External abort happened during our test.
Please help to check.
Linux kernel:Linux version 4.14.98
HW platform: NXP IMX8DX Abort detail is as below. Thank you.
< 36.833886> 2019-03-31 16:00:26 [ 30.147569] [c1: kworker/1:2H: 1805]Timeout for IPC response!
< 36.941883> 2019-03-31 16:00:26 [ 30.255566] [c1: kworker/1:2H: 1805]Timeout for IPC response!
< 36.951571> 2019-03-31 16:00:26 [ 30.265255] [c1: kworker/1:2H: 1805]Failed power operation on resource 248 sc_err 3
< 36.967904> 2019-03-31 16:00:26 [ 30.281587] [c1: kworker/1:2H: 1805]Synchronous External Abort: synchronous external abort (0x96000210) at 0xffff00000d4e0024
< 36.982979> 2019-03-31 16:00:26 [ 30.296662] [c1: kworker/1:2H: 1805]Internal error: : 96000210 [#1] PREEMPT SMP
< 36.996409> 2019-03-31 16:00:26 [ 30.310092] [c1: kworker/1:2H: 1805]Modules linked in:
< 37.006710> 2019-03-31 16:00:26 [ 30.320393] [c1: kworker/1:2H: 1805] crc32_ce
< 37.017528> 2019-03-31 16:00:26 [ 30.331211] [c1: kworker/1:2H: 1805] crct10dif_ce
< 37.043174> 2019-03-31 16:00:26 [ 30.356858] [c1: kworker/1:2H: 1805]CPU: 1 PID: 1805 Comm: kworker/1:2H Not tainted 4.14.98-akso-v1.0+g9cb413aec97a #1
< 37.051201> 2019-03-31 16:00:26 [ 30.364884] [c1: kworker/1:2H: 1805]Hardware name: Hirain i.MX8DX AKSO (DT)
< 37.059340> 2019-03-31 16:00:26 [ 30.373024] [c1: kworker/1:2H: 1805]Workqueue: kblockd blk_mq_run_work_fn
< 37.082539> 2019-03-31 16:00:26 [ 30.396223] [c1: kworker/1:2H: 1805]task: ffff80001923c380 task.stack: ffff00000dd58000
< 37.095275> 2019-03-31 16:00:26 [ 30.408958] [c1: kworker/1:2H: 1805]PC is at esdhc_readl_le+0xc/0x150
< 37.107834> 2019-03-31 16:00:26 [ 30.421517] [c1: kworker/1:2H: 1805]LR is at sdhci_send_command+0xb0/0xab8
< 37.123527> 2019-03-31 16:00:26 [ 30.437211] [c1: kworker/1:2H: 1805]pc : [<ffff0000089c29ec>] lr : [<ffff0000089b5900>] pstate: 200001c5
< 37.137302> 2019-03-31 16:00:26 [ 30.450985] [c1: kworker/1:2H: 1805]sp : ffff00000dd5bad0
< 37.149519> 2019-03-31 16:00:26 [ 30.463202] [c1: kworker/1:2H: 1805]x29: ffff00000dd5bad0
< 37.162159> 2019-03-31 16:00:26 [ 30.475843] [c1: kworker/1:2H: 1805]x28: 0000000000000000
< 37.188585> 2019-03-31 16:00:26 [ 30.502268] [c1: kworker/1:2H: 1805]x27: 0000000000000001
< 37.199845> 2019-03-31 16:00:26 [ 30.513529] [c1: kworker/1:2H: 1805]x26: 0000000000000000
< 37.216438> 2019-03-31 16:00:26 [ 30.530122] [c1: kworker/1:2H: 1805]x25: ffff8000191f8a00
< 37.225265> 2019-03-31 16:00:26 [ 30.538946] [c1: kworker/1:2H: 1805]x24: ffff800018ec9000
< 37.244307> 2019-03-31 16:00:26 [ 30.557991] [c1: kworker/1:2H: 1805]x23: 0000000000418958
< 37.261129> 2019-03-31 16:00:26 [ 30.574813] [c1: kworker/1:2H: 1805]x22: 0000000000000003
< 37.264538> 2019-03-31 16:00:26 [ 30.578222] [c1: kworker/1:2H: 1805]x21: ffff8000174a6388
< 37.267949> 2019-03-31 16:00:26 [ 30.581633] [c1: kworker/1:2H: 1805]x20: 000000000000000b
