Setting bootargs automatically
1,571 次查看
Goi
Is it possible to set bootargs automatically after flashing the image, without entering them manually in the console after every flash?
Thanks.
标记 (2)
1,485 次查看
MassimoBonazzi
Modify env_something.c file in /rpm/BUILD/u-boot*/common/env_mmc.c to match your env var and rebuild uboot.
Once it boots it wont find the enviroment and it will use the default you provided in the .c file.
