ cd /tensorflow/tensorflow/lite/examples/label_image
    $ $CC -o label_image_weilly label_image.cc bitmap_helpers.cc ../../tools/evaluation/utils.cc \
        -I=/usr/include/tensorflow/lite/tools/make/downloads/flatbuffers/include \
        -I=/usr/include/tensorflow/lite/tools/make/downloads/absl \
        -ltensorflow-lite -lstdc++ -lpthread -lm -ldl -lrt
here, Share.
Weilly
10 返答(返信)
7,772件の閲覧回数
Hi Weilly
one can try steps provided in sect.5.6.7 NXP® eIQTM machine learning   i.MX Yocto Project User’s Guide​
7,765件の閲覧回数
weilly_li
Hi, igorpadykov.
I had follow step on this document. So I get this problem !
Can you get me a correctly suggest?? I really need the solution .
Thank !!
Weilly
7,754件の閲覧回数
what processor used in the case.
7,747件の閲覧回数
weilly_li
Hi, igorpadykov.
      frist, i appreciate your concern.
      Using Platform is i.MX8MPlus
      My Step :
      >> EULA=1 MACHINE=imx8mpevk DISTRO=fsl-imx-xwayland
      >> source ./imx-setup-release.sh -b bld-xwayland
      >> local.conf >> Add TOOLCHAIN_TARGET_TASK_append
      >> bitbake -c populate_sdk imx-image-full
      So ,  I get some error  When I compile SDK  using "bitbake -c populate_sdk imx-image-full"
      Thank You !!
Weilly Li
7,741件の閲覧回数
for tensorflow-lite compilation errors may be useful to look at
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Compiling-L5-4-3-1-0-0-BSP-On-Ubuntu-180...
7,709件の閲覧回数
weilly_li
Hi, @igorpadykov
      i have confirmed add it . so I know this toolchian's problem of "tensorflow-lite-staticdev"
      Platform : NXP i.MX8MPlus tesnorflow-lite-satatucdev.pngtesnorflow-lite-satatucdev.png
Weilly
7,702件の閲覧回数
suggest to post issue on dedicated "eIQ Machine Learning Software" community
https://community.nxp.com/t5/eIQ-Machine-Learning-Software/bd-p/eiq
7,646件の閲覧回数
weilly_li
Dear All,
Please follow step
(2) Install SDK
(5) Compile Code
here, Share.
Weilly
7,644件の閲覧回数
weilly_li
Dear All,
Please follow step
(2) Install SDK
(5) Compile Code
here, Share.
Weilly
7,734件の閲覧回数
weilly_li
Hi, igorpadykov.
Just tried your suggestion. I have updated all package that document. But still not compile SDK ...
BTW. I can succed compile the instruction "bitbake imx-image-full". So I think is not solution.
at the yesterday, someone meet this problem too on the communtity. Can you help us figure out this problem?
Thank you for your assistance !!
Weilly