< 37.271364> 2019-03-31 16:00:26 [ 30.585047] [c1: kworker/1:2H: 1805]x19: ffff800018ec9600
< 37.274778> 2019-03-31 16:00:26 [ 30.588462] [c1: kworker/1:2H: 1805]x18: 00000000000007e2
< 37.278194> 2019-03-31 16:00:26 [ 30.591877] [c1: kworker/1:2H: 1805]x17: 0000ffffa405a6a0
< 37.281605> 2019-03-31 16:00:26 [ 30.595289] [c1: kworker/1:2H: 1805]x16: ffff000008239e60
< 37.285014> 2019-03-31 16:00:26 [ 30.598698] [c1: kworker/1:2H: 1805]x15: 0000000000000013
< 37.288425> 2019-03-31 16:00:26 [ 30.602108] [c1: kworker/1:2H: 1805]x14: 000000000000003b
< 37.291831> 2019-03-31 16:00:26 [ 30.605515] [c1: kworker/1:2H: 1805]x13: 0000000000000000
< 37.295244> 2019-03-31 16:00:26 [ 30.608928] [c1: kworker/1:2H: 1805]x12: 00000007035eee5d
< 37.298653> 2019-03-31 16:00:26 [ 30.612336] [c1: kworker/1:2H: 1805]x11: 0000000000000000
< 37.302066> 2019-03-31 16:00:26 [ 30.615749] [c1: kworker/1:2H: 1805]x10: 00000000000009b0
< 37.305480> 2019-03-31 16:00:26 [ 30.619163] [c1: kworker/1:2H: 1805]x9 : ffff800016420a88
< 37.308894> 2019-03-31 16:00:26 [ 30.622578] [c1: kworker/1:2H: 1805]x8 : ffff8000174a6458
< 37.312309> 2019-03-31 16:00:26 [ 30.625993] [c1: kworker/1:2H: 1805]x7 : 0000000000000001
< 37.315722> 2019-03-31 16:00:26 [ 30.629406] [c1: kworker/1:2H: 1805]x6 : 0000000000000100
< 37.319138> 2019-03-31 16:00:26 [ 30.632821] [c1: kworker/1:2H: 1805]x5 : 000000000000ffff
< 37.322549> 2019-03-31 16:00:26 [ 30.636233] [c1: kworker/1:2H: 1805]x4 : 0000000000000000
< 37.325956> 2019-03-31 16:00:26 [ 30.639639] [c1: kworker/1:2H: 1805]x3 : ffff800018ec9600
< 37.329360> 2019-03-31 16:00:26 [ 30.643044] [c1: kworker/1:2H: 1805]x2 : ffff00000d4e0024
< 37.332768> 2019-03-31 16:00:26 [ 30.646452] [c1: kworker/1:2H: 1805]x1 : 0000000000000024
< 37.336180> 2019-03-31 16:00:26 [ 30.649863] [c1: kworker/1:2H: 1805]x0 : ffff800018ec9600
< 37.339589> 2019-03-31 16:00:26 [ 30.653272] [c1: kworker/1:2H: 1805]Process kworker/1:2H (pid: 1805, stack limit = 0xffff00000dd58000)
< 37.346822> 2019-03-31 16:00:26 [ 30.660506] [c1: kworker/1:2H: 1805]Call trace:
< 37.349276> 2019-03-31 16:00:26 [ 30.662959] [c1: kworker/1:2H: 1805]Exception stack(0xffff00000dd5b990 to 0xffff00000dd5bad0)
< 37.355731> 2019-03-31 16:00:26 [ 30.669414] [c1: kworker/1:2H: 1805]b980: ffff800018ec9600 0000000000000024
< 37.363575> 2019-03-31 16:00:26 [ 30.677259] [c1: kworker/1:2H: 1805]b9a0: ffff00000d4e0024 ffff800018ec9600 0000000000000000 000000000000ffff
< 37.371420> 2019-03-31 16:00:26 [ 30.685103] [c1: kworker/1:2H: 1805]b9c0: 0000000000000100 0000000000000001 ffff8000174a6458 ffff800016420a88
< 37.379267> 2019-03-31 16:00:26 [ 30.692950] [c1: kworker/1:2H: 1805]b9e0: 00000000000009b0 0000000000000000 00000007035eee5d 0000000000000000
< 37.387110> 2019-03-31 16:00:26 [ 30.700793] [c1: kworker/1:2H: 1805]ba00: 000000000000003b 0000000000000013 ffff000008239e60 0000ffffa405a6a0
