Hi Roberto
PLL4 provides SSI_CLK_ROOT and this initialization is already
present in clk-imx6sx.c. Regarding external oscillator it may be only necessary
to check requirement from i.MX6SX RM sect.62.8.4 SSI Clocking :
Care should be taken to ensure that the bit clock frequency (either internally generated by
dividing the SSI's sys clock or sourced from external device through Tx/Rx clock ports)
is never greater than 1/5 of the ipg_clk (from CCM) frequency.