< 37.394955> 2019-03-31 16:00:26 [ 30.708638] [c1: kworker/1:2H: 1805]ba20: 00000000000007e2 ffff800018ec9600 000000000000000b ffff8000174a6388
< 37.402799> 2019-03-31 16:00:26 [ 30.716483] [c1: kworker/1:2H: 1805]ba40: 0000000000000003 0000000000418958 ffff800018ec9000 ffff8000191f8a00
< 37.410646> 2019-03-31 16:00:26 [ 30.724329] [c1: kworker/1:2H: 1805]ba60: 0000000000000000 0000000000000001 0000000000000000 ffff00000dd5bad0
< 37.418489> 2019-03-31 16:00:26 [ 30.732173] [c1: kworker/1:2H: 1805]ba80: ffff0000089b5900 ffff00000dd5bad0 ffff0000089c29ec 00000000200001c5
< 37.426334> 2019-03-31 16:00:26 [ 30.740018] [c1: kworker/1:2H: 1805]baa0: ffff8000174a62c8 ffff800018f4c800 ffffffffffffffff ffff00000dd5bbee
< 37.434176> 2019-03-31 16:00:26 [ 30.747859] [c1: kworker/1:2H: 1805]bac0: ffff00000dd5bad0 ffff0000089c29ec
< 37.439074> 2019-03-31 16:00:26 [ 30.752757] [c1: kworker/1:2H: 1805][<ffff0000089c29ec>] esdhc_readl_le+0xc/0x150
< 37.444484> 2019-03-31 16:00:26 [ 30.758167] [c1: kworker/1:2H: 1805][<ffff0000089b6370>] sdhci_request+0x68/0xe8
< 37.449810> 2019-03-31 16:00:26 [ 30.763493] [c1: kworker/1:2H: 1805][<ffff000008999518>] __mmc_start_request+0x78/0x1f0
< 37.455742> 2019-03-31 16:00:26 [ 30.769425] [c1: kworker/1:2H: 1805][<ffff00000899a040>] mmc_start_request+0x60/0x88
< 37.461414> 2019-03-31 16:00:26 [ 30.775097] [c1: kworker/1:2H: 1805][<ffff0000089adecc>] mmc_blk_mq_issue_rq+0x394/0x3c0
< 37.467433> 2019-03-31 16:00:26 [ 30.781117] [c1: kworker/1:2H: 1805][<ffff0000089aea50>] mmc_mq_queue_rq+0x100/0x258
< 37.473108> 2019-03-31 16:00:26 [ 30.786791] [c1: kworker/1:2H: 1805][<ffff00000847d64c>] blk_mq_dispatch_rq_list+0x31c/0x3a0
< 37.479477> 2019-03-31 16:00:26 [ 30.793160] [c1: kworker/1:2H: 1805][<ffff000008481f04>] blk_mq_sched_dispatch_requests+0x1ac/0x228
< 37.486453> 2019-03-31 16:00:26 [ 30.800137] [c1: kworker/1:2H: 1805][<ffff00000847ba84>] __blk_mq_run_hw_queue+0xa4/0x118
< 37.492559> 2019-03-31 16:00:26 [ 30.806243] [c1: kworker/1:2H: 1805][<ffff00000847bb58>] blk_mq_run_work_fn+0x60/0x70
< 37.498323> 2019-03-31 16:00:26 [ 30.812007] [c1: kworker/1:2H: 1805][<ffff0000080c7ae8>] process_one_work+0x1d8/0x4a0
< 37.504078> 2019-03-31 16:00:26 [ 30.817762] [c1: kworker/1:2H: 1805][<ffff0000080c7df8>] worker_thread+0x48/0x470
< 37.509491> 2019-03-31 16:00:26 [ 30.823174] [c1: kworker/1:2H: 1805][<ffff0000080ce078>] kthread+0x130/0x138
< 37.514470> 2019-03-31 16:00:26 [ 30.828153] [c1: kworker/1:2H: 1805][<ffff000008084ed0>] ret_from_fork+0x10/0x18
< 37.519795> 2019-03-31 16:00:26 [ 30.833478] [c1: kworker/1:2H: 1805]Code: 17ffffc5 f9400c02 aa0003e3 8b21c042 (b9400040)
< 37.525908> 2019-03-31 16:00:26 [ 30.839591] [c1: kworker/1:2H: 1805]---[ end trace eef49fda263e0196 ]---
< 37.530539> 2019-03-31 16:00:26 [ 30.844222] [c1: kworker/1:2H: 1805]Kernel panic - not syncing: Fatal exception
< 37.535779> 2019-03-31 16:00:26 [ 30.849462] [c1: kworker/1:2H: 1805]SMP: stopping secondary CPUs
< 37.539717> 2019-03-31 16:00:26 [ 30.853400] [c1: kworker/1:2H: 1805]CPU: 1 PID: 1 Comm: systemd State: S (sleeping)
< 37.545296> 2019-03-31 16:00:26 [ 30.858980] [c1: kworker/1:2H: 1805]Call trace:
< 37.547751> 2019-03-31 16:00:26 [ 30.861434] [c1: kworker/1:2H: 1805][<ffff000008085ebc>] __switch_to+0x94/0xd8
< 37.552905> 2019-03-31 16:00:26 [ 30.866589] [c1: kworker/1:2H: 1805][<ffff000008df721c>] __schedule+0x19c/0x6f8
< 37.558141> 2019-03-31 16:00:26 [ 30.871824] [c1: kworker/1:2H: 1805][<ffff000008df77b0>] schedule+0x38/0xa0
< 37.563035> 2019-03-31 16:00:26 [ 30.876719] [c1: kworker/1:2H: 1805][<ffff000008dfb234>] schedule_hrtimeout_range_clock+0x84/0xe8
< 37.569834> 2019-03-31 16:00:26 [ 30.883517] [c1: kworker/1:2H: 1805][<ffff000008dfb2a8>] schedule_hrtimeout_range+0x10/0x18
< 37.576118> 2019-03-31 16:00:26 [ 30.889801] [c1: kworker/1:2H: 1805][<ffff00000828a354>] SyS_epoll_wait+0x2d4/0x400
< 37.581701> 2019-03-31 16:00:26 [ 30.895385] [c1: kworker/1:2H: 1805][<ffff00000828a58c>] SyS_epoll_pwait+0x10c/0x148
< 37.587371> 2019-03-31 16:00:26 [ 30.901054] [c1: kworker/1:2H: 1805]Exception stack(0xffff00000806bec0 to 0xffff00000806c000)
< 37.593829> 2019-03-31 16:00:26 [ 30.907512] [c1: kworker/1:2H: 1805]bec0: 0000000000000004 0000fffffef99d70 0000000000000046 0000000000003a98
< 37.601674> 2019-03-31 16:00:26 [ 30.915357] [c1: kworker/1:2H: 1805]bee0: 0000000000000000 0000000000000008 8080808080808080 fefefefefefefeff
< 37.609520> 2019-03-31 16:00:26 [ 30.923204] [c1: kworker/1:2H: 1805]bf00: 0000000000000016 0000000000000001 0101010101010101 0000000000000000
< 37.617363> 2019-03-31 16:00:26 [ 30.931047] [c1: kworker/1:2H: 1805]bf20: 0000000000000018 000000005ca0e414 003114720c000000 000023e7e5000000
< 37.625208> 2019-03-31 16:00:26 [ 30.938892] [c1: kworker/1:2H: 1805]bf40: 0000ffffb9405bc0 0000ffffb8f02138 0000ffffb8fa1a70 0000000000000004
< 37.633053> 2019-03-31 16:00:26 [ 30.946736] [c1: kworker/1:2H: 1805]bf60: 0000ffffb9407000 20c49ba5e353f7cf 0000fffffef99d70 0000000000000001
< 37.640900> 2019-03-31 16:00:26 [ 30.954584] [c1: kworker/1:2H: 1805]bf80: 0000aaaac31adbd8 0000aaaac31ad1a8 0000fffffef9a370 0000aaaac31abb00
< 37.648743> 2019-03-31 16:00:26 [ 30.962426] [c1: kworker/1:2H: 1805]bfa0: 00000000000009b7 0000fffffef99d30 0000ffffb92c6d54 0000fffffef99d30
< 37.656587> 2019-03-31 16:00:26 [ 30.970271] [c1: kworker/1:2H: 1805]bfc0: 0000ffffb8f01f90 0000000000000000 0000000000000004 0000000000000016
< 37.664433> 2019-03-31 16:00:26 [ 30.978117] [c1: kworker/1:2H: 1805]bfe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
< 37.672278> 2019-03-31 16:00:26 [ 30.985962] [c1: kworker/1:2H: 1805][<ffff000008083ac0>] el0_svc_naked+0x34/0x38
< 37.677602> 2019-03-31 16:00:26 [ 30.991286] [c1: kworker/1:2H: 1805]CPU: 0 PID: 2 Comm: kthreadd State: S (sleeping)
